BUILD THREAD: Project "Ghetto Fabulous" - Page 32 - JeepForum.com
post #466 of 805 Old 05-23-2013, 12:43 PM Thread Starter
motiv8ya
1979 CJ7
Got the brakes figured out. The hoses were backwards on the caliper and I needed to replace the banjo bolt washers. All sealed up now.
I picked up a rebuild kit for the Carter AFB Comp Series Carb and I will use that to break in the engine before I mess with the Fuel Injection.
motiv8ya is offline
post #467 of 805 Old 05-23-2013, 12:55 PM
cjjon7
1983 CJ7
Did you clear coat those calipers? ?
cjjon7 is offline
post #468 of 805 Old 05-23-2013, 02:26 PM Thread Starter
motiv8ya
1979 CJ7
No, just good ol' spray paint. It'll probably peel off now that I got brake fluid on them.
motiv8ya is offline
post #469 of 805 Old 05-28-2013, 05:57 PM Thread Starter
motiv8ya
1979 CJ7
Howell TBI Kit is on its way!!!!!
motiv8ya is offline
post #470 of 805 Old 06-03-2013, 04:08 PM Thread Starter
motiv8ya
1979 CJ7
The cage is stripped, primed and I started painting it today. I hope to have it installed by the weekend.
motiv8ya is offline
post #471 of 805 Old 06-06-2013, 04:39 PM Thread Starter
motiv8ya
1979 CJ7
Cage is in! It dropped in easily and only made a few small scratches that I need to touch up.
motiv8ya is offline
post #472 of 805 Old 06-06-2013, 04:59 PM
79CJ7dude
1979 CJ7
Looks good!
79CJ7dude is offline
post #473 of 805 Old 06-06-2013, 05:00 PM
cjjon7
1983 CJ7
Hey looks good! Its looking much more complete now! Those corbeau baja ss seats??
cjjon7 is offline
post #474 of 805 Old 06-06-2013, 05:43 PM Thread Starter
motiv8ya
1979 CJ7
Originally Posted by 79CJ7dude
Looks good!
Thanks!
motiv8ya is offline
post #475 of 805 Old 06-06-2013, 05:45 PM Thread Starter
motiv8ya
1979 CJ7
Thanks! The seats are suspension seat knock-off's, they say 'Race trim' on them. Another one of my CL deals.
motiv8ya is offline
post #476 of 805 Old 06-06-2013, 05:51 PM Thread Starter
motiv8ya
1979 CJ7
I'm starting to realize that I don't like how low the front end sits compared to the rear. In some of the pictures I took today the slope is pretty significant even with the rear tires on the ground and the front tires up on the dollies. I know the front springs are pretty flat so I will eventually swap them for the old ones I saved from my 79' to level it out.
My buddy had to hold up the garage door so I could roll the Jeep back in. I had a minor clearance issue with the top of the cage that now needs a paint touch up.
motiv8ya is offline
post #477 of 805 Old 06-06-2013, 09:52 PM
79CJ7dude
1979 CJ7
If you put a spare tire on the back it will drop down the back a little bit, but I don't know if it will be anuff cause it's hard to tell with the front wheels on the dolly how much in droops.
post #478 of 805 Old 06-07-2013, 02:05 AM Thread Starter
motiv8ya
1979 CJ7
Good point, there is still some weight to be added back there between the spare, bumper, full fuel tank and tools to load the box.
motiv8ya is offline
post #479 of 805 Old 06-16-2013, 07:57 PM Thread Starter
motiv8ya
1979 CJ7
I returned my carb rebuild kit and decided to go straight to the TBI. I ran into the problem of not having enough coolant ports for all of the sensors /senders for the mechanical water temp gauge, TBI coolant sensor and the thermo switch I'm using for my fans. I made a trip to Lowe's and picked up a bunch of 3/8 NPT brass fittings to work with.
I repurposed the unused tach 'steering column' mounting ring for my fuel filter, perfect fit. I need to check into the best mounting position for the fuel pump and filter.
Then I moved onto the wiring harness and mounted it to the firewall, stepped back, looked at it and then walked away.
motiv8ya is offline
post #480 of 805 Old 06-18-2013, 05:50 PM Thread Starter
motiv8ya
1979 CJ7
I ordered my Metalcloak front fenders today. I received my TBI 1' spacer and installed that too. I also reworked the brass fittings for all of the coolant sensors. I'm much happier with the way they look now.
motiv8ya is offline
"Old Sarge" CJ7 Build Thread cj7Sswampers Jeep CJ Forum 30 07-03-2014 06:12 AM
1979 CJ7 Build - "Project TRex" TRex Jeep CJ Forum 196 05-11-2014 07:02 AM
1985 "Special Edition" CJ7 Restoration Build Thread elliottferrell Jeep CJ Forum 38 07-23-2012 09:09 AM
a "whats it worth" thread (for a project) Jeepfreak81 Jeep CJ Forum 9 09-23-2009 06:26 PM
Project "Build Take 2" Hybrid AWD Jeep CJ Forum 20 04-28-2009 12:23 PM
