BUILD THREAD: Project "Ghetto Fabulous" - Page 29 - JeepForum.com
post #421 of 805 Old 03-29-2013, 03:03 PM
MrBeast
1980 CJ7
Sweet build man, I am subscribed.
"He used to be a pretty nice feller, now he's a welder"
AMC 304 V8, NV4500, Dana 300, Dana 44, 9 inch, M.O.R.E. SRS, YJ tub.
AT3 US Navy 1999-2003
Cum catapultae proscriptae erunt tum soli proscript catapultas habebunt
(When catapults are outlawed, only outlaws will have catapults)
MrBeast is offline
post #422 of 805 Old 03-29-2013, 11:06 PM Thread Starter
motiv8ya
1979 CJ7
Cool, thanks!
motiv8ya is offline
post #423 of 805 Old 04-06-2013, 08:30 PM Thread Starter
motiv8ya
1979 CJ7
Hooked up the heater hoses today, seems that the Flowkooler pump outlet is 3/4 instead of 5/8 hose like the factory pump so I made two trips to the store. I used a 3/4 - 5/8 adapter for the line that connects the water pump to the 5/8 heater core line. The factory hose fitting that goes into the back of the intake manifold didn't clear the firewall either and no local parts stores had it so I looked through my bucket of old fittings and found a 90* adapter to put in the intake. Then I connected the factory fitting to that and it just barely cleared. Hopefully it won't leak.
My hood got blown over a few times when I had my garage doors open the other day and the last time it fell it dented and creased the hood at the front so I'll have some body work to do on it.
image-4007533794.jpg   image-972278303.jpg   image-2957403748.jpg   image-2589149690.jpg
motiv8ya is offline
post #424 of 805 Old 04-07-2013, 10:13 AM
ASteve
1972 CJ5
On picture number 3 it seems that the hose might be too tight to the heater core nipple. Meaning, over time, with engine torquing the heater core nipple might crack at the core. Just a thought...I may be way off ... but I hate replacing heater cores...
http://www.jeepforum.com/forum/f8/da...l#post14924453
In photo number 3 of my post you can see how I routed my hose in front of the valve cover then a straight shot back to the heater core. So, there is no torquing on the heater core nipple...
Again, just a thought ...
Also, my stock water pump is the same 3/4 to 5/8 heater core, and I used a reducer too. A brass fitting would be better than plastic if you can find one.
Now time to go and read your thread here...
SC
ASteve is offline
post #425 of 805 Old 04-07-2013, 11:04 AM Thread Starter
motiv8ya
1979 CJ7
SC
WOW! Nice engine bay, very clean! Thanks for the tip, I don't think the rubber line I'm using can make such a sharp turn without collapsing though. I tried to run it as short as I could without kinking. I will replace the intake fitting if I can find the correct part locally in the next few days.
motiv8ya is offline
post #426 of 805 Old 04-07-2013, 07:56 PM Thread Starter
motiv8ya
1979 CJ7
I found the correct heater hose connector and put that in today. I also started on a new cover for the air vent inlet to match the one I made for the hood. I still need to drill mounting holes and paint it but you get the idea.
motiv8ya is offline
post #427 of 805 Old 04-08-2013, 05:16 PM Thread Starter
motiv8ya
1979 CJ7
I finished the vent cover and installed it. I also stripped, painted and installed the rest of the driver's seat frame.
I started to tear down the steering column and I couldn't get the steering wheel off so I moved onto the windshield frame. I found a few spots (under the drivers wiper pivot and the top rail) that will need to be repaired. The majority of the rust is in the passenger side under the bracket.
The driver side wiper pivot has some damage, I hope they sell them separately because the rest of the system is good to go.
Just doing little stuff until I hear back from a media blaster with a quote to finish stripping my hood, roll cage and windshield frame. I'm anxious to get those final big parts painted and installed.
image-4028616210.jpg   image-233586131.jpg   image-1553688112.jpg   image-4146348895.jpg   image-2863075824.jpg
motiv8ya is offline
post #428 of 805 Old 04-13-2013, 04:53 AM Thread Starter
motiv8ya
1979 CJ7
I ordered my H1 steering box and also picked up a new set of seats from CL for $150. Good score and they even match!
motiv8ya is offline
post #429 of 805 Old 04-13-2013, 07:59 PM Thread Starter
motiv8ya
1979 CJ7
I couldn't resist even though I know I have to pull them back out to install the cage and dash!
motiv8ya is offline
post #430 of 805 Old 04-13-2013, 08:25 PM
twinstickd20
1979 CJ7
Nice! But you may end up having to use after market seat brackets, I used corbeau because the original jeep brackets set too high and I couldn't get my leg between the steering wheel and seat. They worked so much better with that style of seat.
My Build Thread
twinstickd20 is offline
post #431 of 805 Old 04-13-2013, 08:45 PM Thread Starter
motiv8ya
1979 CJ7
I hope not, the high point of the front of my seats in my 79' measure 14" from the floor. These are 15.5". How much were the corbeau brackets just incase?
motiv8ya is offline
post #432 of 805 Old 04-13-2013, 08:48 PM
twinstickd20
1979 CJ7
60 each I think
My Build Thread
post #433 of 805 Old 04-17-2013, 05:29 PM Thread Starter
motiv8ya
1979 CJ7
H1 steering box is installed. I had to drop the sway bar and remove the steering box mount to get it installed. Here's a pic of the h1 box and CJ7 stock box side by side. Also installed the drop pitman arm and had to run to pick up two new castle nuts for the tie rods.
I picked up a gas filler housing off CL and installed it. I'm not happy with the stainless shine and may remove, blast and paint it to match all the brackets. The guy I bought it from has about 7 jeeps that he's parting out and will definitely be a good resource for me.
My youngest is my official seat tester, everyone love the jeep!
image-2904947232.jpg   image-3384694609.jpg   image-3027201710.jpg   image-2277554717.jpg   image-2614162199.jpg
motiv8ya is offline
post #434 of 805 Old 04-17-2013, 05:46 PM
Jim1611
Jim1611's Avatar
It's all looking great! Hummer box should be a good upgrade. I like the seats, seat tester looks pleased too. Back when I built my cage I made the brakets so they mount to the cage. I had to make them lower than the factory brackets because the aftermarket seats sat too high and my legs hit the steering wheel. You might need to lower yours too.
Jim1611 is offline
post #435 of 805 Old 04-17-2013, 06:28 PM Thread Starter
motiv8ya
1979 CJ7
Thanks Jim! I'm hoping to avoid the seat bracket issue all together. I'm only 5'8" so we'll see how I fit once I get the dash and steering column in there. I know someone who has a tilt wheel column just incase.
Looks like my steering linkage clears the springs with plenty of room and the bars are almost on the same plain. Handling should be a hell of a lot nicer than my 79' due to the geometry.
I will have to figure out a way correct a clearance issue between my front brake lines and the sway bars. There's only two inches of clearance between the sway bar links and the brake lines, one bump and the lines are toast! So I'll either shorten the links or reroute the lines.
The blaster wanted $300 to finish my hood, cage and windshield frame, apparently he forgot about the $175 quote he previously texted me for those same parts plus a tailgate. Needless to say I'll be stripping them by hand.
I have some stuff I need to put up on CL to make some more room here in my garage. I'd like to put both CJ's in here so my 79' doesn't get destroyed in the sun.
motiv8ya is offline
"Old Sarge" CJ7 Build Thread cj7Sswampers Jeep CJ Forum 30 07-03-2014 07:12 AM
1979 CJ7 Build - "Project TRex" TRex Jeep CJ Forum 196 05-11-2014 08:02 AM
1985 "Special Edition" CJ7 Restoration Build Thread elliottferrell Jeep CJ Forum 38 07-23-2012 10:09 AM
a "whats it worth" thread (for a project) Jeepfreak81 Jeep CJ Forum 9 09-23-2009 07:26 PM
Project "Build Take 2" Hybrid AWD Jeep CJ Forum 20 04-28-2009 01:23 PM
