Brake proportioning valve and bleeding brakes - JeepForum.com
post #1 of 4 Old 02-22-2013, 09:26 PM Thread Starter
jurgen24
I'm trying to bleed my brakes and have not had 100% success yet, even when following the front-back-front procedure. I find that I can't fully depress the pedal when bleeding the rears.
In the FSM is says to depress the proportioning valve with special tool (J-26869), I plan to do this with a clamp, but when I look at the valve, it only sticks out about 1/32". Is this all it sticks out? Can someone pls have a look at theirs and tell me know long it is.....sorry for the personal question
jurgen24 is offline
post #2 of 4 Old 02-23-2013, 12:37 AM
Bigjonh
1982 CJ7
yea that's about right, doesn't stick out much and doesn't travel in very much either. I'd say travel was less than 1/4 inch on mine.
Bigjonh is offline
post #3 of 4 Old 02-23-2013, 01:03 AM
carnuck
1984 J-Series Truck
There are W and S valves. Look at http://oljeep.com and it will explain which is push and which is pull. If you follow the lines up to the master cyl, then undo the one closest to the button while someone is pushing the pedal and the button should pop up about the time they hit the floor. (the fluid will eat paint!)
Tighten the line and see how the brakes feel. Also, manually adjust all the brakes (assuming drum) and make them drag a bit. Hit the brake and adjust them again (you have to center them to get the adjustment correct)
"Usually found in a Jeep near Reiter, WA"
FOR SALE STUFF
'81 Eagle wagon with upgrades $2500
'87 Comanche shortbox 4.0/AW4/NP242 on 33" tires $3500
carnuck is offline
post #4 of 4 Old 02-23-2013, 04:11 PM Thread Starter
jurgen24
I gave it another go front-back-front, now pedal is nice and firm, and back bled OK. I never touched the prop. valve.
jurgen24 is offline
