Building of a CJ7 - Page 3 - JeepForum.com
post #31 of 73 Old 02-22-2009, 01:47 AM
Renegade86
Regarding your "homemade" Commando grill, which set of holes will you be using for the parking lamps? Or are you going to be utilizing all 4 holes for lights?
God Bless
1986 Renegade
Renegade86 is offline
post #32 of 73 Old 02-22-2009, 03:29 AM Thread Starter
sail78385
Ill be installing a pair of projector fog lights in the lower two holes and use the top two for the parking lamps.
sail78385 is offline
post #33 of 73 Old 02-22-2009, 04:10 AM
Renegade86
That's gonna look cool!
God Bless
1986 Renegade
post #34 of 73 Old 02-22-2009, 04:10 PM Thread Starter
sail78385
Here are the lights im gonna get.
post #35 of 73 Old 02-22-2009, 07:51 PM
imtheant
HAHA that pic looks like the latest GEICO commercials...
"I ALWAYS FEEL LIKE, SOMEBODY'S WATCHING MEEEE!!"
1983 CJ7 - Project "Surf Jeep Restoration"
imtheant is offline
post #36 of 73 Old 02-22-2009, 09:41 PM
molsenice
1964 CJ5
wow - how did I miss this thread - awsome work
molsenice is offline
post #37 of 73 Old 02-23-2009, 03:43 PM Thread Starter
sail78385
Just if anyone else is reading, I found out that I cant use my Model 20 on my chrysler 727. I have to use a dana 300, so Ill be looking for one when I get some mulah. Anyways in my 79 Jeep CJ I have a 304 with the Automatic GM hydromatic transmission. I believe this trans was connected to the model 20?? Anyways I dont believe this is the original motor and trans and such in my 79. I find it odd that the transfer case is engaged by a shifter simalr to whats found in the wagoneers but smaller. Does this make sense to anyone?
post #38 of 73 Old 02-23-2009, 03:48 PM
JoonHoss
2011 JK Wrangler
... Anyways in my 79 Jeep CJ I have a 304 with the Automatic GM hydromatic transmission. I believe this trans was connected to the model 20?? Anyways I dont believe this is the original motor and trans and such in my 79..?
my new '68 commando has the TH 400 and Model 20 T-case standard from the factory...
Hoss
"Gimme three gallons of low lead; two hot dogs and a strawberry soda..."JGW
JoonHoss is online now
post #39 of 73 Old 02-23-2009, 03:49 PM
bigjoe
1977 CJ7
Sail, If you have some pics it would help id what you have. It sounds like you might have a Quadratrac xcase. Going by what you posted your questioning the transfer case model. As I recall, the only transfer case bolted from the factory was the Quadratrac transfer case. It's a full time unit. The smaller shift to wrote about. Is it on the floor by the driver seat? If so and I could be wrong, but it sounds like the opt. low range unit for the full-time case. Hope this helps.
Seems like everyday is a Monday.
77' CJ-7 83' Chevy K10
bigjoe is offline
post #40 of 73 Old 02-23-2009, 03:51 PM
bigjoe
1977 CJ7
Hoss
See I was wrong. But I think the CJ's came with the GM tranny were only bolted to the Quadratrac xcase.
bigjoe is offline
post #41 of 73 Old 02-23-2009, 03:54 PM
JoonHoss
2011 JK Wrangler
I believe you are correct. (especially for his year CJ).
more info here
http://www.jeeptech.com/trans/
and here
http://www.jeeptech.com/xfer/
Hoss
post #42 of 73 Old 04-05-2009, 11:46 AM Thread Starter
sail78385
SO what do you do when you have 2 Jeeps neither of them work right? Build one!!
The 79 has massive rust problems in the frame and the 86 has a perfect frame and the running gear (axels) are crap. Here goes.....
86 tub
86 frame and 360 motor
grinding off body mounts ugh
big mess in the yard
post #43 of 73 Old 04-06-2009, 09:41 AM
JoonHoss
2011 JK Wrangler
so, are you changing (project) directions again then?
Hoss
post #44 of 73 Old 04-06-2009, 06:37 PM Thread Starter
sail78385
No. Same goal which is a commando CJ7 but I need a running and driving Jeep. I cant stand looking at others with the top and doors off, Im jeleous. So im taking the goods off of one jeep to make the other fully functional. I finally got the tub off today and will power wash the drivetrain tomorrw. Im excited. I have to be done in one month though!
post #45 of 73 Old 04-06-2009, 06:38 PM Thread Starter
sail78385
oh in case you were wondering the 79 CJ7 has a frame thats rusting from the inside out, hence the dismantiling. I dont wanna sell it and have someone get hurt.
Building a cj7 tub out of the available panels ttownjeep Jeep CJ Forum 2 09-18-2009 10:08 PM
Building a new harness happylilshroom Jeep CJ Forum 1 08-19-2009 09:02 PM
building a 360 Arcticcat843 Jeep CJ Forum 7 09-13-2008 12:22 PM
Building a 360? xulcuz Jeep CJ Forum 14 08-09-2008 06:19 PM
building a CJ7 mudding Jeep CJ Forum 3 03-14-2003 12:36 PM
