BUILD THREAD: Project "Ghetto Fabulous" - Page 35 - JeepForum.com
post #511 of 805 Old 07-17-2013, 07:38 PM
83vert
1982 CJ7
It was a great feeling when I got most of the parts on the jeep. It opened up a ton of space but now I keep bumping into the rear view mirrors. What's the story with your other jeep? Daily driver? V8? Etc?
I am in deep
http://www.jeepforum.com/forum/f8/how-did-happen-rebuild-1113470/
83vert is offline
post #512 of 805 Old 07-17-2013, 08:24 PM Thread Starter
motiv8ya
1979 CJ7
Daily Driver, 79' CJ7 with a 401/th400/dana20 twinstick. Currie 9's front and rear with 4.10's and detriots. Hydroboost brakes and power steering, etc.
motiv8ya is offline
post #513 of 805 Old 07-20-2013, 05:57 PM Thread Starter
motiv8ya
1979 CJ7
I picked up another windshield frame that already had some good glass for $25. Aside from the 6 stripped and broken torx bolts stuck in it, its in much better shape than my other one and will require less work and $$$$. Some pb blaster and an easy out made quick work of the torx bolts. Now I gotta strip it and paint it.
I also picked up two complete dashes and stripped them down to resell the parts. One has the entire dash wiring harness and fuse block. I needed a glovebox door and grab handle.
I primed the hood today and will pick up more paint tonight to try and have that finished and installed by tomorrow night.
motiv8ya is offline
post #514 of 805 Old 07-21-2013, 01:48 PM Thread Starter
motiv8ya
1979 CJ7
That sucks, looks like I'll be stripping and cleaning again. I used the same combo of primer and paint everywhere else with no issues. All I can think of is the humidity due to 3 days of rain here in the desert.
motiv8ya is offline
post #515 of 805 Old 07-21-2013, 02:23 PM Thread Starter
motiv8ya
1979 CJ7
Should I use this old headlight switch plug or just wire the painless kit directly to the headlight switch? First option is all butt splices and mixes old wires with new, the second cuts the # of crimps in half and uses the new wiring only.
motiv8ya is offline
post #516 of 805 Old 07-21-2013, 08:46 PM Thread Starter
motiv8ya
1979 CJ7
Well, I guess I had a bad can of primer or something because I stripped the hood down to bare metal where it peeled and 'test' painted that same section with only a wipe down with a paper towel. The paint stuck and dried nicely to the bare metal. The overspray that landed on the remaining primed section peeled again. I'm gonna strip the whole thing again and give it another shot with a different primer. Just weird because I used the same primer on the tub, cage, tailgate and fenders without any problems.
motiv8ya is offline
post #517 of 805 Old 07-22-2013, 09:16 AM
83vert
1982 CJ7
I used my original harness but this pic should help. It's one of Jon Strenks
I am in deep
83vert is offline
post #518 of 805 Old 07-22-2013, 09:20 AM
83vert
1982 CJ7
I am assuming the wires for the headlight switch are labeled from painless?
I am in deep
83vert is offline
post #519 of 805 Old 07-22-2013, 01:10 PM Thread Starter
motiv8ya
1979 CJ7
Thanks, that's one of the pictures I found in a headlight switch thread on my search. The universal painless wires are labelled however they are different in color and number from what is in the original plug. Painless manual shows connections using a GM headlight switch (looks like the terminals are different in quantity and orientation), not the Jeep switch. I have an original jeep headlight switch plug with the 5 wires sticking out but I have 6 wires from the new harness to hookup. I'm not sure if the individual front and rear parking light wires (painless color = brown) are to be splice together onto one of the terminals or if they connect separately. I'll send an email to painless. Thanks again.
motiv8ya is offline
post #520 of 805 Old 07-25-2013, 01:04 PM Thread Starter
motiv8ya
1979 CJ7
Delete post
motiv8ya is offline
post #521 of 805 Old 07-29-2013, 07:10 PM Thread Starter
motiv8ya
1979 CJ7
All that's left to wire is a few gauges on the dash. I made a fill panel for the factory speedo hole to mount the smaller aftermarket speedo and a few lights in. I put the left and right turn signal indicators, a high beam indicator and my idiot light (tbi) in there. I'm trying to keep the wiring under the dash as clean as possible.
motiv8ya is offline
post #522 of 805 Old 07-29-2013, 08:44 PM
Jim1611
Jim1611's Avatar
Looking real nice!
Jim1611 is offline
post #523 of 805 Old 07-30-2013, 10:41 AM Thread Starter
motiv8ya
1979 CJ7
Originally Posted by Jim1611
Looking real nice!
Thanks Jim! I'm hoping to have this project done by the end of October. I've got two weeks vacation coming in August and I want to put in as much time as I can to make it to the end.
motiv8ya is offline
post #524 of 805 Old 07-31-2013, 05:01 PM Thread Starter
motiv8ya
1979 CJ7
Hood is on, I need to grab some more hardware to mount the vent I made for it. I will have to adjust the left front fender up a little because the gap between it and the lower hood line is 1/4" more than the right side. Also, I need to touch up two spots inside the hood where the original coat of paint failed to adhere.
The dash is all wired except for the wiper motor switch and 12v aux port. I ordered some aluminum knobs for the dash, I'm not a fan of these plastic replacement heater cables because they flex and move around. I mounted the TBI diagnostic plug in the glovebox area for easy access and wired my neutral safety switch to a rocker switch. I'm gonna make a small plate to mount a few more switches where the radio hole is. Some will be dummy switches and some will have a function (dome light, overhead fan). I painted the glovebox door and will mount that tomorrow also.
I seem to have come up short for the wire to my blower motor. I have an extra black/white wire under hood labeled 'A/C Compressor' but not sure if that connects to it for power.
I hope the 6 cans of paint I bought today are the last ones I need!
Here's a quick list of tasks to be done (not in any specific order):
1. Buy and run main ground cables (body/engine/frame)
2. Paint and install windshield frame
3. Clean and assemble the wiper motor and linkage
4. Exhaust
5. Fuel lines
6. Replace Injectors and mount TBI
7. Order custom chip from Howell
8. Make air intake system and find a 'snail' for tbi
9. Driveshafts
10. Buy and install seat belts
11. Buy and install battery
12. Buy and install wires for HEI
13. Confirm TDC compression stroke
14. Rear bumper / tire carrier
15. Overhead fan
16. Engine break-in
Getting there!
motiv8ya is offline
post #525 of 805 Old 07-31-2013, 05:06 PM
83vert
1982 CJ7
Keep chipping away at that list and before you know it you'll be ready to go for a test drive. Lookin real good
I am in deep
83vert is offline
"Old Sarge" CJ7 Build Thread cj7Sswampers Jeep CJ Forum 30 07-03-2014 06:12 AM
1979 CJ7 Build - "Project TRex" TRex Jeep CJ Forum 196 05-11-2014 07:02 AM
1985 "Special Edition" CJ7 Restoration Build Thread elliottferrell Jeep CJ Forum 38 07-23-2012 09:09 AM
a "whats it worth" thread (for a project) Jeepfreak81 Jeep CJ Forum 9 09-23-2009 06:26 PM
Project "Build Take 2" Hybrid AWD Jeep CJ Forum 20 04-28-2009 12:23 PM
