Bumper from a YJ to a CJ - JeepForum.com
post #1 of 16 Old 10-03-2011, 01:52 PM Thread Starter
corvetteguy
How much different are the bumper mounts from a CJ to a YJ?
I have a front bar bumper from an 95, a guy called me wanting to buy it for his on his 82/83 CJ....is there any difference in the fit?
Will it bolt right on....thanks!
corvetteguy is offline
post #2 of 16 Old 10-03-2011, 01:54 PM
BrandonJames
1974 CJ5
cj7 should fit, I beleive, not cj5..
BrandonJames is offline
post #3 of 16 Old 10-03-2011, 02:02 PM
mvbrady
My 86 CJ is a little more narrow...about an inch or so on either side than a YJ,
he's gonna need to drill some new holes...pretty easy.
mvbrady is offline
post #4 of 16 Old 10-03-2011, 02:11 PM
Pathkiller
1974 CJ5
Wrong, a 76-83 CJ5 has identical frame dimensions to a 76-86 CJ7, the only difference is the length. Any bumper that fits a CJ7 also fits a 76+ CJ5. 55-75 are different.
Pathkiller is offline
post #5 of 16 Old 10-03-2011, 02:12 PM
HurricaneRZA
When I bought my bumper last week, it came for CJ/YJ/TJ.
For the CJ it has spacers and holes that are about 1inch offset from the YJ holes (for the narrower CJ)
If he drills a couple holes and slaps some washers in there it'll be good to go.
Originally Posted by YoureverydayXJ View Post
This is the most metal thing I have ever heard.
Originally Posted by doublins View Post
I always get people coming over and saying things like "I wish I knew how to do that," etc- but they don't realize- at some point I didn't know how to do it either- I had to figure it out.
HurricaneRZA is offline
post #6 of 16 Old 10-03-2011, 02:18 PM
RobsCrawlin7
no balls
RobsCrawlin7's Avatar
100% accurate
'01 TJ 4.7/NV3550, 2" lift, 35's, locked.
'79 CJ7 stock, 304
'98 XJ sold
'79 CJ7 sold
'82 CJ7 parted
'89 MJ sold
SSG David Mejias, SSG Eric Vick, SGT William Bowling, SGT Robert McDowell
1 April 2007
Rest In Peace Brothers
RobsCrawlin7 is offline
post #7 of 16 Old 10-03-2011, 02:21 PM
lucdog
lucdog's Avatar
1980 CJ5
The bolt holes are different between the two, the YJ being further apart. The front of the frame on a YJ is right at 0.0625" taller.
So the YJ bumper will fit on a CJ, if the mounting holes are redrilled.
When the bolts are tightend, the bumper will compress approximately the difference in frame height. Unless a small spacer is used.
Bumper length is the same.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #8 of 16 Old 10-03-2011, 03:03 PM
BESRK
GROUND POUNDER
BESRK's Avatar
1980 CJ5
Bill
We have a winner!!
BESRK is offline
post #9 of 16 Old 10-03-2011, 04:08 PM
jcalhoon84
1980 CJ5
Originally Posted by BESRK
We have a winner!!
Agreed!
jcalhoon84 is offline
post #10 of 16 Old 10-03-2011, 08:31 PM
mopar408
1974 CJ5
Mr Anal here, but are we talking sixty thousandths of an inch or 5/8th of an inch.
I'll defer to BESRK, he should know.
.0625 will need a file, .625 will need a torch.
If it's good TO you, it's gotta be good FOR you....
mopar408 is offline
post #11 of 16 Old 10-03-2011, 08:44 PM
HurricaneRZA
Not really, i guess if you're super anal about fitting (even though the washers go on the bottom). Sit tight I think I can take pics of the washer set I've got
EDIT:
Pics of said washer kit.
Didn't have a quarter, so for reference thats a AA battery.
post #12 of 16 Old 10-03-2011, 10:55 PM
lucdog
lucdog's Avatar
1980 CJ5
.0625" or 1/16" thats a lot of file work on the top of the frame.
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #13 of 16 Old 10-04-2011, 06:44 AM
HurricaneRZA
Wait hang on. Why would you cut/torch/grind? The bumper is taller than the frame. The frame remains untouched. This is a YJ bumper to a CJ, isn't it?
Sent from my Blaster while searching for the Rebels.
post #14 of 16 Old 10-04-2011, 07:22 AM
lucdog
lucdog's Avatar
1980 CJ5
I have no idea why mopar said that, I also thought .0625" was clear.
Bill
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1983 CJ7
lucdog is offline
post #15 of 16 Old 10-04-2011, 07:56 AM
CSP
No, one will need a different spacer than the other. The YJ bumper mounted on a CJ frame has a gap that needs to be filled.
CSP is offline
New Bumper my_304_cj7 Jeep CJ Forum 9 01-31-2011 12:28 AM
'74 Rear Bumper/Tire Carrier - Should I swap for a bumper w/tire mount? Agar426 Jeep CJ Forum 5 03-21-2010 08:26 PM
cj5 bumper ??s davegt Jeep CJ Forum 1 08-26-2008 03:00 PM
73 cj5 bumper? leetudor Jeep CJ Forum 3 05-28-2007 07:19 PM
SRC Front Bumper (and back bumper and side armor...) mountainwolf Jeep CJ Forum 1 11-28-2005 12:10 PM
