Building A fan Shroud CAUTION LONG AND PIC HEAVY!! - Page 2 - JeepForum.com
post #16 of 44 Old 05-26-2011, 02:26 PM
scrapman
Originally Posted by TBailey View Post
Looks good.The only thing I would have done differently would be to gelcoat it.Fiberglass and fiberglass resin are not water proof.
Why would it being "water proof" matter? Will the resin turn to mush if it gets wet?
scrapman is offline
post #17 of 44 Old 05-26-2011, 02:32 PM
mikeumkc
2009 JK Wrangler
I think you'll be quite fine without it being "waterproof". Fiberglass doesn't turn to mush in water. not at all. It is porous and will absorb water and dry out. much like wood. but I certainly dont see that being an issue with a fan shroud.
2009 JKU Rubicon. stock now.... I'm working on it.
mikeumkc is offline
post #18 of 44 Old 05-26-2011, 02:35 PM
Jim1611
Jim1611's Avatar
Now that's a great job my friend!! Nice to see some fiberglass work going on.
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #19 of 44 Old 05-26-2011, 02:36 PM
Bakunin
Bakunin's Avatar
Very nicely done! And a great example of how critical a decent fan shroud really is.
Bakunin is offline
post #20 of 44 Old 05-26-2011, 02:49 PM
TBailey
1983 CJ7
Fiberglass itself does not rot.Fiberglass resin will rot to an extent.It will only absorb water and dry so many times before it starts to crack and deteriorate.It will also get between multipe layers of glass and cause it to peel apart.At that point it wont be long before it comes apart and eats up the radiator.
The only reason I mentioned it is because it is something that is going to get wet.If you drive in the rain its getting wet.If you do a deep enough water crossing its getting wet.
TBailey is offline
post #21 of 44 Old 05-26-2011, 03:10 PM Thread Starter
jcal73
jcal73's Avatar
2015 JK Wrangler
Fiberglass itself does not rot.Fiberglass resin will rot to an extent.It will only absorb water and dry so many times before it starts to crack and deteriorate.At that point it wont be long before it comes apart and eats up the radiator.
Thanks for the input.
I would think that a good coat of paint would seal it up enough to be ok.
If I'm in that deep of water something has gone terribly wrong!
Jeff
Jeff
Our Jeep Links
jcal73 is offline
post #22 of 44 Old 05-26-2011, 03:17 PM
84scrambler
1984 CJ8
I'm a little skeptical to think a fan shroud will help with over heating issues at freeway speeds. The purpose of a fan is to move a sufficient amount of air across the radiator but the use of a fan goes away when you get up to speed (stick your hand behind the fan at idle vs sticking it out of your window at 50 mph and there is no comparison). Adding a fan shroud aids the fan due to its size limitation but once you get up to speed you will have uniform air coverage across the radiator which should be much better then any automotive fan would provide. This makes me think your radiator is undersized for the size of your engine.
Perhaps there is more to it then what I am thinking. Please keep us posted as you get more hours driving it on the road.
84scrambler is offline
post #23 of 44 Old 05-26-2011, 03:26 PM Thread Starter
jcal73
jcal73's Avatar
2015 JK Wrangler
It's a four core radiator.....
Did you read my first post??
Jeff
Our Jeep Links
jcal73 is offline
post #24 of 44 Old 05-26-2011, 06:04 PM
84scrambler
1984 CJ8
I skimmed through it again and can't find a mention of radiator size. Not important because I did see this written by you which I seemed to have missed the first time "It has too small a fan and not enough area open for the air to get through while on the road." reading that and looking at the picture makes complete sense for changing the shroud.
My personal experience I had a 4 core vertical copper radiator and had over heating issues. I switched to a two core cross flow aluminum radiator and temperatures dropped about 15 degrees. I didn't really have much of a fan shroud though.
i also saw an interesting design in a shroud, along the entire bottom it had spring flaps which would open up at highway speeds. Something to consider for future designs.
post #25 of 44 Old 05-26-2011, 06:15 PM Thread Starter
jcal73
jcal73's Avatar
2015 JK Wrangler
I was thinking that you must have missed the part about the original fan and shroud.
The aluminum was out of the question because of money!
I was thinking of adding flaps or doors to the original, but I wanted to get away from an electric fan anyway.
Jeff
Jeff
Our Jeep Links
jcal73 is offline
post #26 of 44 Old 05-26-2011, 06:30 PM Thread Starter
jcal73
jcal73's Avatar
2015 JK Wrangler
I'm going to pull it to refinish the paint/clean it up some.
How hard is it to use Gel Coat?
Can it be sprayed?
Do I have to paint it before or after or not at all?
Sorry for my ignorance, I've never used it.
Jeff
Jeff
Our Jeep Links
jcal73 is offline
post #27 of 44 Old 05-26-2011, 07:26 PM
brian613
1977 CJ5
nice build.. i've been thinking of making some custom stuff out of glass but dont know much about it so that video will help out
77 cj5 304 v8 np435 twin sticked dana 20 transfer scout dana 44's with 4.88 gears
brian613 is offline
post #28 of 44 Old 05-26-2011, 09:12 PM
TBailey
1983 CJ7
Can it be sprayed?
Jeff
Gel coat is simple to use but it has to be applied before the the top coat of paint.It can be sprayed once thinned.Thin it with acetone to about the consistency of water.If its not thin enough it will come out with a very rough texture.Be patient it will take three to four thin coats to get good coverage.Its also very easy to sand if you get a run or anything else goes wrong.Do not mix it in a plastic cup unless its a paint cup.The hardener will melt alot of plastics as will acetone.
TBailey is offline
post #29 of 44 Old 05-26-2011, 10:05 PM
FLynes
1976 CJ5
You did a great job fabbing that shroud up!
How close of a tolerance do you have between the fan blades and the shroud itself? The reason I ask is because I've read that, if you go offroad and get a decent amount of flex, the fan can make contact with the shroud.
Fred
Fred
Retired Army Guy
High Plains Drifter
1976 CJ-5
Lime Green
Black Wellington Vinyl Bench Seats
258 I-6 1bbl
T-150 3-Speed
3.54:1 Open Gears
FLynes is offline
post #30 of 44 Old 05-27-2011, 06:07 AM Thread Starter
jcal73
jcal73's Avatar
2015 JK Wrangler
Fred
Fred,
Thanks to you and all the others for the kind words.
I don't know about that much flex. I hope someone who has wheeled that hard can chime in.
It has about 1 inch or a little less between the blades and shroud.
Derale Performance tech support wanted 1/2 inch and covering only half of the thickness of the blades.
I'm pretty close on the covering half of the blades, but I made the template for the fan opening with one inch of clearance all the way around.
I wanted some "Fudge" room on the fan centering measurements.
It grew some in thickness with the 2 layers of glass and resin inside.
So it's a little less than 1inch and is almost centered on the fan.
Finding the center measurement of the fan in relation to the radiator core is hard to do.
You can't just use a small square and go from the center of the fan out to the core, this will make the center measurement high because of the tilt of the engine.
I used a length of heavy wire bent on 90deg to get the location from the core back to the center of the fan.
That’s where I drilled for the centering rod on the templates.
Sorry to be long winded.
Jeff
Jeff
Our Jeep Links
jcal73 is offline
fan shroud for v8 coday Jeep CJ Forum 0 07-12-2010 11:42 AM
fan into shroud spoonkilr Jeep CJ Forum 3 07-05-2010 12:49 PM
Fan shroud SonicR1 Jeep CJ Forum 4 02-05-2010 08:56 AM
Looking for Fan Shroud for 84 CJ-7 with GM 350 jbramble24 Jeep CJ Forum 1 03-09-2008 09:49 AM
Where can I get a Fan Shroud??? Boots Jeep CJ Forum 4 07-26-2002 10:37 AM
