Quantcast Broken Shock Mount - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Broken Shock Mount
Old 10-13-2006, 10:06 AM   #1
Garpo
Broken Shock Mount
The mount on the stabilizer bar in the rear broke off and before I had a chance to fix that my shock mount broke in half. The shock is hanging there with half of the mount still attached...... Should I just try welding the mount back together or is the mount its self replaceable, I have not crawled under to investigate yet, I just found it and was a little annoyed.
Garpo is offline   Reply With Quote
Old 10-13-2006, 10:22 AM   #2
ttrem
There is a place that sells them, but I dont have a link since Im at work and dont remember the name of it. Once I get home in roughly 5 hours I will post it for you.
1986 CJ-7 w/ 4.0HO FI, 4" lift, 1" body lift on 35" Super Swampers, AX-15, and a girly sounding horn =(
ttrem is offline   Reply With Quote
Old 10-13-2006, 10:27 AM   #3
Garpo
thanks a lot. Also I was driving in the rain the other day and I noticed water dripping out from under my dash, this has happened before but I never had any problems. Well this time it must have hit my radio because first my speakers went out, now my radio wont turn on. I imagine this is coming from the vent outside the windshield. Is there an easy fix for this?
Old 10-13-2006, 11:06 AM   #4
YeloCJ
Cowl vent
I had the same problem, I re-fiberglassed the box that is under the grill. This worked for a long time but eventually it started leaking again. I guess I'm not that good with fiberglass. When it started leaking again it fried my new cd player so I took the grill off and cut a piece of sheet metal to fit under the grill and siliconed it in. I replaced the grill on top of the sheet metal and it doesn't leak anymore.
YeloCJ, 360, 36's and Detroits f/r, T-18, Tera-low 20
YeloCJ is offline   Reply With Quote
Old 10-13-2006, 01:29 PM   #5
ttrem
I would replace the cowl seal there. That should fix the problem, also look at the windshield wiper seals. There is a recent thread with a link to the outer seals that need to be replaced. They are prety cheap. I would try there first on this problem. I bought my cowl seal on ebay for 12 bucks, so they arent too pricey either. If you dont feel like dealin with ebay pretty much every online vendor sells em.
Old 10-13-2006, 01:52 PM   #6
coxhaus
I welded a rear shock mount for a buddy. Did not cost him a dime. The stud was broken off. I put a taper grind on it and welded it back on with high heat. It has held for years. See if you can find a buddy who welds.
coxhaus is offline   Reply With Quote
Glock Forum
