BUILD THREAD: Project "Ghetto Fabulous" - Page 47 - JeepForum.com
post #691 of 805 Old 03-05-2014, 06:27 PM Thread Starter
motiv8ya
1979 CJ7
Originally Posted by cjjon7 View Post
Ah bummer. The old seal has been trained for the groove in your old yoke ill bet...you replaced the yokes correct?
Yep, I have a new seal to put in there. I also found a part# for a VDO Temp Switch (vdo 232-011-005-019D E) that will work for my fan relays. Now I just gotta find a place that sells it.
motiv8ya is offline
post #692 of 805 Old 03-06-2014, 02:58 PM
243
1978 FSJ Cherokee
You have made a ton of progress since I last looked, very nice.
Every time I look at a build I say "I should have done it like that"
243 is offline
post #693 of 805 Old 03-06-2014, 04:12 PM Thread Starter
motiv8ya
1979 CJ7
Thank you! I followed yours too and your work is impressive. Very detailed and clean.
It's been a long road for this project but the end is near. I definitely had my share of would've - should've - could'ves over the past five years. Right now I'm thinking I should've replaced the Dana300 front yoke seal when I swapped the yokes the other day .
motiv8ya is offline
post #694 of 805 Old 03-07-2014, 10:17 PM Thread Starter
motiv8ya
1979 CJ7
http://s487.photobucket.com/user/mot..._5770.mp4.html
I finally got the video to upload, just had to do it from my laptop.
motiv8ya is offline
post #695 of 805 Old 03-07-2014, 10:23 PM
cjjon7
1983 CJ7
What type of coolant bottle are you using? Sounds like the exhaust is popping a little
cjjon7 is offline
post #696 of 805 Old 03-07-2014, 10:50 PM Thread Starter
motiv8ya
1979 CJ7
The coolant bottle was a universal kit I picked up at O'Reilly's. The exhaust popping stopped after the initial high idle lowered a bit.
motiv8ya is offline
post #697 of 805 Old 03-09-2014, 03:25 PM Thread Starter
motiv8ya
1979 CJ7
Reset the timing to 10* and the exhaust popping went away. It idles smoother now too. Replaced the front output oil seal also and that leak stopped.
motiv8ya is offline
post #698 of 805 Old 03-11-2014, 06:44 PM Thread Starter
motiv8ya
1979 CJ7
Removed the brass 'T' and installed the TBI coolant sensor in the right front port. I bent the terminal on the thermal switch and it cleared the intake when installed in the back of the T-Stat. Fans work when I tested it and it doesn't leak. Hope to drive it tomorrow!
motiv8ya is offline
post #699 of 805 Old 03-14-2014, 03:04 PM Thread Starter
motiv8ya
1979 CJ7
So much for that!
I got all ready to drive it today and it just grinds when I try to put it into reverse. It won't shift into a forward gear with the engine running either. The transmission shifts fine without the engine running but not when it's running and the clutch is engaged. Scratching my head!?!?
motiv8ya is offline
post #700 of 805 Old 03-14-2014, 03:11 PM
cjjon7
1983 CJ7
You probably need to adjust your clutch linkage. Try setting it a little deeper so that full deflection of the clutch pedal pushes it more than it currently is. It sounds to me like the transmission doesn't have the ability to slow down before you try shifting.
cjjon7 is offline
post #701 of 805 Old 03-14-2014, 03:25 PM Thread Starter
motiv8ya
1979 CJ7
So add more slack into it?
motiv8ya is offline
post #702 of 805 Old 03-14-2014, 03:32 PM
cjjon7
1983 CJ7
No, remove slack. There should be 1/8" or so of preload on the clutch fork when sitting (not stepping on the clutch). Basically you want the clutch to open further when you step on the pedal, but not so far that it slips when you release the pedal. It will take a little playing with but once you find the sweet spot, youll know.
cjjon7 is offline
post #703 of 805 Old 03-14-2014, 03:36 PM Thread Starter
motiv8ya
1979 CJ7
Ok, thanks. I'll report back
motiv8ya is offline
post #704 of 805 Old 03-14-2014, 03:40 PM
cjjon7
1983 CJ7
Good luck! Everyone finishing their builds are really motivating me to hurry my *** up and finish mine!
cjjon7 is offline
post #705 of 805 Old 03-14-2014, 04:49 PM Thread Starter
motiv8ya
1979 CJ7
Looks like I need a longer threaded rod to make more space between the zbar and the clutch fork. I adjusted this all the way out (I didn't know it was that far out) and the trans finally went into reverse (but still grinded) then stalled the engine. I tried to adjust it further but it dropped out ontop me, that's when I realized I went to far. Can I use a piece of all thread for this or is it some special part?
motiv8ya is offline
"Old Sarge" CJ7 Build Thread cj7Sswampers Jeep CJ Forum 30 07-03-2014 07:12 AM
1979 CJ7 Build - "Project TRex" TRex Jeep CJ Forum 196 05-11-2014 08:02 AM
1985 "Special Edition" CJ7 Restoration Build Thread elliottferrell Jeep CJ Forum 38 07-23-2012 10:09 AM
a "whats it worth" thread (for a project) Jeepfreak81 Jeep CJ Forum 9 09-23-2009 07:26 PM
Project "Build Take 2" Hybrid AWD Jeep CJ Forum 20 04-28-2009 01:23 PM
