Broke off tap in head......crap - JeepForum.com
post #1 of 9 Old 03-15-2011, 06:43 PM Thread Starter
MrWonderful73
While installing my new aluminum valve cover I bottomed out a tap in the unthreaded holes in the head and broke it off about 1/4 below the surface. Anyone have any ideas or tricks for removal????
MrWonderful73 is offline
post #2 of 9 Old 03-15-2011, 06:46 PM
walkerhoundvm
1981 CJ8
Are you sure you're from Luck? Wish I could help you, but all I have is sympathy. I busted a main cap bolt in the block while changing out my rear main seal last year. Fumed for about a week before I got a reverse bit, EZ-out, and a six pack. Started with the reverse bit and the darn thing was loose the whole time. Spun it out with my pinky finger.
Just keep in mind: things are never as bad as they seem. These are jeeps, built by man and any problems you come across can be solved by man - even you! Best of luck.
walkerhoundvm is offline
post #3 of 9 Old 03-15-2011, 07:00 PM
John N
1981 CJ8
Try using 2 pin punches in the openings in the tap as a handle to back it out. You can put a wrench on the 2 punches to help turn them. If that doesn't work, use one of the pin punches to drive it around and back it out. Use plenty of lube. Good luck.
'81 Scrambler w/ FI 360 AMC, 33x12.50 BFG M/T's, 5" of lift, ARB'd Dana 44's F & R, Dana 300 clocked & twin sticked w/4:1, Warn XD9000i, etc...
2002 Grand Cherokee Limited, 2008 Overland Grand Cherokee, a 1976 CJ-7 in pieces and 3 more off-brand 4x4s...............
John N
John N is offline
post #4 of 9 Old 03-15-2011, 07:05 PM
gosupes
I have used removers similar to these with better than average results:
http://www.newmantools.com/walton/extrtap.htm
It's just a Jeep, and if you don't wheel it once in a while, it's not even that.
gosupes is offline
post #5 of 9 Old 03-15-2011, 07:33 PM
HighFive
1981 CJ5
Damn that sucks. Your tapping threads for a valve cover so it's probably a really small tap. Try fitting some thin needle nose pliers into the "tap openings" then twist it out with pliers?
[/color]
Let's go Flyer's!!!!!!
HighFive is offline
post #6 of 9 Old 03-15-2011, 09:02 PM
LibertyJeeper
I am putting that quote in my sig
Looking for axles 4.10's or higher
LibertyJeeper is offline
post #7 of 9 Old 03-15-2011, 09:06 PM
sbsg2005
I use one of them little spring loaded center punches with good results and have also use one of them vibrating engraving tools on little bolts
sbsg2005 is offline
post #8 of 9 Old 03-15-2011, 09:08 PM
walkerhoundvm
1981 CJ8
I tell myself that every time I muck something up. Which happens with some frequency. Yet somehow she still starts up in the morning.
post #9 of 9 Old 03-15-2011, 09:10 PM Thread Starter
MrWonderful73
Success!!!!!
Thanks everyone for the replies, I got it out. Ended up using a Snap-on "pencil" grinder (I think thats what its called I borrowed it..) with a small bit that looked like an end mill. I was able to grind out the middle and then break it up with a punch, picked out the pieces with a pick and a magnet. It took about an hour of grinding and swearing to get it out. Wow will I be more careful...........
Alternator belt broke now runs like crap. Dad03 Jeep CJ Forum 6 04-26-2009 08:40 PM
broke bolt off in head...suggestions? jadams68 Jeep CJ Forum 12 10-15-2006 06:44 PM
Broke the bleeder valve. Crap! gaa Jeep CJ Forum 1 02-05-2006 09:54 PM
Round Head Light Square Head LIghts? Daniel W Jeep CJ Forum 5 07-27-2003 08:25 PM
