BUILD THREAD: Project "Ghetto Fabulous" - Page 39 - JeepForum.com
post #571 of 800 Old 08-23-2013, 08:15 PM Thread Starter
motiv8ya
1979 CJ7
I unbolted the trans mount and raised it up to try and get better angles for the driveshafts. This is the area that confuses me, I know the rear axle pinion should be 2 - 3* less than the transfer case rear output to account for the rise under load. The rear axle pinion is pointing up at 15*. Not sure where to set the transfer case rear output. The difference in height between the two yokes is 10.5" and distance is 27". Is the total number of the three angles supposed to add to 180*?
On my other Jeep I had to run a rear CV Shaft and raise my transfer case rear output to near 90*. It still has some minor vibrations at highway speeds and took some shims to adjust the rear axle pinion properly. Trying to avoid all the adjustments.
If I go with a rear CV shaft on this build and put the transfer case rear output at 90* I would have to raise it a full 2". So I tried it and set a piece of 2x2 as a spacer and it leveled out the engine perfectly. It also added an inch to the rear shaft length (28") and corrected the transfer case front output angle downward (was pointing up towards radiator). I gained a ton of clearance. It looks 'right' this way. Anybody got some skills in this area that can help me out?
If this is how it should be run then I built that crossmember for nothing, there is a ton of space between the transfer case and the crossmember now. I guess I'll search CL for a stock one.
I ordered larger injectors for the TBI and have to call Howell on Tuesday to order a new cal-prom.
Only thing left to wire in is the back up light switch and back up lights, which reminds me...I need a backup light switch, some backup lights and a rear bumper / carrier to mount them on.
motiv8ya is offline
post #572 of 800 Old 08-24-2013, 11:37 PM Thread Starter
motiv8ya
1979 CJ7
Raising the trans corrected the 1 - 2" travel loss in my clutch pedal but I had to drill two new holes in the firewall mounted z-bar bracket to get it level again. I plan on leaving the trans at this height and seeing if my old crossmember will work now that everything seems to be falling into place. I'm off for another week and the kids go back to school on monday so I should get plenty of Jeep time.
motiv8ya is offline
post #573 of 800 Old 08-25-2013, 11:32 AM
cjjon7
1983 CJ7
That sounds about right, you want your transfer case yoke parallel with the floor when using a CV driveshaft, or close to it. I had to do the same thing with my trans mount beneath the TF727... still need to order the driveshaft, and yeah im running the stock skidplate as well.
cjjon7 is offline
post #574 of 800 Old 08-25-2013, 01:01 PM Thread Starter
motiv8ya
1979 CJ7
Good info, thanks. I found a trans crossmember for the dana300 on CL incase my stock one doesn't work.
motiv8ya is offline
post #575 of 800 Old 08-25-2013, 03:29 PM Thread Starter
motiv8ya
1979 CJ7
I bolted up the stock 76-79' crossmember and believe it or not 4 of the bolt holes lined up and it went in smoothly without any interference with the bottom of the dana 300. I will need the crossmember from the dana 300 set up though because the transmission mounts are at different positions and these don't line up. The one I found is from an 80' CJ7 with a 6cyl and auto/dana 300. Hope it works.
motiv8ya is offline
post #576 of 800 Old 08-25-2013, 08:25 PM Thread Starter
motiv8ya
1979 CJ7
I pulled the sway bar off until I figure out what to do to solve the clearance issues with the brake lines on the upwards travel. Shocks are ordered.
motiv8ya is offline
post #577 of 800 Old 08-26-2013, 11:24 AM
cjjon7
1983 CJ7
What shocks you go with??
cjjon7 is offline
post #578 of 800 Old 08-26-2013, 12:11 PM Thread Starter
motiv8ya
1979 CJ7
Doestch DT3000
motiv8ya is offline
post #579 of 800 Old 08-26-2013, 12:25 PM
cjjon7
1983 CJ7
Nice I've heard good things and they don't break the bank!
cjjon7 is offline
post #580 of 800 Old 08-26-2013, 04:17 PM Thread Starter
motiv8ya
1979 CJ7
Did my good deed for the day, I pulled a hyundai out of a ditch with the 79'.
I went to have one of the Flowmasters installed on the 79' but it was a no-go. I bought (2) 2.5" Flowmasters and the 79' has 2.25 exhaust tubing. Maybe I'll just do dual exhaust on the project now that I have the extra muffler. That will eliminate the cost of having a Y-pipe made and make it easier to work on stuff without having to remove exhaust pipes to get to stuff.
I should have my crossmember tomorrow so that means more stripping and painting. I'm anxious to get this thing done already.
motiv8ya is offline
post #581 of 800 Old 08-26-2013, 06:15 PM
cjjon7
1983 CJ7
UGH youre telling me! I tallied up everything I have left to do the other day and the total scared me... Its at the point where fabrication is out of the picture without buying expensive tools, so buying or paying to have made is the only option.
How have you liked the metalcloak fenders thus far, liners fit nice? Clean and easy install? (should be for 500$!)
Cant wait to finally drive my CJ again someday
cjjon7 is offline
post #582 of 800 Old 08-26-2013, 07:14 PM Thread Starter
motiv8ya
1979 CJ7
The Metalcloaks are well worth the money spent. Heavy duty construction, perfect fit, beautiful 'new' aluminum inners and all the required hardware.
motiv8ya is offline
post #583 of 800 Old 08-26-2013, 08:09 PM
Jim1611
Jim1611's Avatar
Bill (Lucdog) tells me he doesn't run a sway bar on his CJ and has never felt he needed it. Maybe just take it off?
Jim1611 is offline
post #584 of 800 Old 08-26-2013, 09:20 PM Thread Starter
motiv8ya
1979 CJ7
I pulled it off but the springs are so soft that unless these new shocks compensate for them I will have to shorten the link bars or just relocate/rotate the brake lines above the axle before I reinstall the swaybar. The lift springs on my 79' are so stiff that I don't run the sway bar on it and it can't even tell the difference.
motiv8ya is offline
post #585 of 800 Old 08-27-2013, 08:23 AM
Jim1611
Jim1611's Avatar
I could see that happening. If you're going to shorten them maybe it'd be a good time to make them quick detachable too.
Jim1611 is offline
"Old Sarge" CJ7 Build Thread cj7Sswampers Jeep CJ Forum 30 07-03-2014 07:12 AM
1979 CJ7 Build - "Project TRex" TRex Jeep CJ Forum 196 05-11-2014 08:02 AM
1985 "Special Edition" CJ7 Restoration Build Thread elliottferrell Jeep CJ Forum 38 07-23-2012 10:09 AM
a "whats it worth" thread (for a project) Jeepfreak81 Jeep CJ Forum 9 09-23-2009 07:26 PM
Project "Build Take 2" Hybrid AWD Jeep CJ Forum 20 04-28-2009 01:23 PM
