BUILD THREAD: Project "Ghetto Fabulous" - Page 40 - JeepForum.com
post #586 of 800 Old 08-27-2013, 05:46 PM Thread Starter
motiv8ya
1979 CJ7
I picked up the other style crossmember today from a stock 80' cj7 with and auto/dana300 combo. It came with some weird looking 'w' shaped mount between the trans and trans/torque arm mount. It looked like it would work perfectly to raise the trans so I could use the crossmember I made. I spent some time degreasing, sandblasting and welding (it was cracked). All that and it doesn't work.
So I got busy degreasing the crossmember. It still needs to get stripped with the grinder and painted. Thought I was done with all of the dirty work. It'll have to wait until tomorrow.
I ordered my new chip from Howell today also.
One thing that has bugged me is the the dirt on the used tires I bought that I couldn't get off. Nothing that I used got them clean. So I sprayed them with simple green and hit them with a red scotch brite pad. Here's the difference it made in about 1 minute per tire. I'm happy now.
motiv8ya is offline
post #587 of 800 Old 08-29-2013, 12:36 PM Thread Starter
motiv8ya
1979 CJ7
Crossmember didn't bolt right up so I elongated six of the holes to get it on the frame. The bolt holes for the trans mount and torque arm didn't line up either so I'm working on a piece of 3/8 plate to put in between the crossmember and trans mount. The plate with spacers will bolt to the crossmember with some existing holes and new holes. Then I will redrill the plate for the trans mount. Pics were too large to upload.
motiv8ya is offline
post #588 of 800 Old 08-29-2013, 04:53 PM
243
1978 FSJ Cherokee
Oh yeah, try Simple Green on those dirty tires
Dave's 78 Build
243 is offline
post #589 of 800 Old 08-29-2013, 06:38 PM Thread Starter
motiv8ya
1979 CJ7
Ok, trans and crossmember saga is finished. Here is what I ended up with....moving on.
I'm thinking of upgrading the strap style yokes to the 1310 u-joint ubolt style yokes. Plenty of kits on ebay right now.
Speedo cable and injectors just showed up so I'm gonna go start on that.
motiv8ya is offline
post #590 of 800 Old 08-30-2013, 02:36 PM Thread Starter
motiv8ya
1979 CJ7
Injectors are swapped in and the TBI is mounted up. I had to drill another hole in the firewall to pass the speedo cable / grommet through. You can see it in this pic.
UPS just dropped off the shocks, that leaves:
1. Spark plug wires
2. Exhaust
3. Connect MAP Sensor
4. Air filter / TBI intake and hoses
5. Throttle cable
6. Driveshafts and yoke conversion
7. Change chip in computer with new Howell chip
8. Confirm TDC on #1 Cyl
9. Prime engine oil
10. Install battery
11. Double check everything
12. Stage the fire extinguisher (just in case)
13. Engine break in
14. Seatbelts
motiv8ya is offline
post #591 of 800 Old 09-02-2013, 04:23 PM Thread Starter
motiv8ya
1979 CJ7
Shocks are mounted. The fronts are a little too long with only 4 inches of up-travel but that will be corrected when I swap out the flat front springs to level out the Jeep. The front of the Jeep sits too low compared to the rear so I will eventually refurb my old front (4") springs from the 79' and install them.
I like the way the brake lines tuck in when I turn the wheels keeping them out of the way.
Fuel lines are connected to the TBI. I can't remember which injector plug goes where (blue to the left / green to the right or vice versa). I'll look for a picture online and try to match it up. Can't seem to find my howell instructions at the moment.
New backup light transmission switch is installed also, now I need to run the wires to it.
Anyone know what spark plug wire set to use on the HEI to amc v8 swap?
Edit: Google is my friend, MSD Wire Set #35859 is on its way.
motiv8ya is offline
post #592 of 800 Old 09-02-2013, 07:23 PM Thread Starter
motiv8ya
1979 CJ7
I found a couple of pics online and it looks like the injector plug with the blue wire goes on the left side of the engine and the green one goes on the right.
motiv8ya is offline
post #593 of 800 Old 09-15-2013, 07:52 PM Thread Starter
motiv8ya
1979 CJ7
I was out of town for a few days and I came home to some boxes that got delivered. Mirrors, spark plug wires, throttle cable and my new Howell chip for the 401. Everything got put on but I needed to modify my already modified throttle cable bracket. I needed to shorten and flip the mounting tab. So cut/grind/weld and paint. It's ugly but it works.
motiv8ya is offline
post #594 of 800 Old 09-16-2013, 02:02 PM Thread Starter
motiv8ya
1979 CJ7
I installed some new plugs gapped at .045 along with the wires. I used MSD wires made for the AMC V8 with HEI swap. The part# is in the pic below. While hand starting the plug in the #4 cyl it started to bind so I backed it out and saw that it was chipped, see pic. I assumed the chipped piece fell in the cylinder because it wasn't on the floor or in the box. I scoped it and the cylinder is clear of debris....that was stressful!
motiv8ya is offline
post #595 of 800 Old 09-16-2013, 04:34 PM
cjjon7
1983 CJ7
Whew you absolutely sure its not in there? Did you pull the head or just look through the hole? Maybe stick an air nozzle in the plug hole, give a shot, look, give a shot, look etc until youre 100% sure. Dont want that screwing you up!
cjjon7 is offline
post #596 of 800 Old 09-16-2013, 05:50 PM Thread Starter
motiv8ya
1979 CJ7
Yeah, I scoped it with this (see pic). I will give it another look just to be absolutely sure it didn't land high on the cylinder wall and get stuck. The scope is so clear I can read the part# on the piston. I need to get some wire separators because my plug wires always look sloppy.
motiv8ya is offline
post #597 of 800 Old 09-16-2013, 07:19 PM
cjjon7
1983 CJ7
Oh very cool. handy tool to have around the shop!
cjjon7 is offline
post #598 of 800 Old 09-16-2013, 07:59 PM Thread Starter
motiv8ya
1979 CJ7
The scope definitely helped me today. It's still going to drive me crazy until I find that broken piece though.
motiv8ya is offline
post #599 of 800 Old 09-18-2013, 04:59 PM Thread Starter
motiv8ya
1979 CJ7
I gave it one more shot today. I pulled the #4 plug again and blew out the cylinder then scoped it again. It's clear, now I can sleep easier.
motiv8ya is offline
post #600 of 800 Old 09-19-2013, 05:18 PM Thread Starter
motiv8ya
1979 CJ7
I installed the seatbelts using some left over pieces of a chopped up seat frame to make risers for the latch side mount. Here's how they came out. I'm thinking I will reroute the lap portion of the belts through the slot in the seat's side bolster before it attaches to the floor. That should keep it from flapping in the wind when not in use on the passenger side.
motiv8ya is offline
"Old Sarge" CJ7 Build Thread cj7Sswampers Jeep CJ Forum 30 07-03-2014 06:12 AM
1979 CJ7 Build - "Project TRex" TRex Jeep CJ Forum 196 05-11-2014 07:02 AM
1985 "Special Edition" CJ7 Restoration Build Thread elliottferrell Jeep CJ Forum 38 07-23-2012 09:09 AM
a "whats it worth" thread (for a project) Jeepfreak81 Jeep CJ Forum 9 09-23-2009 06:26 PM
Project "Build Take 2" Hybrid AWD Jeep CJ Forum 20 04-28-2009 12:23 PM
