Broken seat mount bolts... HELP!! - JeepForum.com
post #1 of 15 Old 06-30-2013, 10:06 PM Thread Starter
Jeepn-n-tx
I went by Mike Honcho...
Jeepn-n-tx's Avatar
1981 CJ7
Hopefully someone smarter than me is reading this tonight ...
I just got all the eletrical gremlins fixed so my Jeep is finally ready to go get inspected. But .... when I removed the driver's seat awhile back IOT get to under the dash, two of the bolts broke. One has about a 1/4" of thread sticking up and the other dang near broke flush to the body.
I've tried ...
- Heat ... no dice
- Drilling them out and using extractors ... which they both broke off so now there's a really hard piece of metal in there to prevent further drilling
- welding a nut on, but I just can't get a good bead going inside the nut and I can't grind on/ clean up the broken bolt enough to get a good stick
The bolts are the two closest to the outside so as far as under the body goes, one is up inside the channel and the other located in a tight space between two channels.
I've been soaking them in penetrating oil for two days and nothing.
Really need help here as I need to get my seat back in IOT drive it down for inspection. Gotta do it tomorrow as it's my only day off this week and they'll be closed on Thrusday anyway. Thanks in advance!
Jeepn-n-tx is offline
post #2 of 15 Old 06-30-2013, 10:23 PM
pman
As a quick fix (which will create a bit of cleanup), could you simply run a weld along the one side of the bracket that has the broken bolts, just to get you through inspection?
88 Wrangler Laredo 258-999-NP231
81/76 CJ5 304-t150-Spicer 20
82 Wagoneer 360-727-NP208
82 CJ8 Scrambler 258-t5-Dana 300
pman is offline
post #3 of 15 Old 06-30-2013, 10:36 PM Thread Starter
Jeepn-n-tx
Jeepn-n-tx's Avatar
1981 CJ7
Like tack the seat bracket to the body?? .... I guess I could, but I'm squeemish about that idea ... HOWEVER ... it does give me the idea to place the seat bracket back in, throw on a washer to cover the holes in the bracket and then re-weld a couple of nuts on. Hmm ... I may have to try and build up that one bolt that's broken flush, but that just might do the trick. Thanks, Pman!
Please keep the comments coming just in case .... going to run out the the garage to try this one!
post #4 of 15 Old 06-30-2013, 10:36 PM
JeffreyCharles
1976 CJ5
How about a hole saw with a circumference larger than the embedded nuts? Cut the whole mess out. Then, weld in some new sheet metal with a new nut attached. Mount the seat using the other bolts so as to get the new bolt/sheet metal location correct, run the "new" bolts into the new nuts/sheet metal and then tack in the sheet metal from below. Rinse and repeat as needed.
Jeffrey Charles
http://jeep.smallcraft.net/
JeffreyCharles is offline
post #5 of 15 Old 06-30-2013, 11:09 PM Thread Starter
Jeepn-n-tx
Jeepn-n-tx's Avatar
1981 CJ7
I thought about that, but I think that may be my last step to take. Think ill be calling a friend to blow out the bolts with an oxy-torch and then retap the holes.
post #6 of 15 Old 07-01-2013, 08:41 AM
texas1al
I think you can probably still drill them out, even with the extractors broke off inside the bolts. It sounds strange, but use a masonry drill bit at low speed. Carbide tipped masonry bits combined with drilling oil/coolant will eat through hardened steel, albeit slowly. You may need a couple of bits to get the job done, but the cheap ones will work as long as they're carbide tipped. This approach will take a little patience, but it will be easier than the alternatives. Just remember to go slow (you can almost count the rpm's of the drill), but you'll see the bit gradually grinding out the metal.
texas1al is offline
post #7 of 15 Old 07-01-2013, 09:46 AM
82JeepCJ7
1982 CJ7
Heat the bolts (including the broken off ez-out) up with a torch until they glow orange. Let them cool and do it again. That will take the temper and hardness out of the extractor. Use a center punch and smack the center of the extractor. Some times they will shatter or break. If not, since they are softer now, drill them out. Work your way up with drill sizes until you get to where you can re-tap the hole to 7/16 and then put in new bolts.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #8 of 15 Old 07-01-2013, 11:34 AM
redsduty
1978 CJ7
Instead of welding a nut onto the broken bolt try welding a 2" x 2" piece of 3/16" or 1/4" steel on edge to the broken bolt. Then use a large adjustable wrench or a pipe wrench to remove it. This has worked good for in the past when the welded nut trick did not work. Good Luck.
redsduty is offline
post #9 of 15 Old 07-01-2013, 05:14 PM Thread Starter
Jeepn-n-tx
Jeepn-n-tx's Avatar
1981 CJ7
These are all awesome suggestions & I plan on putting them to use one by one.
I was able to get the seat in & get the jeep down for inspection today. We're all legal again and I'm already one tank of gas in the hole. I ended up tacking the seat frame to the broken bolts as they met up nicely. I didn't need that big a tack but it held all day. Should be good to go until I decide to tackle this one again.... Maybe later in the fall when winter rears is bastard little head.
Thanks again for all the help. ... That's why I love this forum....
post #10 of 15 Old 07-01-2013, 10:03 PM
pman
That's awesome! Heck, the heat you put on the broken bolts after the welding may be enough to make extraction of them easier now.
pman is offline
post #11 of 15 Old 07-01-2013, 10:38 PM
jeepwhore
Glad you got it inspected! But I'd be wanting to tackle those bolts as soon as you can. If Murphy rears his ugly head that tack will let go at the most inopportune time.
'84 CJ-7: Yota axles (spartan locked front, e-locked rear) 4" BDS, 1" Daystar & 3/8" shackle lifts, 35" X-Terrains on steelies, YJ Tub & family roll bar, heater blower upgrade, 4.2L w/MC2100 & Team Rush, Warn 8274. Rebuilt 4.2/4.0 hybrid, AX15 and twin sticks/clocking ring waiting to go in.
The advertised position for a topless, dirty jeep girl has been filled......by my wife. Thanks to all that applied.
<------------and yes, that is her.
:-D
jeepwhore is offline
post #12 of 15 Old 07-02-2013, 01:46 AM
RARECJ8
RARECJ8's Avatar
1981 CJ8
can you not just thru-bolt from seat frame to underneath tub-- some big fender washers and be done?
Look it's a 4.6!
Life member BRC
Cal4Wheel. ECV 3697
RARECJ8 is offline
post #13 of 15 Old 07-02-2013, 11:59 AM Thread Starter
Jeepn-n-tx
Jeepn-n-tx's Avatar
1981 CJ7
SHHH!!!! .... It'll hear you!
post #14 of 15 Old 07-02-2013, 12:09 PM
Hawk4097
I'd cut into the rail that its in underneath and grind the welded nut off and tac weld a new on in then weld in a piece of sheet metal to replace what you cut
Hawk4097 is offline
post #15 of 15 Old 07-03-2013, 09:56 PM Thread Starter
Jeepn-n-tx
Jeepn-n-tx's Avatar
1981 CJ7
Thanks Hawk ... I think breaking the weld on the nut underneath will be my next move after reheating the bolts and trying to extract them from below. I wouldn't mind keeping the original nuts in there and just cleaning them out with a tap if needed.
Thanks again for all the help guys.
