Breather Hose Connection Adapter - JeepForum.com
post #1 of 1 Old 11-18-2013, 09:26 PM Thread Starter
jco6560
1970 CJ5
Hello,
I need a connecter that will push-plug into a valve cover breather opening (1 inch) and connect to part of the PVC system for a 1 inch hose (see picture - its the black thingy at the bottom of the hose from the oil bath) . Can't find the part or anything like it around here or at parts stores. Any homemade suggestions?
I have found one that will connect to a 5/8 hose, but finding a 5/8 to 1 inch hose connecter is not happening either. Also looked at some of the PVC baffled grommets - can one of those be run 'upside down' with the baffle sticking up above the valve cover to connect to a 1 inch hose?
Any of you with the V6 225 solve this problem or know of place to get the breather connector?
thanks,
James
jco6560 is offline
