brakes and gas lines - JeepForum.com
post #1 of 3 Old 09-07-2002, 07:03 PM Thread Starter
certifiablejeep
Bicentennial Nickel
certifiablejeep's Avatar
1976 CJ5
Where is the best place to get gas and brake lines?
I have a 76 CJ-5 that I just stripped down to the frame.
I just got the body off, dropped the gas tank, and yanked the exhaust pipes and manifolds. I air blasted the frame quickly to get off the majority of junk.
Frame is straight(except rear cross member, needs replacing), and everything else looks great. I want to replace the links to the brakes and gas tank after I get the frame sandblasted and por-15'ed up. So, if anyone has any suggestions, I would appreciate it.
Also, one last thing. It appears that the line from the charcoal canister? to the rear of the jeep was melted on the exhaust pipe. The hose was green. Is this original or no? I just thought it was a little strange. No idea how long this has been like this so I don't know if it could have caused any damage or not. I am just glad all that stuff is off, helps a lot when there is another person helping ya out.
peace.
cb
certifiablejeep is offline
post #2 of 3 Old 09-09-2002, 06:42 AM
Scrambler82
Scrambler82's Avatar
1982 CJ8
Cool
Stainless Steel !
Look in the back of Truck Mag and you will see different suppliers for pre-bent tubes ($$$).
My be Napa could supply S/S tubing and you could bend your own.
That's what I am doing.
Stainless is the only way to go, keep it high on the frame.
Good Luck,
Scrambler82
Do it right the first time !
Scrambler82 is offline
post #3 of 3 Old 09-09-2002, 11:26 PM
Jeep Daddy
Jeep Daddy's Avatar
4WD Hardware
Check 4WD Hardware. They have them for $169.99. The small soft lines are about $50 for the fronts. The rear is $40 or so.
2004 Rubicon, 6" lift, 35s, winch, hard top, full doors, bumpers, tire carrier and rock sliders.
Jeep Daddy is offline
routing of lines from master to valve on cj7 power brakes nicknoty Jeep CJ Forum 0 07-28-2009 09:25 PM
Weber 34 conv, nutter, Vacuum lines / Fuel lines valkadesh Jeep CJ Forum 29 06-11-2007 09:21 AM
What is this part that all my brake lines come in to, and no fluid on front brakes? part.changer Jeep CJ Forum 37 04-23-2007 04:15 PM
Running auto trans lines...use braided or hard lines? Pacfanweb Jeep CJ Forum 7 08-15-2006 10:07 PM
brake lines, gas lines, which order certifiablejeep Jeep CJ Forum 6 06-30-2003 04:03 AM
