Brand New Rotors not true? - JeepForum.com
post #1 of 14 Old 01-06-2010, 07:03 PM Thread Starter
CJman77
1977 CJ7
Okay so got some brand new rotors from discount. And I have measured all over and have found it varies about .01 to .03 in diameter in different areas. I had a rub spot on the top edge of the rotor on my amc 20 disk conversion that was .03 "high". I filed the caliper bracket and its fine now.
My question is:
Is this normal?
I always thought brake rotors were made to exact tolerences? Am I wrong?
Thanks
Brian
CJman77 is offline
post #2 of 14 Old 01-06-2010, 08:22 PM
scooter
1982 CJ7
Im my experiance in say the last 10 years or so if you buy new rotors or drums and do not have them checked ad most likely turned you will not be happy. The exception is high dollar stuff,otherwise its all substandard import trash. This goes for new vehicles of all makes particulary Jeep and Ford who instally factory lacking parts that warp at the hint of heat or stress.
scooter is offline
post #3 of 14 Old 01-06-2010, 09:37 PM
JeepHammer
Running On Empty...
1973 CJ5
I have to agree.
I've often turned brand new rotors because they were turned incorrectly at the factory.
Import crap is just that, crap...
If you buy a $15 rotor, expect it to be poorly made and to warp at the first hard brakeing you do.
The rotors I use are about $40 each, but they usually don't have to be turned BEFORE you install them!
And they run true for quite a while.
REMEMBER,
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
LINK:
JeepHammer is offline
post #4 of 14 Old 01-06-2010, 09:56 PM
_Kyle_
_Kyle_'s Avatar
I got some $30 from Autozone that were pretty decent. But the lower the price, the lower quality you should expect.
-Kyle
1996 Grand Cherokee
2005 Wrangler Rocky Mountain Edition
RIP Troy (bigbluezj94)
_Kyle_ is offline
post #5 of 14 Old 01-07-2010, 12:05 AM
Cutlass327
Cutlass327's Avatar
1978 CJ5
Sad thing is the Chrysler/Dodge/Plymouth minivans in the mid-late 90's - $120 each, and just as cheap as the ones you'd get at Carquest or Napa for less than $30 each.
Seems they are all Chinese steel - pits and rusts by the time the first set of pads are worn out.
Rick
Cutlass327 is offline
post #6 of 14 Old 01-07-2010, 08:25 AM Thread Starter
CJman77
1977 CJ7
Jeephammer I spent 40. Bought it from advance instead of ChinaZone. Same cheap POS.
Where do you buy brake rotors?
CJman77 is offline
post #7 of 14 Old 01-07-2010, 03:14 PM
jkl
Years ago when I worked for Firestone, I would turn all new rotors and drums before installing them. Most were not true from the factory.
'13 10th Anniversary Unlimited Rubi
...now parting out
jkl is offline
post #8 of 14 Old 01-07-2010, 03:35 PM
kmm
Just went through this, Bought from CarQuest and had to have them trued up also.
kmm is offline
post #9 of 14 Old 01-07-2010, 03:54 PM Thread Starter
CJman77
1977 CJ7
These are almost like warped left to right. I dont think my axles are warped.
CJman77 is offline
post #10 of 14 Old 01-07-2010, 04:42 PM
Area.3.Fiftyone
Cheap rotors almost ALWAYS need to be turned.
I have never had a set of el cheapo's that weren't warped from day one.
.001 - .003 is acceptable runout from what I remember.
79' CJ7 - 82' CJ8 - 94' YJ - 96' ZJ
Diagonally parked in a parallel universe.......
Area.3.Fiftyone is offline
post #11 of 14 Old 01-07-2010, 10:37 PM Thread Starter
CJman77
1977 CJ7
I could get them turned I guess. But why put another 30 per rotor into these cheap things.
I could return them and buy made in the usa nice slotted (useless I know) rotors for 65 each.
CJman77 is offline
post #12 of 14 Old 01-08-2010, 10:19 AM
_Kyle_
_Kyle_'s Avatar
They carry a warranty anyways so I guess if they suck, you can always get another set...
-Kyle
1996 Grand Cherokee
_Kyle_ is offline
post #13 of 14 Old 01-08-2010, 11:19 AM
Area.3.Fiftyone
$30 to cut a rotor?
You're getting raped. It's only about $8-$10 per rotor.
Spend more money up front and you won't have to worry about warpage out of the box.
post #14 of 14 Old 01-09-2010, 12:15 AM
JKM3134
1983 CJ7
i recently had this same problem with my rear drums. replaced the pads and drums from autozone and i could not adjust them properly.
after a week of thought i took the drums to a shop and sure enough they weren't round out of the box. i had them turned for about 20 dollars and they work well.
JKM3134 is offline
Is it true? 69cj5 Jeep CJ Forum 8 06-03-2007 06:13 PM
Could this be true jeepe Jeep CJ Forum 13 11-18-2005 02:24 PM
is it true ? sandhog Jeep CJ Forum 1 07-11-2005 07:01 PM
true jdub_cj Jeep CJ Forum 1 06-10-2004 06:52 AM
is this true? jeepnut00 Jeep CJ Forum 6 03-02-2004 09:51 AM
