Burning a little oil. - JeepForum.com
post #1 of 5 Old 09-04-2013, 12:52 PM Thread Starter
row684
So my 258 jeep which usually sits 8 months a year and maybe run the other 4 has started burning a little bit of oil. It comes out the exhaust when you rev it up and when doing a trail ride it starts puffing a little bit after a while like its building up at lower rpm's.
It still pulls fine up hills so I don't think it's rings. Valve seals? Stuck valve? Other???
row684 is offline
post #2 of 5 Old 09-04-2013, 01:34 PM
WillysCJ
1976 CJ6
Quick check. If it puffs smoke when you change gears then its valves. If it smokes the whole time its rings. Throw some broil or oil additive in and check if it gets better. If it does then its rings. It could just be a oil ring thats a bit sticky from standing a lot.
WillysCJ is offline
post #3 of 5 Old 09-04-2013, 02:04 PM
seabass1858
1983 CJ7
Might I also sugest a compression test if handy. Sometimes this would tell a story also. I would do a cold and warm test if possible.
seabass1858 is offline
post #4 of 5 Old 09-05-2013, 08:35 AM Thread Starter
row684
It is not all the time. I threw some Seafoam in with the last oil change hoping it would clean up the valve seals if that is what it is. What would you recommend for the rings?
row684 is offline
post #5 of 5 Old 09-05-2013, 08:37 AM Thread Starter
row684
I will see if I can find a tester as mine is 2,400 miles away at the moment and let you know. Looking for 100-140 with less than 25% difference correct?
row684 is offline
