BUILD THREAD: Project "Ghetto Fabulous" - Page 33 - JeepForum.com
post #481 of 800 Old 06-20-2013, 01:52 PM Thread Starter
motiv8ya
1979 CJ7
The project just got bigger! I picked up (4) 35x12.5x r15 tires off of CL to swap out for the 33's that I will resell.
motiv8ya is online now
post #482 of 800 Old 06-20-2013, 08:22 PM
cjjon7
1983 CJ7
Good find. That's what I'm searching for!
cjjon7 is offline
post #483 of 800 Old 06-21-2013, 12:57 AM Thread Starter
motiv8ya
1979 CJ7
Couldn't pass them up for $175.00
post #484 of 800 Old 06-21-2013, 07:19 AM
83vert
1982 CJ7
It looks good, make sure you post some updated pics when you get those tires mounted. I'm liking the paint, would you use that paint again if you had to do it all over?
I am in deep
http://www.jeepforum.com/forum/f8/how-did-happen-rebuild-1113470/
83vert is offline
post #485 of 800 Old 06-21-2013, 08:35 AM
Jim1611
Jim1611's Avatar
Interested in seeing how they fit. I'd like to put 35s on mine after all is said and done.
Jim1611 is offline
post #486 of 800 Old 06-21-2013, 08:37 AM Thread Starter
motiv8ya
1979 CJ7
Thanks, will do. I like the color and texture of the paint but if I had to do it over (or would've used the correct primer the first time around) I would 'Monsta' line it inside and out in the tan color. I know I've spent far more in paint than it would've cost to monsta line it and be done.
post #487 of 800 Old 06-21-2013, 08:57 AM
83vert
1982 CJ7
I believe it's $6 a can, ask me how I know? I liked it so much I'm gonna attempt it this weekend. I think I need to pick up a few more cans
I am in deep
83vert is offline
post #488 of 800 Old 06-21-2013, 11:25 AM
Neuner-9R
How do you know? Did you read it on the front page of the newspaper? Was it the major article in a 4x4 magazine? Don't leave us hanging!!
Neuner-9R is offline
post #489 of 800 Old 06-21-2013, 02:25 PM Thread Starter
motiv8ya
1979 CJ7
The cheapest I found was Home Depot at $5.77, Walmart around $5.86 and Lowe's is $6.77. I stopped counting after 24 cans. They empty quick and the overspray settles everywhere.
post #490 of 800 Old 06-21-2013, 10:34 PM Thread Starter
motiv8ya
1979 CJ7
The new tires are Durango AT's and are the same size as the Big O' XT's on my other CJ, however when stood side by side the Durango's are nearly 2 inches taller. Weird.
The fronts will clear with the metalcloak front fenders without any problem. I will trim the corners of the rear wheel wells to match the inner curve of the metalcloak rear fender flare mounts for more clearance also.
I started separating the wiring harness into its smaller sections and realized that I can delete or repurpose some of the wires in it. It should be a nice and clean install.
post #491 of 800 Old 06-22-2013, 12:26 AM Thread Starter
motiv8ya
1979 CJ7
post #492 of 800 Old 07-01-2013, 05:59 PM Thread Starter
motiv8ya
1979 CJ7
I got it up on the 35's today! I'd love to post some pics from my iPhone but the site keeps blocking them.
My wire split loom, heater cables, battery tray and other miscellaneous parts came in so I can move ahead with the wiring. Do I need to add or change anything to the wiring to get the LED tailights to work correctly?
I'm going to use the larger TBI throttle body from the 89' 454 setup that I already have and just get a new chip from Howell for the FI. From what I've read, the 350 injectors will be run at their max in the smaller TBI. The 454 TBI unit has 2" bores and higher / more suitable injectors for the 401.
post #493 of 800 Old 07-01-2013, 06:39 PM
83vert
1982 CJ7
I think you need a special flasher for the led tail lights
I am in deep
83vert is offline
post #494 of 800 Old 07-01-2013, 07:18 PM
83vert
1982 CJ7
I am in deep
83vert is offline
post #495 of 800 Old 07-01-2013, 07:29 PM Thread Starter
motiv8ya
1979 CJ7
"Old Sarge" CJ7 Build Thread cj7Sswampers Jeep CJ Forum 30 07-03-2014 06:12 AM
1979 CJ7 Build - "Project TRex" TRex Jeep CJ Forum 196 05-11-2014 07:02 AM
1985 "Special Edition" CJ7 Restoration Build Thread elliottferrell Jeep CJ Forum 38 07-23-2012 09:09 AM
a "whats it worth" thread (for a project) Jeepfreak81 Jeep CJ Forum 9 09-23-2009 06:26 PM
Project "Build Take 2" Hybrid AWD Jeep CJ Forum 20 04-28-2009 12:23 PM
