Well, here I go again. This is CJ7 #3 for me and here's the story behind it and the title of the build.
For the past 7 years I have worked in the "Ghetto" and have driven past this one house that had this CJ7 parked along side the house for probably longer than 7 years. I would pass this thing numerous times a day and always check to see if this fellow Jeeper has made any progress on it. It never changed, it sat in the same spot the entire time never to be worked on again....until last week when I drove by again and there was a 4 sale sign on the grill. I called that day and went to take a look at it.
It "is" a 76 frame with an 83 tub, a chevy 350/ muncie 4 speed/ dana 20, stock axles, P/S. P/B with a custom cage and lots of extra parts.The tub has two minor areas with surface rust, solid floors and windshield frame. The chassis/frame looks new and all of the body mounts are solid. The guy asked $700.00 so I jumped on it (I wanted to build a $crambler, but what the hell) :thumbsup:.
So not only did I get a great deal but the guy trailered it to my house and helped me unload it into my garage!! :
The Jeep sat in the desert heat for years, so after vacuuming the desert off of the floorbaords (and the black widows) I was pleasantly surprised to see their like new condition. Nothing more than surface rust that will easily come off with a wire wheel or media blast.
So this turned out to be a "fabulous" find in the "ghetto", hence the build title.
Here's some pics:
The plan is to build a wheeler that will see street use:
#1. dump the stock axles for Currie 9 inch housings front and rear with detroit lockers and discs all around.
#2. dump the stock suspension and lift shackles for a quality 4.5 inch lift.
#3. install tube fenders up front and TJ flares out back to clear 35's.
#4. install Vanco hydraboost brakes and a high pressure P/S system.
#5. strip the body and line the interior and underside. the body will be painted either orange or camo. I already have a token red jeep :laugh:
#6. install rock sliders and bumpers with a tire carrier
#7. install new wiring harness
#8. tear down the motor, trans and xfer case and freshen them up because they sat open in the desert for years, probably got scorpions living in them, or completely replace everything.
#9. custom exhaust
Now here comes the big decision, do I keep the 350/muncie/dana 20 or install my worked 304/th400/dana 20 that I also have from another Jeep and put Fuel Injection on it? I'm an AMC kinda guy and I like to keep my CJ's mostly AMC/Jeep when I can (everyone and their mother can run a chevy, but an AMC takes a little TLC).
This project will take me quite a while cause I'm in no rush, so please bare with me and I'll post updates and lots of photos.
If anyone has any suggestions feel free to let me know.
I may put blacked out rims with some bling bling chrome center caps to keep with the "Ghetto Fabulous" theme. Cause in the Ghetto camoflauge and chrome match.
Here's some pics:
#9. custom exhaust
