Building of a CJ7 - Page 2 - JeepForum.com
post #16 of 73 Old 08-07-2008, 04:56 PM Thread Starter
sail78385
Went to pull the engine tonight and one bolt from the manifold is giving me a tough time. Anyays the engine should be pulled tomorrow and shold be dropped in the frame sometime this weekend. Cant wait!
Anyone have any tips on how to clean and paint the engine while its out?
sail78385 is offline
post #17 of 73 Old 08-08-2008, 12:47 PM
Johnyakimo1855
Gunk foamy engine brite and a high psi pressure washer. Make sure you drain the oil and refill to keep water from piercing through the gaskets. I would make sure I at least change the valve cover gaskets though. As far as paint. How far you wanting to go as far as time and money....
Johnyakimo1855 is offline
post #18 of 73 Old 08-08-2008, 02:10 PM
bigjoe
1977 CJ7
Originally Posted by sail78385 View Post
Also got a note from my neighbors, Ive been toying with the idea of putting christmas lights and flowers in the Jeep to make them a little more appealing!
Love em or hate em
Gotta love some neighbors. From the pics you posted looks to me you keep it pretty clean. You should post a note stating "when you pay my taxes then you can do what you'd like over here." But then again get even not mad. Had a neighbor once ask my wife to have me not work all night on my cars. So I try not to work late anymore. BUT everytime I get a fire call for my fire dept. in the wee hours before dawn I always fire up my PU's V8 and am sure to race the engine a few seconds longer to let them know I'm off to help someone.
bigjoe is offline
post #19 of 73 Old 08-08-2008, 04:39 PM Thread Starter
sail78385
Question of the year! Im goin to try my hardest to get the Jeep done by May. I finish college in December and hope to have it done before I walk in May so I can show all of my buddies. As far as money is concerned I figure that around $6000 will about wrap things up. I would like to have 35-38's on it, beadlocks (hopefully I can put beadlocks on the factory alloy wheels off of the waggy), mastercraft seats, full roll cage, Re-paint to Blue, lockers, and a 21 gallon fuel tank.
I finally got the engine pulled and started the cleaning process. Im gonna remove the body and re-paint the bottom of the tub beacue the paint is peeling. Also Im painting the frame glossy blue. Once I wrap that up Ill run the stainless brake and fuel lines.
I really hope yall are enjoying my build.
post #20 of 73 Old 08-09-2008, 08:40 PM Thread Starter
sail78385
So heres what Ive gotten accomplished in the last 2 days.
Waggy ready for the pull
Had to cut a whole to get the transfer case off
Finally got it out
I also cut of the homemade 350 mounts off the CJ frame and started painting the frame and getting ready for the drop. All I need to do now is get the 360 mounts in after a little drilling. I should be cleaning the engine up tomorrow and getting the waggy ready for the front axle pull.
post #21 of 73 Old 08-10-2008, 07:20 PM Thread Starter
sail78385
Well I went to drop the engine in the frame today that I finished painting and quickly realized that I dont have the correct mounts. Also I went to run the hard brake lines and stoped because I havent gotten my Proportioning valve yet. So looks like it will be a couple of days until I get things rolling again.
post #22 of 73 Old 08-12-2008, 06:52 PM Thread Starter
sail78385
I sacraficed a good original CJ hood to the jeep gods today. Ended up cutting off 6 1/2 inches and got it ready to be welded onto the commando hood. Looks like it should be done by the end of the week. There is going to be alot of body work! Im also thinking about spraying the frame black. I just think that a blue frame could be a bad thing -Any suggestions? Also installed a soild differential cover on the rear and ran brake lines to the rear. Just waiting on the proportioning valve and motor mounts horns to come in.
Im thinking about naming this car the Command-J7 -anyone else got something better ?
post #23 of 73 Old 08-21-2008, 07:25 PM Thread Starter
sail78385
Well I got the motor and transmission in and im at a stand still right now. The skid plate for the trans that came with my 86 is definatley out of an older CJ, looks like the one in my 79. Did these change so much that you cant use the older one on an 86 frame?? Ive got the 727 auto trans from the waggy in there maybe its the mount on the trans itself that I need to change? Anyone got any suggestion? Do I need the newer style skid plate or a custom one?
post #24 of 73 Old 08-22-2008, 03:39 PM Thread Starter
sail78385
anyone have some tips for me?
post #25 of 73 Old 10-21-2008, 09:53 PM
illinicj
1979 CJ7
How is this coming along?
illinicj is offline
post #26 of 73 Old 10-22-2008, 12:11 AM Thread Starter
sail78385
Well its coming. I dont know if I mentioned this but I go to a military college: The Citadel. Im pretty much stuck here until I graduate this semester. But I have gotten the frame painted black and dropped the 360 motor in. The hood, which I made from a commando hood + a CJ7 hood needs about 2 more hours of work, you will never be able to tell it was made from two. I ordered a Lokar shifter for the 727 transmission and went to install it this past weekend but bad weather prevented it. I went and put the Dana 44 cover on the rear and then quickly noticed that oil was leaking out of the back. So I may end up putting the wagoneer dana 44 front and model 20 in the rear. After all everything was functional on these when I pulled them. I need to get a buddy over to help me put the tub back on and then it will start looking like a vehicle again. Im praying for an Atlas transfer case or ill flip a dana 300 and twin stick it. I like the ease of having the controls next to me. Then Ill block sand the entire tub, order new fenders and a windshied and paint it. At the same time Ill have the bottom of the motor rebuilt and put edlebrock aluminum heads and preformer intake with a 650 cfm carb -I like keeping things simple. Also Ill have the transmission examined and replace the flex plate, new seals everywhere and have the breather hole moved on top of the trans and a breather line ran. I should have things rolling again in December. Ill post pictures then.
post #27 of 73 Old 10-22-2008, 09:03 AM
JoonHoss
2011 JK Wrangler
definitely paint the frame black, you'll be glad you did in the long run...
and as a Commando fan, I can't wait to see the finished product; Keep up the good work!
Hoss
"Gimme three gallons of low lead; two hot dogs and a strawberry soda..."JGW
JoonHoss is online now
post #28 of 73 Old 02-21-2009, 07:19 PM Thread Starter
sail78385
I finally got to this point, I still need more work but Im proud of the out come so far.
post #29 of 73 Old 02-21-2009, 07:33 PM Thread Starter
sail78385
Once I get the transmission mount fabbed up I can roll it around again, also I need to install the model 20 transfer case. Does anyone know if this is a direct bolt on to the 727 transmission that had the NP transfer case mounted behind it?
post #30 of 73 Old 02-21-2009, 09:35 PM
mjfitz99
Technically I can't help with your questions, but I think that you have done some really nice work. I am not sure how I missed your thread. Keep it up.
mjfitz99 is offline
Building a cj7 tub out of the available panels ttownjeep Jeep CJ Forum 2 09-18-2009 10:08 PM
Building a new harness happylilshroom Jeep CJ Forum 1 08-19-2009 09:02 PM
building a 360 Arcticcat843 Jeep CJ Forum 7 09-13-2008 12:22 PM
Building a 360? xulcuz Jeep CJ Forum 14 08-09-2008 06:19 PM
building a CJ7 mudding Jeep CJ Forum 3 03-14-2003 12:36 PM
