brakeline repair question - JeepForum.com
post #1 of 7 Old 08-15-2013, 02:45 PM Thread Starter
CJ-junky
We've been rebuilding the front end on our 86 CJ7. Made great progress with some key help from the forum.
Last hurdle seems to be the removal of the flex brake line at the frame end. The joint is pretty rusty, and we cant break it free. I'm assuming that I can't apply heat, and that PB breaker won't do much to this fitting.
Any ideas?
CJ-junky is offline
post #2 of 7 Old 08-15-2013, 02:53 PM
LumpyGrits
Be carefull with the heat. That part is spring steel.
Soak it with WD-40 overnight and give it a try. That worked for me yrs ago.
LG
LumpyGrits is offline
post #3 of 7 Old 08-15-2013, 05:24 PM
82JeepCJ7
1982 CJ7
Grab the nut part on the hard line with some vice grips. A wrench is only going to round it off.
Beat it to fit, paint it to match!
Wheel, Wrench, Repeat.
82JeepCJ7 is offline
post #4 of 7 Old 08-15-2013, 09:30 PM
Spieg8
1984 CJ8
Irwin Vise-Grip part# 4LW
Best brake line wrench made IMO. Won't scuff or chew up nuts like a standard vise-grip.
Spieg8 is offline
post #5 of 7 Old 08-16-2013, 08:13 AM Thread Starter
CJ-junky
That looks great - I'll try to find one around here. Thanks.
CJ-junky is offline
post #6 of 7 Old 08-16-2013, 07:06 PM Thread Starter
CJ-junky
That vise grip worked perfectly. No big box store had any around here, but I did find a Irwin 7LW at a local hardware store. I just placed a square nut on one jaw to make up for the fact that this wrench is larger than the one that you mentioned. THANKS Speig8.
CJ-junky is offline
post #7 of 7 Old 08-16-2013, 07:47 PM
Spieg8
1984 CJ8
Glad it worked out for you. Pretty creative idea using a nut as spacer for the larger size tool.
Spieg8 is offline
