Brakes????? - JeepForum.com
post #1 of 7 Old 03-22-2003, 05:38 PM Thread Starter
RHRacing
Brakes?????
Anyone have any idea why when i brake too hard the car dies??
Or more importantly why i see sparks when i brake??
Ben
1981 CJ7 - In lots of pieces... in process of build up
4.5" Rubicon Express LIft kit (still on frame)
35x12.5x15 BFG Mud Terrain tires on 15x10 rockcrawlers (still on stock axles waiting for Dana 44's to be rebuilt)
Chevy 305 - Lunati RV cam, stock heads w/slightly cut valve springs
SM465 tranny and NP205 t-case awaiting rebuild
flattie fenders cut front bumper
RHRacing - "We always come first"
RHRacing is offline
post #2 of 7 Old 03-22-2003, 07:12 PM
CJeep
Alpha dog
CJeep's Avatar
1982 CJ8
for the first one, it's likely a carb issue, a hard stop will slosh the fuel, and if you are clutching, the Carter carb is famous for the ability to stall due to a likely clog in the idle tubes. Do a search here or on google, and you can make your Carter run good.
Edit: also check for vacuum leaks
As for number two, I'll just assume you are kidding.
'82 Scrambler - NV4500/4.5" lift/33" Toyo MTs/4.0/twin stick, and my windshield washers work! Full 1/2 cab Cage
2004 Grand Limited 4.7 HO - OH Boy!
2010 Grand Laredo 5.7 Hemi - SICK - back for a second time!
"Both my Doberman and my Jeep can accurately be described as 'black and rust.'"
CJeep is offline
post #3 of 7 Old 03-23-2003, 05:58 PM Thread Starter
RHRacing
hate to tell you but deffinately not kidding. i never saw it but my friends did as i drove away and above my feet when i braked
RHRacing is offline
post #4 of 7 Old 03-23-2003, 06:46 PM
jadams68
jadams68's Avatar
Well it may have nothing to do with braking, but maybe those sparks are eminating from your starter. My buddy's CJ tossed a bunch of sparks when he would turn the car over. We swapped the starter out...
The stalling is definitely the carb.
I used to own two CJ's...Perhaps a 3rd is in the future?
jadams68 is offline
post #5 of 7 Old 03-23-2003, 08:35 PM
pontiac58
1980 CJ7
Are you metal to metal.
pontiac58 is offline
post #6 of 7 Old 03-24-2003, 11:40 PM Thread Starter
RHRacing
i don't think so my uncle just replaced the brakes
the sparks were comin from above my feet my friend said(above the petals)
RHRacing is offline
post #7 of 7 Old 03-26-2003, 12:26 AM
bowhunter
check for any loose wiring under or around that area
bowhunter is offline
Need opinion....Manual Brakes/360 to Power Brakes Rollbar Jeep CJ Forum 16 04-08-2009 11:06 PM
cj brakes to power brakes worth it? drunkenrich Jeep CJ Forum 21 02-15-2008 03:25 PM
Manual brakes to power brakes theclothman Jeep CJ Forum 17 06-18-2007 05:40 PM
Manual brakes to power brakes. NOVACAIN350 Jeep CJ Forum 4 04-27-2007 09:16 PM
Hydraulic brakes to power brakes question Jeep'N 4 Fun Jeep CJ Forum 5 03-05-2003 11:00 PM
