brake proportioning valve - JeepForum.com
post #1 of 4 Old 06-29-2003, 01:09 PM Thread Starter
certifiablejeep
Bicentennial Nickel
certifiablejeep's Avatar
1976 CJ5
2 questions.
First, is there a difference for valves on power vs. non-power brake systems.
And secondly, what is the ordering of the lines as they come into the valve.
I was outside today and tried to put on the stainless lines that I got to my 76 CJ-5 and I was having some issues as to what lines went into where on the valve. Also, the stainless kit had the 2 lines that go to the master cylinder and one was larger then the other where it attaches to the valve. The problem I have is that my valve has all the same size openings.
thanks,
cb
CertifiableJeep
'76 ORANGE
'76 MAROON
'78 SILVER
'82 WHITE
Build
'83 GREEN
Build
ORANGE JEEP CLUB #41
SILVER JEEP CLUB #41
SIENNA JEEP CLUB #62
RHD JEEP CLUB #41
NEWJO Member
certifiablejeep is offline
post #2 of 4 Old 07-15-2003, 07:34 PM Thread Starter
certifiablejeep
Bicentennial Nickel
1976 CJ5
OK, since no one answered this, I went out and got a valve from a 79, now I have 2. One that has an angle that goes toward the front and one that does not. One installs with 1 screw and the other installs with 2. So, now I am confused because the pre-bent stainless lines from the rear has an upwards bend in it but no where to put it underneath.
Can anyone provide a picture of a power brake proportioning valve from a late 70's CJ-5?
Thanks,
cb
CertifiableJeep
'76 ORANGE
'76 MAROON
'78 SILVER
'82 WHITE
Build
'83 GREEN
Build
RHD JEEP CLUB #41
NEWJO Member
post #3 of 4 Old 07-16-2003, 08:43 PM
mean green
i don't have a picture but i know on mine i had 2 different sise lines and my valve were all same size holes but 1 so i just got brass reducers to make it work i can't remember if that was the way i got or not but works
1985 cj-7,256, t-176,dana 300, dana 44's f & R ,detroit lockers f&r, 4.09 gears, soa with 4"suspension lift,2" shackle extention,shackle reversal,custom 3"x5" straight frame, custom roll cage with tire rack above, fiberglass body,35"s.s boggers,ramsey 8000lb winch
mean green is offline
post #4 of 4 Old 07-16-2003, 10:08 PM Thread Starter
certifiablejeep
Bicentennial Nickel
1976 CJ5
that is a good idea, but instead of a reducer, I need an increaser!
The one I have has all the same lines, but one of the stainless lines I have it bigger.
thanks for the info.
CertifiableJeep
'76 ORANGE
'76 MAROON
'78 SILVER
'82 WHITE
Build
'83 GREEN
Build
RHD JEEP CLUB #41
NEWJO Member
Brake Combination Valve/Proportioning Valve Question Wrangler1642 Jeep CJ Forum 1 01-17-2011 05:43 PM
Brake Proportioning Valve OoIIIIIIIoO Jeep CJ Forum 8 10-18-2009 12:05 PM
Brake Proportioning valve only in a jeep cj Jeep CJ Forum 4 03-27-2007 11:39 PM
Brake Proportioning Valve CJ5_Fan Jeep CJ Forum 4 06-27-2005 05:03 PM
Brake Proportioning Valve Lightningdon Jeep CJ Forum 1 08-30-2003 06:49 PM
