to build a CJ frame - JeepForum.com
post #1 of 15 Old 01-06-2003, 05:36 PM Thread Starter
Dtray332
to build a CJ frame
Do any of you researching, jeep buiding, anything fixing jeepers out there know where a fellow could get the specs to build a frame for a CJ7. Things like angles for bends, mount locations & cross members? If not, I'll try to get my hands on a trashed out frame and start copying it. Thanks.
1986 Renegade CJ7, 258 straight 6, 4 inch Pro Comp lift, 33 inch Super Swampers (TSL Radial), Double Trail Master steering stabilizer, cool set of aircraft seat restraints.
Dtray332 is offline
post #2 of 15 Old 01-06-2003, 05:52 PM
Lujan
Send me your email address. I downloaded some drawings of the net. I am planning the same project on building my own frame.
I would like to share notes, ideas and pictures.
My CJ7 frame is shot from the front. Right now I am working on replacing the two axles with Dana 44, upgrade to t18 and installing a Dana 300 transfer case.
Bert
Lujan is offline
post #3 of 15 Old 01-06-2003, 06:50 PM
icarus00000
I can do one better. I have a 1978 service manual, with a cad drawing of all the jeep frames & models for those years.
I was just looking at it fast, but it has some specs, not sure on the angle bends or anything like that. But, let me know if ya want a copy of it. I can scan it in a few days, or snap off some shots with my digital.
icarus00000 is offline
post #4 of 15 Old 01-06-2003, 07:01 PM
Lujan
Iwould like a copy also. I would like to see your project going.
lujan@pmt.org
Bert
Lujan is offline
post #5 of 15 Old 01-06-2003, 08:03 PM
icarus00000
no prob. will check on that tomight in fact when I get out of work
post #6 of 15 Old 01-06-2003, 08:55 PM Thread Starter
Dtray332
All the help I can get will be greatly appreciated. My e-mail address is Dtray332@aol.com
Thanks
Dtray332 is offline
post #7 of 15 Old 01-07-2003, 11:48 AM
icarus00000
I am going to scan those sheets in this weekend, expect them sat eve, sunday to your email and posted here as well.
post #8 of 15 Old 01-07-2003, 08:03 PM
Strelnikov
This might help.
Strelnikov is offline
post #9 of 15 Old 01-07-2003, 10:00 PM
Crash&Burn
Those drawings bring up a question for me.......Does any one know the purpose of the bar between the 2 mounts in #5 of the top drawing.
These bars (one on each side) were on my CJ7 body but I could find no way to reinstall them on the Wrangler tub.
They look like they were some kind of floor reinforcing device but must not be needed on the YJ..?????
Sure someone out there has a answer.............
1979 CJ7 (YJ tub) full cage, Currie 9inch rear with Warn full float kit, detroit locker, 456 gears both ends, Lockrite in front, T 18 trans, 360, 040 over, Isky cam, 2 into 1 Flowmaster exhaust
I'm not as good as I once was....but I'm good once as I ever was.
Crash&Burn is offline
post #10 of 15 Old 01-07-2003, 10:15 PM
OldJeepguy
OldJeepguy's Avatar
1979 CJ7
They are for floor reinforcing and body mounts that I believe the YJ doesn't have - when I rebuilt my tub I left the front one out but retained the rear since it has a body mount on each side that connects from the frame crossmember.
Oops! I just looked at my restoration project and it looks like I retained the front one and scrapped the rear....
Steve
OldJeepguy is offline
post #11 of 15 Old 01-07-2003, 10:42 PM
Crash&Burn
Looking at the angle they are installed at I don't see how they could have much of a effect...
Could be they are a after thought to fix a design flaw!
post #12 of 15 Old 01-08-2003, 04:27 PM
icarus00000
That posting is the same sheet I have in my manual, so, if that helps. great. saved me some scan time !
post #13 of 15 Old 01-08-2003, 08:36 PM
Strelnikov
I found them somewhere on the internet, don't remember where. They look like a scan out of a book.
post #14 of 15 Old 01-11-2003, 04:13 PM
bstruckm
bstruckm's Avatar
Frame Mounts
I've got a pair of frame body mounts and a rear crossmember on Ebay if your interested? I bought these to repair my 81 frame, but then got a deal on a rust free 84 frame.
Frame Mounts
bstruckm is offline
post #15 of 15 Old 01-11-2003, 08:19 PM Thread Starter
Dtray332
OK, here I go. I'm about to begin the project. I'll document and photo as I go. I decided to try something that I've never seen before. Instead of building with 2"X4" box tubing, I'm going to use two 2" round tubing stacked on top of each other. If you look at it on an engineer aspect, there should be more flexability to it. You know how they say the every action has a reaction. Well when you bend one side in, the other side stretches out. This way, I'll have 2 of each working at the same time. I'll weld 1" flat stock every 12 inches to keep them together. I'll also have to fabricate my own mounts for body, tranny shocks and springs. I know it would be a lot easier to just buy one, but who buys a jeep already built up.
Dtray332 is offline
cj frame cracked....replacment frame or 1 ton frame for cj neatocj Jeep CJ Forum 17 12-03-2009 08:44 PM
Frame Repair - cutting frame open to remove rust? Bell-Vegas Jeep CJ Forum 4 04-21-2009 10:44 PM
Jeep CJ7 build FRAME TIME ajstewart Jeep CJ Forum 0 09-18-2008 09:58 AM
Frame off build up Ideas JFlanny11 Jeep CJ Forum 8 08-05-2008 12:49 PM
Anyone ever build a home made frame? jonnythunder Jeep CJ Forum 14 12-08-2007 04:58 PM
