broken shift lever 1978 CJ-5 - JeepForum.com
post #1 of 4 Old 12-31-2008, 01:33 PM Thread Starter
jimdubose
1978 CJ5
while i was removing the shift knob from my shift lever (to replace the hurst knob the previous owner had installed with a stock lknob i ordered on line and am awaiting in the mail), i accidentally snapped off the threaded part of the lever. i cleaned up the lever as best at i could at the break with a wire brush and am wondering is this a single piece of metal, or can the threaded part be removed using an 'easy out' or similar application and then replaced with a similar sized piece of all thread, or is this a solid piece and the whole lever needs replacing. although it cleaned up, it looks like it the threaded piece may have been introduced to a threaded opening at the top of the lever and then spot welded. anyone had any experience with this?
jimdubose is offline
post #2 of 4 Old 01-01-2009, 08:31 AM
Bubba Ray
A buddy had this same problem. We ground the remaining threads down to a flat surface and tig welded the correct threaded bolt to the lever. Any welding shop can do this for a few dollars.
Bubba Ray is offline
post #3 of 4 Old 10-17-2011, 01:43 PM
CJ7ROB
I snapped the knob off my T-176. I want to weld a small stud onto the end of the lever like stated above. Anyone know what the correct thread is for the knob on a T-176? thanks.
CJ7ROB is offline
post #4 of 4 Old 10-17-2011, 07:36 PM
cardiffclimber
1981 CJ7
Same thing happened to me. Since I don't own a welder (shame on me), I drilled and tapped a new stud in the top of the shifter.
cardiffclimber is offline
T-176 Shift lever removal holtmeier Jeep CJ Forum 9 10-17-2011 06:17 PM
1978 CJ7 T-150 shift lever fell off 4wheelHIGH Jeep CJ Forum 7 04-21-2009 12:40 PM
T-4 vs T-176 shift lever BioTex Jeep CJ Forum 17 10-15-2008 08:52 AM
Broken shaft that connects shift lever to T/C darwood112 Jeep CJ Forum 1 05-27-2008 03:16 PM
Shift Lever Needed GADJIT98 Jeep CJ Forum 1 06-10-2004 06:38 PM
