Broken Shifter Lever - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Broken Shifter Lever
Toxic Brakes - 3000 PSI Braided Stainless Steel Brake LineFS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitZone Offroad - Jeep Forum Promotion
Unread 05-06-2009, 08:53 PM   #1
kapsig431
1981 CJ5
I was changing the shifter knob the other day and snapped it right off my shifter lever. I'm having a heck of a time finding a replacement shifter lever for my Borg-Warner SR4. However, I have found several shifter levers for the Borg-Warner T5. They look identical. Can anyone tell me if both trannys use the same shifter?
kapsig431 is offline   Reply With Quote Quick reply to this message
Unread 05-07-2009, 12:00 PM   #2
Nickmil
No they do not. Where they bolt to the transmission is different.
'59 CJ-5, '59 CJ-6, '68 CJ-5, Bone stock '57 CJ-5, a couple of XJ Cherokees
Nickmil is offline   Reply With Quote Quick reply to this message
Unread 05-07-2009, 12:04 PM   #3
kapsig431
1981 CJ5
Nickmil, thanks for the reply. Any chance you could point me in the direction of a SR4 shifter lever? Apparently, every Jeep part company in the country has ones that will fit a T5, but not an SR4.
Unread 05-07-2009, 12:46 PM   #4
Stan99
1978 CJ7
Im assuming that it broke off at the bottom of the threads? If so, it would be easy enough to have a bolt welded on there or re tap it. If you want to change then try this place........
http://www.jwjeep.com
But I am sure there are some easy fixs for ya. Maybe try posting apic of it and see what people say. Save your self the money.
1978 Jeep Cj7 Soa, Shackle Reversle, 36x13.5x15 Irocks, 4.5 Stroker MPI, Dana 300 twin Sticked, 4.88's
Stan99 is offline   Reply With Quote Quick reply to this message
Unread 05-07-2009, 01:13 PM   #5
Jon In Tucson
Jesus Is Lord!
Jon In Tucson's Avatar
1983 CJ5
What are the chances of squaring off the broken shift lever and cutting new threads. It will be a little bit shorter than before. Now the shift throws will be shorter.....
Jon In Tucson
Jeremiah 17:7 "But blessed is the man who trusts in the Lord, whose confidence in Him."
"The secret to a Jeep, especially a CJ, is you can't
panic." - Mike
"I may not be a smart man, Jenny, but I do know grounds."
Jon In Tucson is offline   Reply With Quote Quick reply to this message
Unread 05-07-2009, 01:17 PM   #6
Nickmil
Where is it broken off? Maybe if you can post a pic we can help with a "budget" fix. The SR-4 shifters are getting harder to find as it's common for them to wear out or break. Try JW like posted above, or maybe Collins Bros. Jeep Parts. I know they advertise in many of the 4 wheel drive rags.
Unread 05-07-2009, 02:21 PM   #7
caleb7mm
does anyone have a link to replacement shifter for the man? I searched for a while and found replacements for just about every tranny out there except the sr4??
|...........MILLER........| ||'|";, ___.
|_..._..._______===|=||_|__|..., ] -
caleb7mm is offline   Reply With Quote Quick reply to this message
Unread 05-07-2009, 04:24 PM   #8
caleb7mm
call them, they might have one.
Mack's Standard Transmission
8680 Cullen Blvd.
Houston, Tx 77051
1-800-392-8607
Unread 05-07-2009, 05:27 PM   #9
sabu
1983 CJ7
It's very easy to drill and tap the shifter. I installed a short threaded rod with loctite and replaced the knob and locknut.
sabu is offline   Reply With Quote Quick reply to this message
Unread 05-07-2009, 10:49 PM   #10
eastin82
1981 CJ5
ive got the same problem in with my sr4 but it still shifts without the knob ha ha! i would fix it but ive got a t176 that im gona rebuild so for now it works.
eastin82 is offline   Reply With Quote Quick reply to this message
Unread Today, 03:54 PM   #11
rlhott
Looking for a shifter for a Berg Warner sr4.
rlhott is offline   Reply With Quote Quick reply to this message
