BUILD THREAD: Project "Ghetto Fabulous" - Page 17 - JeepForum.com
post #241 of 800 Old 06-19-2011, 04:18 PM Thread Starter
motiv8ya
1979 CJ7
This project is not dead!!!! Life has been kicking my *** lately leaving me with no time for anything. So in order to jumpstart this project again I decided to scrap my front bumper builds and I ordered some MetalCloak bumpers (for my 79' and the 83'). I consider it a Father's Day present to myself. The Metal Cloaks have the look I wanted plus they have the winch mount built in. They were on sale so I ordered two identical sets.
motiv8ya is offline
post #242 of 800 Old 06-19-2011, 04:25 PM
Coiz
1979 CJ7
Sweet.
Mike
Coiz is offline
post #243 of 800 Old 06-25-2011, 03:29 PM Thread Starter
motiv8ya
1979 CJ7
I installed the new bumpers and I'm very happy with them. They went on easy and look good. I like the fact that they are modular because it gives me the ability to change or add things to it without having to start from scratch. Which is a huge bonus seeing as I constantly change my mind about stuff on this build. The bumpers come with a ton of hardware to close off all of the unused holes but I'm gonna leave it as is.
motiv8ya is offline
post #244 of 800 Old 07-03-2011, 05:17 PM Thread Starter
motiv8ya
1979 CJ7
I've been researching hood louvers and their placement lately, so today I marked up my project hood. I'm going to put a vent above each exhaust manifold and across the back of the hood as close to the firewall as the hood bracing will allow. I still plan on using the perforated sheet I have on hand. I'll make two sets of vents because if I'm happy with the results I'll do the same setup on my 79'.
motiv8ya is offline
post #245 of 800 Old 07-03-2011, 05:44 PM
Havasu Living
1980 CJ7
I picked up a hood several years ago to do the samething. I'm interested to see how you do it.
80 CJ7 5.0 Dual Exhaust, T176, D300, D30 w/ true trac, AMC 20 w/ ARB 4.56 gears, York OBA, Hydroboost
Havasu Living is offline
post #246 of 800 Old 07-26-2011, 05:45 PM Thread Starter
motiv8ya
1979 CJ7
I spent some time cleaning up some wiring on my 79', changing the thermostat and adding relays to my E-fans wiring. Runs much cooler now.
I made one vent for the project hood out of 1 inch x 1/8 flat bar and perforated sheet. I'm only going to run one vent towards the rear of the hood so I won't be cutting out the other two sections I laid out on the hood over the top of the exhaust manifolds. The one rear vent is large enough that it should help rid the engine compartment of excess heat. I like the way it came out so I'm gonna make another for my 79'.
I also made a mount and screen out of the same materials for an auxillary trans cooler/E-fan setup that I may mount in the right front fenderwell of the 79' to take the extra cooling load of the th400 off the radiator. I'll have to cut a section out of the inner fender behind the wheel to get the airflow. The perforated sheet will block any rocks/debris that may get kicked up at the cooler mounted behind it.
motiv8ya is offline
post #247 of 800 Old 08-02-2011, 03:51 PM Thread Starter
motiv8ya
1979 CJ7
I finished my hood vents for both CJ's. I was kinda nervous about cutting up two perfectly good CJ hoods but I like the end result. Here's a some pics....
image-1632717757.jpg   image-1877193802.jpg   image-693047140.jpg   image-1207092730.jpg
motiv8ya is offline
post #248 of 800 Old 08-02-2011, 10:46 PM
Havasu Living
1980 CJ7
Turned out nice. What's the hardware you used to attach?
post #249 of 800 Old 08-02-2011, 10:51 PM Thread Starter
motiv8ya
1979 CJ7
motiv8ya is offline
post #250 of 800 Old 08-02-2011, 10:57 PM Thread Starter
motiv8ya
1979 CJ7
Thanks! I used stainless 1/4 - 20 x 3/4 inch button heads with stainless washers and locknuts. Overall it went together nice and easy. I was able to get it all done by myself in a couple hours.
motiv8ya is offline
post #251 of 800 Old 08-03-2011, 04:27 PM
Skerr
That came out very good. Very sporty!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #252 of 800 Old 08-03-2011, 04:31 PM Thread Starter
motiv8ya
1979 CJ7
Thanks Skerr!
motiv8ya is offline
post #253 of 800 Old 08-03-2011, 04:57 PM
Jim1611
Jim1611's Avatar
Man I'd have had a hard time cutting into that hood but you did a great job. Keep us posted how well the vents work.
(Crabtree Shackle Hangers)
My build thread
Jim1611 is offline
post #254 of 800 Old 08-03-2011, 05:46 PM Thread Starter
motiv8ya
1979 CJ7
Thanks! I took a ride today in the 107* heat and hit the highway for 20 minutes, pulled off and drove some side streets and then pulled over and idled for ten minutes and it maintained a steady operating temp of 195*. This is down 15-20* from pre-hood vent temps. I'm running a 160* t-stat.
motiv8ya is offline
post #255 of 800 Old 08-12-2011, 01:53 PM Thread Starter
motiv8ya
1979 CJ7
Yesterday was a great day! I went to the local pick a part looking for 2 contour fan setups ( one to replace the dual flexalite in my 79 and one for this project) and I found this near complete 6/auto/300 p/s, p/b CJ tucked in with the cherokees. The only thing missing was the front arb locker. I immediately noticed the mean green and arb stickers on the dash. Yup it had mean green starter in it! I pulled the starter, alternator, headlight and marker assemblies/harnesses and a bunch of other little hard to find parts. It even had the same gas tank I'm using on the 83 so I pulled the fuel sender retaining ring and float arm extension that I couldn't find anywhere else.
The cj has quite a bit of aftermarket stuff on it to include a clifford aluminum valve cover, slotted rotors, front lift shackles and a nice aluminum skid for the aluminum gas tank. Too bad I didn't come across this CJ earlier in the project because I could've used the trans crossmember instead of building one. If any Vegas guys need CJ stuff you need to get there quick!
I wound up finding a good contour fan setup so i pulled that also along with the harnesses for another guy in my club who really needed it.
motiv8ya is offline
"Old Sarge" CJ7 Build Thread cj7Sswampers Jeep CJ Forum 30 07-03-2014 06:12 AM
1979 CJ7 Build - "Project TRex" TRex Jeep CJ Forum 196 05-11-2014 07:02 AM
1985 "Special Edition" CJ7 Restoration Build Thread elliottferrell Jeep CJ Forum 38 07-23-2012 09:09 AM
a "whats it worth" thread (for a project) Jeepfreak81 Jeep CJ Forum 9 09-23-2009 06:26 PM
Project "Build Take 2" Hybrid AWD Jeep CJ Forum 20 04-28-2009 12:23 PM
