BUILD THREAD: Project "Ghetto Fabulous" - Page 45 - JeepForum.com
post #661 of 805 Old 02-22-2014, 10:20 PM Thread Starter
motiv8ya
1979 CJ7
Originally Posted by twinstickd20
Okay are the injectors getting power and pulsing? Trying to think through my 92 chevy truck with tbi.
I have to wait until tomorrow to test it. I don't have another hand to turn the key right now while I check the injectors. I didn't hear any sound coming from or see any fuel spraying from the injectors when I had my wife turning the key earlier today.
According to the Painless instructions it says to use pink wire #720 (coil +) to power the ECM and the HEI. I have it hooked up according to those instructions. I sent an email to Howell and Painless to seek further info also. I'll confirm the ground for the TBI harness too.
Edit: I just read on some old post from another forum about connecting the ECM fuse block directly to the battery with some sort of toggle switch in between. I can try this tomorrow also. (Kids are asleep and their rooms are over the garage = no Jeep time)
motiv8ya is offline
post #662 of 805 Old 02-23-2014, 01:14 PM Thread Starter
motiv8ya
1979 CJ7
I just ran a single wire from a 12v power distribution block off the battery directly to the ECM Fuse block and also swapped batteries with the one in my other CJ. Same result, still not starting. Starter is lugging then stopping. Gonna see if I have a spare on my shelf.
motiv8ya is offline
post #663 of 805 Old 02-23-2014, 01:36 PM Thread Starter
motiv8ya
1979 CJ7
Swapped starters and turned the key, the new(old) starter cranked alot better than the one that was in there. Now I have backfire through the TBI?!? Does that mean I have the Dizzy 180* out?
motiv8ya is offline
post #664 of 805 Old 02-23-2014, 03:16 PM
cjjon7
1983 CJ7
Is it even trying to start? you either have it 180 degrees out or the timing is just way advanced
cjjon7 is offline
post #665 of 805 Old 02-23-2014, 04:07 PM Thread Starter
motiv8ya
1979 CJ7
I removed the #1 spark plug and used my compression gauge to help with finding TDC compression stroke while I was hand cranking the engine. This is where the rotor wound up on the compression stroke, looks like 180* out. I removed the HEI and all the plug wires and reinstalled. Hoping this is it.
motiv8ya is offline
post #666 of 805 Old 02-23-2014, 04:12 PM
cjjon7
1983 CJ7
That actually looks pretty close I just looked on my 360 and the number one plug wire is about 1 hour clock wise of were yours is
cjjon7 is offline
post #667 of 805 Old 02-23-2014, 05:00 PM Thread Starter
motiv8ya
1979 CJ7
That did the trick, it started up but I only have the passenger side injector spraying fuel. Also, the canister on the HEI is dangerously close to my PS belts. My fans never kicked on during the break in so I had some boil over, trying to fix that now so I can restart, time it properly and figure out the non spraying injector issue. The Throttle body whistles like crazy, is that normal for TBI, its really loud under the hood. Exhaust sounds great!
motiv8ya is offline
post #668 of 805 Old 02-23-2014, 05:52 PM Thread Starter
motiv8ya
1979 CJ7
Fixed a bad relay and broken wire for my e-fans (junkyard parts) and they both work now. Also, both injectors are now spraying but it's flooding during cranking now. Fuel is pouring out below the throttle linkage.
I restabbed the HEI over one tooth and it gave me plenty of clearance with the canister. Rotor is in the same spot as it was when I removed it (when it ran). What should the timing be set at with the HEI and the TBI?
motiv8ya is offline
post #669 of 805 Old 02-24-2014, 01:19 PM Thread Starter
motiv8ya
1979 CJ7
I fixed the injector issue, the ground wire was loose. I pulled all of the plugs and hand cranked the engine to push excess fuel out and the #7 cyl had quite a bit in there which leaked out onto the floor. I left the plugs out for a while to evaporate the rest of the excess fuel. Now I'm concerned about having fuel in my oil pan. The dipstick smells like fuel.
The HEI is reinstalled and rotor pointing at #1. #1 cyl is on TDC on compression stroke. I need to top off my coolant and I'm thinking oil change.
motiv8ya is offline
post #670 of 805 Old 02-24-2014, 02:29 PM
twinstickd20
1979 CJ7
Definitely do an oil change, not worth risking damage.
My Build Thread
twinstickd20 is offline
post #671 of 805 Old 02-25-2014, 01:45 AM Thread Starter
motiv8ya
1979 CJ7
Will do but its gonna have to wait a few days now. I plan on changing the oil/filter and then priming it a few times each day until I can spend some more time on it again. Would it hurt to put a squirt of oil in each of the cylinders incase those rings are washed out from the gas?
motiv8ya is offline
post #672 of 805 Old 02-26-2014, 01:01 PM Thread Starter
motiv8ya
1979 CJ7
Just drained the oil. There was alot more fuel in there than I expected. I'll spend the next couple of days priming it a couple times to push the new oil through the system and get everything as lubricated as possible. Should I squirt some oil in each cylinder?
motiv8ya is offline
post #673 of 805 Old 02-26-2014, 04:30 PM
Coiz
1979 CJ7
You could. It would help with initial compression build up but could also potentially foul your spark plugs. You would probably fine either way.
Mike
Coiz is offline
post #674 of 805 Old 02-26-2014, 05:56 PM Thread Starter
motiv8ya
1979 CJ7
I couldn't wait, I primed it about 5 times for several minutes each today and put a tiny bit of oil in each cylinder and let it sit for a few minutes. Turned the key and it fired right up!!!!! Set the timing from 0* TDC to 12* while it was running. The PS pump started squealing due to low fluid so I shut it down (probably shouldn't have) and topped off the PS system (it was very low). Went to start it again and now it won't turn over. The starter kicks in but lugs once or twice and quits. I got called out for work so the Jeep has to wait.
It sounded great while it lasted!
motiv8ya is offline
post #675 of 805 Old 02-26-2014, 07:56 PM
cjjon7
1983 CJ7
Sounds like you alternator might not be putting out, had the same issue when i first ran mine, it was just firing off the battery and didnt want to start after running for a bit
cjjon7 is offline
"Old Sarge" CJ7 Build Thread cj7Sswampers Jeep CJ Forum 30 07-03-2014 07:12 AM
1979 CJ7 Build - "Project TRex" TRex Jeep CJ Forum 196 05-11-2014 08:02 AM
1985 "Special Edition" CJ7 Restoration Build Thread elliottferrell Jeep CJ Forum 38 07-23-2012 10:09 AM
a "whats it worth" thread (for a project) Jeepfreak81 Jeep CJ Forum 9 09-23-2009 07:26 PM
Project "Build Take 2" Hybrid AWD Jeep CJ Forum 20 04-28-2009 01:23 PM
