Burnt Valve or Bad Lifter??? - JeepForum.com
post #1 of 6 Old 09-09-2009, 06:28 AM Thread Starter
Chadrick454
1977 CJ5
Thought I would ask the experts on the CJ forum. My 77 CJ has an AMC 360 in it. Ever since I got this project Jeep running there has been a ticking/clicking noise, almost like an exhaust leak, coming from the passenger side of the engine. Long story short I can pull the plug wire off the back passenger side cylinder and nothing happens. No change in sound, RPM, or anything. Tried adjusting timing and that made no difference. Talked to a friend who has rebuilt a couple motors and he said it sounds like either a burnt valve or a bad lifter.
Has anyone here had the same/similar problem?
Can anyone suggest something to check or test?
Chadrick454 is offline
post #2 of 6 Old 09-09-2009, 12:01 PM
CJhollic
1980 CJ7
Check compression on that cylinder.
Weber 32/36 DGEV,
4" Suspension Lift , 1 " body lift
8000 lb Winch,
ViAir Onboard Air
TeamRush ignition upgrade with MSD 6a CDI
Dual Batteries
KC Daylighters
Cold Air Intake
Lock-Right Lockers
Yukon 1 piece axles
Custom Bumper& Swing Out Tire Carrier
Mile Marker Hubs
Chevy Blower Upgrade
1500 lb airbag suspension
Floor mounted gun rack (2 guns)
CJhollic is offline
post #3 of 6 Old 09-09-2009, 12:06 PM
mudking_ky87
i had that happen, was a cracked head, probably a valve though
97' TJ Sport 2.5" - 3" suspension Rancho? lift, 3" BL, Smittybuilt SRC Rear bumper, KC lighing, Tube front bumper and side steps, warn x8000i winch, 33" Mickey Thompson MTZ, magnaflow exhaust, gibson Hi flow cat. more to come in the future!
mudking_ky87 is offline
post #4 of 6 Old 09-09-2009, 12:14 PM
Coiz
1979 CJ7
If you have a burnt valve, that means that combustion pressures are able to escape around the valve and seat. Move that cylinder to TDC compression and use a compression tester adapter with the shrader valve removed. Inject 100 psi of air into the cylinder. A small amount of blow by into the crankcase is normal. You will hear a light hiss from the dipstick tube or oil fill cap so don't worry about that. If one of the valves is burnt you will hear a heavy hiss from either the intake/carb or the exhaust pipe depending on which one is leaking. It should be fairly obvious if that is the cause.
If neither the intake or exhaust are hissing, you likely have a weak lifter that is not opening a valve and causing that cylinder to have low/no power. At that point you will have to at least pull the valve cover and push on the rocker/pushrod to check the lifter resistance.
I just helped a friend with a freshly built 331 stroker in a road course racing Mustang do this exact same thing just last week. We found the lifter on the exhaust valve felt like a sponge while the intake side was stiff as expected.
Mike
Coiz is offline
post #5 of 6 Old 09-09-2009, 12:50 PM Thread Starter
Chadrick454
1977 CJ5
Thanks for all the great advice guys! I will check compression and cylinder leakage next weekend when I get back from vacation.
post #6 of 6 Old 09-09-2009, 12:58 PM
swatson454
1983 CJ7
X2 Perfect!
swatson454 is offline
Replacements for Liquid Check Valve/Roll Over valve jpd1899 Jeep CJ Forum 143 08-25-2015 09:07 PM
1964 CJ5 F-134 Engine, Burnt Valve? LastGenEK Jeep CJ Forum 13 12-29-2009 01:47 AM
My CJ burnt to the ground today!! jeepguy85 Jeep CJ Forum 66 11-02-2009 06:07 AM
Fuel gauge windings burnt up rkbell Jeep CJ Forum 1 02-22-2009 01:03 PM
AMC 360 Valve / lifter tap speeddemon651 Jeep CJ Forum 3 09-17-2008 06:45 PM
