Brake questions - JeepForum.com
post #1 of 5 Old 05-31-2013, 10:53 PM Thread Starter
caseypotts
1980 CJ7
Brake questions
Two questions... I've been struggling with break issues since putting a ton of work into my CJ. Prior to the work it had mostly been sitting for about 3 years.
I did NOT have any issues until I changed out my front lines. The do not appear to be leaking. I bled and bled and then bled some more and never maintained pressure. I came to the conclusion that my problem was the master cylinder and bought a reman master cylinder. It is now leaking between the master and the booster. Is this a bad master cylinder?
Second question. My brake light is always on in the speedo. I'm not sure the above is connected. Is there an adjustment on the parking brake that I am missing?
1980 CJ7 GM151 Bored out, Flat Top Pistons, Hedman Header, 2.5in Superlift springs, Extrem Shocks' 31 10.5 Mastercraft Courser MT tires on Allied MockLoc rims, Blazer heater upgrade.
Her Ride
2003 Liberty Renegade
caseypotts is offline
post #2 of 5 Old 05-31-2013, 11:58 PM
RenoF250
Yes, it should not be leaking there. Did you possibly damage when installing?
How were you bleeding the original MC?
I have the light problem also, there is a wire on the back of the emergency brake pedal that is pretty hokey. My is usually on but flickers, I just ignore it, I have bigger problems to deal with on it.
RenoF250 is offline
post #3 of 5 Old 07-15-2013, 09:58 AM
Jsadamson1
On the late 70's cj and newer, I believe there is a sensor on the brake pressure divider block that will also trip the brake light if there is air in the line. I remember reading about it when I was doing my rear brakes the other day.
Follow my Jeep Builds!
jeepbuilds.blogspot.com
Jsadamson1 is offline
post #4 of 5 Old 07-15-2013, 11:09 PM Thread Starter
caseypotts
1980 CJ7
Sorry meant to respond back to this a got busy with other things. Thanks for the responses, I still have the same issues going on as I haven't had time to work on it the past couple weeks but I think...I think I have found my air issue. I bled the m.c. per the instructions. I'm thinking maybe there is remaining air in it and now that I solved my leak problem I just need to bleed the system again. With any luck my brakes will work and that damn light will go off. Then I can move on to my next problem
Her Ride
post #5 of 5 Old 07-16-2013, 03:53 AM
BagusJeep
1981 CJ7
Are you holding back the Combination Valve???
Are you following the bleeding procedure in the FSM?
Have you taken the front calipers off, because you can swap them and not realise the bleed nipples are upside down and it will not bleed out all the air.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
