Quantcast Is this the Brake Prop Valve I need? - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Is this the Brake Prop Valve I need?
Old 02-11-2009, 01:09 AM   #1
jfite
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWAX:IT&it em=150325266036
Hey, I have an 84 CJ7 and am going to replace the BPV. I was wondering if this is the right BPV. It is much cheaper than the ones in the online stores! Just checking, thanks in advance!
jfite is offline   Reply With Quote
Old 02-11-2009, 01:10 AM   #2
HackFabrication
1976 CJ5
Bad link.
www.inlinetube.com you need the VML101 for a disc/drum setup. Order the brakelight pigtail too.
"In the end...It's all Hack."
HackFabrication is offline   Reply With Quote
Old 02-11-2009, 01:19 AM   #3
jfite
Yeah, that was some GM valve after looking at it a bit. Alot cheaper though! Sorry about the bad link.
Old 02-11-2009, 07:53 AM   #4
JeepHammer
Running On Empty...
1973 CJ5
I think the last one I had to install came from a '85 Chevy S-10 Pickup.
Anyway, it had the same size fittings all the way around as the Jeep unit.
JeepHammer is offline   Reply With Quote
Old 02-11-2009, 08:06 AM   #5
mjp83
2011 JK Wrangler
Bought a YJ vlavle from a fellow jeeper here online. I am also upgrading, and will mount mine directly under the MC, to keep it away from heat.
New YJ vlave: 89.99 (link from HackFabrication), new one on ebay from dealer (guy bought it and sold jeep) start: 80.00, or used at about $25 - 30 local junkyard.
JeepHammer: Could not find the S-10 valve at autoparts store, so I decided to go with used YJ valve.
mjp83 is offline   Reply With Quote
Old 02-11-2009, 09:28 AM   #6
jfite
JeepHammer I was looking at that and wondering, because they look the exact same. I guess I'll call that place, because the valve is about 50 bucks cheaper.
Old 02-11-2009, 10:12 AM   #7
JeepHammer
Running On Empty...
1973 CJ5
That's why I use them.
Valve for a 'Jeep' is about $200 for a quality 'Replacment'.
The valve for a GM S-10 is about $50 or $60.
Junk yards are full of them also.
Old 02-11-2009, 10:24 AM   #8
jfite
So will this work on my 84 CJ7 and do you have the number for the S10 BPV? Thanks so much!
Glock Forum
