BUILD THREAD: Project "Ghetto Fabulous" - Page 38 - JeepForum.com
post #556 of 805 Old 08-14-2013, 07:55 PM Thread Starter
motiv8ya
1979 CJ7
Originally Posted by cjjon7
Man that paint looks so slick, cant believe its a rattle can job. I hope it stays that way for awhile for you and doesnt stain, thats the only thing keeping me from a job like that. Lines look real clean!
Thanks, it will collect dirt and the first greasy hand print I put on it because of the gritty texture but that's another reason why I painted it dirt color. I think it will hold up ok out here in the desert. Not so sure I would do it again if i was back on the east coast though due to the constant humidity where you can actually watch your jeep rust in front of you. My test panel has been sitting outside since I initially sprayed it and still has not rusted.
I'm seeing the light at the end of the tunnel. I have to figure out a way to get the jeep down to the exhaust shop so I can knock that project out.
I can just give the driveshaft shop measurements and have those made but I also want to swap out all of my yokes from the 'strap' style to something stronger also.
motiv8ya is offline
post #557 of 805 Old 08-14-2013, 08:51 PM Thread Starter
motiv8ya
1979 CJ7
Rear shaft needs to be 27" and the front 31 3/16". The rear xfercase output is at a 6* drop and the rear axle yoke is at 10* rise. Hope that is workable.
Edit: just so I don't forget
motiv8ya is offline
post #558 of 805 Old 08-14-2013, 09:20 PM Thread Starter
motiv8ya
1979 CJ7
The spare 80' CJ7 harness I have has a six slot/five wire plug. File/pic is to big to upload.
A-pink
B-white
C-green
D-green w/grey tracer
E-white w/black tracer
F- open
Both white wires run to the fuse panel, both green wires run to the plug on the steering column, the pink one has a push on connector at the other end. I dissected the harness and pulled it out with all the original terminals. Research time, thanks for the info yellow85cj
motiv8ya is offline
post #559 of 805 Old 08-20-2013, 05:37 PM Thread Starter
motiv8ya
1979 CJ7
No work on the build this weekend but I did swap out the 'probe in the radiator' type e-fan switch for a 195* thermo switch in the back of the thermostat housing today. It grounds out at 195* and kicks on the contour fans relays then opens back up around 175* so it should keep the engine operating temp right in between. Tested everything and it works great.
The probe style switch I had in there was inconsistent. Sometimes it turned on the fans at startup when the engine was 'cold' and sometimes the probe was found hanging out of the radiator. The new switch reads directly from the coolant stream as it passes through the 160* thermostat.
The plug that was in the back of the thermostat housing had a 5/16th square recess. I was expecting a hex/allen key like I encountered on the build and of course I didn't have a 5/16th square adapter for anything. So... I ground down the lug on an old Harbor Freight 3/8 socket wrench to 5/16 and off it came. Took longer to do that part of the job than the install, wiring and testing of the new switch.
motiv8ya is offline
post #560 of 805 Old 08-20-2013, 05:47 PM
cjjon7
1983 CJ7
What part number is the switch you bought? I got one from AZ but don't really like it because its a stud rather than blade like yours
cjjon7 is offline
post #561 of 805 Old 08-20-2013, 07:03 PM Thread Starter
motiv8ya
1979 CJ7
Maradyne MFA109. It fits in the coolant ports on the intake and also in the back of the thermostat housing.
Its wired 12v power to a dash switch then to the relays and ends at the therm switch. The fans are powered directly from the battery with separate relays which are activated when the therm switch goes to ground.
motiv8ya is offline
post #562 of 805 Old 08-20-2013, 07:27 PM
cjjon7
1983 CJ7
Great, thanks. That'll work better than the one I got. Kinda worried about my relays as they're only 40a each...though each relay is for only one fan, and single speed. You find a source for 70amp relays?
cjjon7 is offline
post #563 of 805 Old 08-20-2013, 08:17 PM
243
1978 FSJ Cherokee
I had the same brackets on my e-pump bolted to the frame, it was so dang loud I took the brackets off and let the pump hand from the fuel hose.
Dave's 78 Build
243 is offline
post #564 of 805 Old 08-20-2013, 11:12 PM Thread Starter
motiv8ya
1979 CJ7
The relays are Bosch from a late 90's caddy that I pulled from the JY. There's three on one bracket so I pull the whole bracket and cut the harness about a foot down and take all three ($1 each). Read about them in a Jeephammer post a while ago so I grab some every time I go. I forgot to mention that I use a 6 terminal power distribution block from the battery before the relays so each relay/fan has it's own fuse. There should be a video of the wire routing somewhere in the middle of the build thread when I did the contour fans on the 79'.
motiv8ya is offline
post #565 of 805 Old 08-20-2013, 11:17 PM Thread Starter
motiv8ya
1979 CJ7
That's what I'm worried about. The single bracket that came with the howell kit didn't even hold the fuel pump tight. I'm thinking of cutting a strip of stall mat (1" thick rubber) and using two exhaust ubolts to hold the pump in place (body, rubber, pump, u-bracket), i just don't want to drill anymore holes in the body though. We'll see what I come up with. My holley red pump on my 79' isn't that loud, hope this one isn't either.
motiv8ya is offline
post #566 of 805 Old 08-21-2013, 05:01 AM
243
1978 FSJ Cherokee
I swear mine sounded like the neurotic woodpecker hammering on on my rain gutter in Houston.
I was thinking about putting a rubber matt between the pump and frame as well.
Dave's 78 Build
243 is offline
post #567 of 805 Old 08-21-2013, 02:38 PM Thread Starter
motiv8ya
1979 CJ7
Two small exhaust hanger ubolts sleeved in rubber fuel line clamping the fuel pump to the rubber mat and body is what I'm gonna try this weekend.
I tried to figure out my rear driveshaft angles using an online driveline calculator, here's what I came up with. I think I can benefit from a small spacer in the trans mount to raise the transfercase rear output and lower the front output onto a level plane. I'll have to experiment with different thicknesses of flat bar to see what gets those 6* back.
motiv8ya is offline
post #568 of 805 Old 08-22-2013, 04:06 PM Thread Starter
motiv8ya
1979 CJ7
Made an uneventful trip to the Junkyard this morning and left empty handed. Not a good Jeep selection this time around. I did come across this International Harvester pickup that kept calling my name though, looks like a great project. There is something about the style of the old internationals that I really like. Everything was there and it was definitely someones project because they had their very short to do list penciled in on the tailgate and every major component was intact.
I remounted the fuel pump with the stall mat and two 1.75" exhaust hangers. My 7 year old daughter helped on this project. She got to install the nuts inside the Jeep while I was underneath pushing the ubolts through. She had fun. Hard to believe she was two when I started this build.
I drilled through the rubber and transferred the holes to the tub. Bolted it up and its done. If this thing vibrates I'll be shocked. The stall mat was 3/4" thick, not 1" like I thought, which turned out perfect because the ubolts were just long enough to pass through and be tightened down.
motiv8ya is offline
post #569 of 805 Old 08-22-2013, 04:40 PM
twinstickd20
1979 CJ7
I've seen a 4 door international truck like that and in that color, needless to say it was sweet.
My Build Thread
twinstickd20 is offline
post #570 of 805 Old 08-23-2013, 02:48 PM Thread Starter
motiv8ya
1979 CJ7
So after thinking about this IH pickup all night I decided to call the yard today and ask their price for the whole thing........and they won't sell it. Its a damn shame because it's a really nice project and I have never seen one before. Let alone seen an old unrestored truck this complete. These are the kinds of projects I like to work on, not the dime a dozen sbc swap into anything on wheels. I like the slightly odd, not too popular rides. I even found a rebuilt IH 345 on CL for it already. Oh well.
motiv8ya is offline
"Old Sarge" CJ7 Build Thread cj7Sswampers Jeep CJ Forum 30 07-03-2014 06:12 AM
1979 CJ7 Build - "Project TRex" TRex Jeep CJ Forum 196 05-11-2014 07:02 AM
1985 "Special Edition" CJ7 Restoration Build Thread elliottferrell Jeep CJ Forum 38 07-23-2012 09:09 AM
a "whats it worth" thread (for a project) Jeepfreak81 Jeep CJ Forum 9 09-23-2009 06:26 PM
Project "Build Take 2" Hybrid AWD Jeep CJ Forum 20 04-28-2009 12:23 PM
