Brakes locking up - JeepForum.com
post #1 of 6 Old 05-01-2013, 04:27 PM Thread Starter
larock
1983 CJ7
Brakes locking up
83 cj7
Just got the jeep-79k miles. The guy I bought it from put around 1500 miles on it in about 7 years, so it has been sitting a good bit.
After about 15 minutes of driving the brakes lock up. Last time it happened we jacked it up and all
4 wheels were affected (disc front & drum rear)
When I first got it there was evidence of leaking rear wheel cylinders so both of them have been replaced with new shoes as well. The fact that it happens to all 4 wheels kind of rules out a crimp in the flexible brake lines.
I find I real peculiar that it only happens after driving for a little bit. Could it have something to do with engine heat having some sort of effect on the master cylinder?
Any help would be appreciated.
J
larock is offline
post #2 of 6 Old 05-01-2013, 05:40 PM
wellmax
something in your brake system is restricting the reverse flow of brake fluid.
if all 4 of your brakes are locking up, then as you said, I would rule out restricted or defective rubber hoses at first blush.
I would change out the master cylinder and start from there, if that does not fix the problem then rebuild all wheel cylinders and replace all rubber brake lines.
flush all old brake fluid,
at least that would be my plan, if these item replaced or repaired does not fix the problem, then it would be off to the mech shop
as you must have good dependable brakes to drive the jeep on the highway.
i
wellmax is offline
post #3 of 6 Old 05-01-2013, 08:07 PM
86cj74.2L
86cj74.2L's Avatar
Master cylinder is the first to get replaced.
86cj74.2L is offline
post #4 of 6 Old 05-01-2013, 10:54 PM
dandd
1982 CJ8
If your brakes are boosted check that the booster rod is releasing fully from the master cylinder. In mine I had to adjust the booster rod due to the MC never fully releasing pressure. During usage the brakes would build pressure until they lock up.
The spec was about 1/16" rod to MC plunger
dandd is offline
post #5 of 6 Old 05-02-2013, 03:08 AM
John Strenk
John Strenk's Avatar
1976 CJ5
I had a truck with a bad booster that would lock up the brakes after a few min of driving.
Quite annoying because I would have to shut the engine off to get it to release the brakes.
John Strenk is offline
post #6 of 6 Old 05-02-2013, 06:38 AM
JeePete
1983 CJ7
FWIW, mine always does this in the spring, after being stored all winter. I always attributed it to rusty drums (rears lock, not fronts). It stops after a couple of days driving....
However, this is not to say you have an issue.....
Just my .02
JeePete is offline
