Break lights? - Page 2 - JeepForum.com
post #16 of 40 Old 09-26-2013, 04:21 PM
imafishingfred
imafishingfred's Avatar
1981 CJ7
Just realized your a new member to the forum. WELCOME. While I don't have an answer to your brake light problem, I'm sure someone here will lead you in the right direction.
imafishingfred is offline
post #17 of 40 Old 09-26-2013, 04:23 PM Thread Starter
CourtneyUGA
Ah. I was wondering why I had a fuse spot for cruise but I have no cruise. Thanks! And also, "lumpygrits", thank you. That helped me trace a little bit more and understand what I was looking at with the two wires. There's a charlie foxtrot of wires that it leads into I'll go through to keep tracing once I figure out how to get my little hands in a smaller spot. Thanks for all the advice yall.
CourtneyUGA is offline
post #18 of 40 Old 09-26-2013, 04:27 PM Thread Starter
CourtneyUGA
Thanks for the welcome!
post #19 of 40 Old 09-26-2013, 04:49 PM
LumpyGrits
Court, You REALLY need to get a copy of the REAL Factory Service Manual(MR252).
It's well worth the cost and so much better than Haynes and the like.
Till you get a MR252, this may help some, even though there are no electrical schematics.
http://home.sprynet.com/~dale02/list.htm
LG
Have'n you along, is like loose'n 2 good men
LumpyGrits is offline
post #20 of 40 Old 09-26-2013, 05:23 PM Thread Starter
CourtneyUGA
I just picked up my Haynes. But I will certainly get the real manual. Thanks man.
post #21 of 40 Old 09-26-2013, 05:43 PM
LumpyGrits
Keep the Haynes in the Jeep and the FSM at home for big stuff.
LG
post #22 of 40 Old 09-26-2013, 08:17 PM
MoneypitCJ5
1977 CJ5
If it makes you feel any better, I'll be addressing the exact same problem this weekend...although my turn signals are sort of MIA too. I'll let you know what I find and maybe that will help you as well!
1973 VW Karmann-Ghia first car
2009 Challenger R/T 6MT, Flowmaster, inTune daily driver
1977 CJ5 304, 3MT - under construction
And many in between!
MoneypitCJ5 is offline
post #23 of 40 Old 09-26-2013, 08:21 PM Thread Starter
CourtneyUGA
Please and thank you! This will probably be my weekend, figuring this out between studying for an anatomy class!
post #24 of 40 Old 09-26-2013, 08:25 PM
MoneypitCJ5
1977 CJ5
In your case I still say it sounds like a bad turn signal switch, and I think that's what's wrong with mine. I'll try to take some pics to walk you through diagnosing it while I'm working on it.
post #25 of 40 Old 09-26-2013, 08:27 PM
LumpyGrits
Before you do anydangthing.
Ign OFF.........
Work the turn signal lever up and down about 50 times and now see is the t'sigs & b'lights are work'n.
Crud on the t'sig contacts will foul them up, quick.
LG
post #26 of 40 Old 09-26-2013, 09:10 PM
MoneypitCJ5
1977 CJ5
The issue I have is two fold. I know the plugs for the tail lights are badly worn so they don't make great contact. When I plug the turn signal switch in, my passenger brake light stays on, but the turn signal works on that side. The driver rear turn signal works but the front doesn't.
No brake lights at all. Parking lights and headlights function normally with the turn signal switch unplugged.
I recently swapped columns and I know the brake lights worked with the old one, but not the new-to-me one.
post #27 of 40 Old 09-27-2013, 08:39 AM
turbogus
1978 CJ5
Inkeeping with JeepHammer's posts I'd first check and possibly rewire the grounds to the negative side battery terminal. Apparently bad grounds are the primary cause of electrical failures/issues in our old CJ's. Ultimately I went with a grounding bus bar from a breaker panel and mounted it to my firewall near the battieries, ran a 8 gauge wire to the terminal then ran all my ground wires to the bus bar. It's been working great since!
The parts shop that stocks part for Skylab II will not have parts for our year/model of Jeep
We cannot accurately judge the trajectory of a speeding critter (cat, dog, sasquatch)
Record heat waves and floods only occur when we visit that area
turbogus is offline
post #28 of 40 Old 09-27-2013, 06:18 PM Thread Starter
CourtneyUGA
So I figured out what it was today. After tracing wires all yesterday and today nothing was wrong until I got to the back where it goes into my tail lights. Someone who had it before put trailer wires in and when they hooked them in with the brake lights they didn't connect a wire completely. The guy before me said he had the CJ for two years, never had brake lights and he never got to them (he fixed everything else, it has a motor in it with 8k miles on it and a 100k mile no questions asked warranty). Anyway, I took the trailer wires off and threw some sleeves on, crimped, back to how it's supposed to be. Good to go, brakes work!
post #29 of 40 Old 09-27-2013, 11:24 PM
MoneypitCJ5
1977 CJ5
Impressive! Maybe I'll have some luck tomorrow as well....maybe
post #30 of 40 Old 09-28-2013, 11:04 AM Thread Starter
CourtneyUGA
ha good luck. I still want to know what you find out so I can keep it in my brain for future reference!
breaks , cj7
