Build thread-1957 CJ6 4.3 swap! - Page 2 - JeepForum.com
post #16 of 121 Old 11-12-2010, 10:43 PM
1986cj
Back in the day when I was a kid, Hudson steering boxs were a common swap in early CJs. I don't remember for sure but I don't think they came apart, well easly apart.
1986cj is offline
post #17 of 121 Old 11-19-2010, 10:49 PM
MMPSM
1959 CJ6
Originally Posted by FamillyCJ7 View Post
Not wanting to post pictures due to stealing idea's and not getting credit? That's what the forum is for is for getting idea's and learning new things and helping people out. Who cares if someone likes your bed idea and copies it, it will more than likely happen sooner or later anyways unless you plan on never driving the thing and keeping it out of sight.
I'm sorry but that's just I don't even know what to call it
I'd be really surprised if you are the only and 1st person to make a flatbed CJ6. Unless pictures are posted this thread is useless
Oh and a flatbed CJ has been done before:
Looks like an extended CJ7 to me . . .
MMPSM is offline
post #18 of 121 Old 11-19-2010, 10:54 PM
FamillyCJ7
1983 CJ7
I said flat bed CJ, didn't say it was a CJ6.... nearly stating the obvious that he more than likely is not the first to come up with a flatbed CJ6.
'83 CJ7 258I6 4-Speed Father Daughter Project - Using Monstaliner/Chassis Saver and Products from CrabTreeTool
NorthEastFL4x4.com - Local 4x4 Enthusiasts website, join up now!
FamillyCJ7 is offline
post #19 of 121 Old 11-20-2010, 07:10 AM
Skerr
I was excited about the possibility of a 4.3 in a CJ. But this looks like a Dead Thread!
Kerrdog
Go Fish! <*////><
Skerr is offline
post #20 of 121 Old 11-20-2010, 11:24 AM
1986cj
I have been toying with the idea of dropping a 4.3 tbi in my 86 CJ7. I will have to transfer every thing into mine as I have to remain smog legal. My biggest hang up is the bellhousing. I will need to keep the T5 for a while. I would change out the T5 for a AX15 or NV3550 but that will have to be down the road. Everything I have read is that all 4.3s came with the large 168 tooth flywheel and changing to the smaller 153 tooth will change the rotating mass and drop the torque a lot so that rules out the iron duke bell. Changing out the T5 later rules out AA's 450.00 bell. I have also heard that some of the last years Gm used the T5 in the S10 blazers had the Ford bolt pattern but have never seen one yet. So the search goes on.
1986cj is offline
post #21 of 121 Old 11-22-2010, 09:19 PM Thread Starter
Rumpeltiltskin
1957 CJ6
Ok so here are the pictures of the steering wheel to help identify what kind of vehicle it came from. I have gotten over the fact that I was being selfish about the flatbed pictures and whatnot so those pictures will be coming soon! I promise! Anyhow, I have gotten the steering box completely torn apart and removed from the jeep altogether. I think it is time for the body to come off! Here are the things I have removed: steering box and column, radiator, battery, hood, windshield, fuel tank, drivers seat, fuel lines, complete heater assembly(may or may not get reinstalled), center section of the floor, brake clutch and gas pedals.
Things that have been disconnected but not removed completely:all engine wiring, tail light wiring, speedo cable, some misc. wires under the dash(unintentional, they were zip tied to the heater and they became disconnected ) So I guess my question this time around is if anybody can help me out with what the steering came out of just because I am still curious. and am I missing anything that needs to be diconnected/removed before I lift the body off? (yes I know I need to remove the body mount bolts)
Rumpeltiltskin is offline
post #22 of 121 Old 11-22-2010, 09:45 PM
83vert
1982 CJ7
What the???
I am in deep
http://www.jeepforum.com/forum/f8/how-did-happen-rebuild-1113470/
83vert is offline
post #23 of 121 Old 11-22-2010, 09:50 PM Thread Starter
Rumpeltiltskin
1957 CJ6
weird huh!?! It is also much larger in diameter than a normal jeep steering wheel.
post #24 of 121 Old 11-22-2010, 10:08 PM Thread Starter
Rumpeltiltskin
1957 CJ6
I think you are right! I googled "old hudson steering wheel" and this picture came up! It sure looks the same! Mine used to have that horn lever too but I cut it off. funny how all this time I thought it was a pontiac wheel
post #25 of 121 Old 11-22-2010, 10:48 PM
1986cj
Yep Hudson all the way. It was Hudson/Nash or something like that, that became AMC or AMC bought up Hudson/Nash. I don't remember now. Back in the late 60s and early 70s Hudson was a very common swap to CJs as it was as easy to turn and steer as the power steering we have now days.
1986cj is offline
post #26 of 121 Old 11-24-2010, 08:20 AM
MMPSM
1959 CJ6
Originally Posted by Rumpeltiltskin View Post
Ok I have officially began the project! I drove the jeep into its place of rest for the next few months where it will be beat on, spit on, cussed at, torched, welded, hoisted, jacked up, cussed at, spilled on, ignored, spit on, and cussed at.
And thus it begins...
Step 1 was supposed to be to pull the body off of the frame and leave as much as I could intact(engine,trans, driveshafts, etc) Thus far I have unhooked all the engine wiring, drained the coolant, removed the drivers seat, hood, and windshield. I was moving right along and already hit a snag at the steering box. I have always known that this steering box was never meant to be in a jeep, however it worked quite well so I left it alone. Now I want to remove the entire steering column and I cant get it out of the box. I will try to get pictures up as soon as I can but for now the only info on the box that I can give you is: it is not a jeep box, it is not a saginaw setup, and it is possibly from a pontiac of some sort? So I guess my question is if somebody can tell me how to get the column seperated from the box before I give up and get Mr. Choppy out (sawzall).
PS I am most likely going to convert to saginaw steering during the process of the engine swap if finances are present (I am hoping)
I have a couple of '59 CJ6's, one actually in Colorado. Interested in your treatment of Fan Tunnel and Radiator. When you get there.
MMSM
MMPSM is offline
post #27 of 121 Old 11-24-2010, 08:23 AM
MMPSM
1959 CJ6
Back in the day, Hudson boxes were routinely swapped into CJ's because the Hudson box was bigger and made turning less "armstrong" and more power. The extra added attraction was the great wheel. Though it was a little like driving a bus. Put one in my CJ2A
MMPSM is offline
post #28 of 121 Old 11-24-2010, 11:54 AM Thread Starter
Rumpeltiltskin
1957 CJ6
Here are the pictures you have all been waiting for(finally found my digital camera) This is how the project looks as of right now. and yes there is a sneak peek of the flatbed there too.
post #29 of 121 Old 11-24-2010, 11:58 AM Thread Starter
Rumpeltiltskin
1957 CJ6
Here's 5 more
post #30 of 121 Old 11-24-2010, 03:42 PM
Skerr
COOOL! The bed looks great.
Kerrdog
Go Fish! <*////><
Skerr is offline
1957 cj5 DeVo24 Jeep CJ Forum 2 03-13-2010 03:02 PM
1957 cj5 brake swap? Luckyduck Jeep CJ Forum 3 08-19-2008 06:57 AM
1957 Cj 5 ROYALT91 Jeep CJ Forum 3 08-05-2005 03:56 PM
1957 cj5 info jeepinarkansas Jeep CJ Forum 6 02-09-2004 09:59 AM
