Quantcast Brake Problems - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Brake Problems
JcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!JKS products - Free shipping! Lowest prices!East Coast Gear Supply- Quality Diff Parts
Old 12-08-2008, 10:10 AM   #1
gwalls
1979 CJ7
Brake Problems
Finally drove Jeep after 2 1/2 years of rebuilding. Put about 20 miles on it Saturday. Right front brake is dragging and overheating and causing it to lock up. I've got new stainless steel lines and proportion valve from inline tube. New rear wheel cyclinders and all brake hardware. New Power Booster. Rebuilt master cyclinder and front calipers. The Proportion valve is really close to my inframe Headman Headers. Would Proportion valve getting too hot cause the right front caliper to stick or is it just a bad caliper and it sticking? Thanks for any advice.
gwalls is offline   Reply With Quote
Old 12-08-2008, 11:20 AM   #2
Saltydawg1
1983 CJ7
Sticking caliper would be my first guess.
Saltydawg1 is offline   Reply With Quote
Old 12-08-2008, 11:34 AM   #3
gwalls
1979 CJ7
Thanks. Just don't really know how proportion valve works. Was wondering if fluid could be getting too hot and causing expansion and pushing on caliper.
Old 12-08-2008, 12:10 PM   #4
jatepper
jatepper's Avatar
I dont think the fluid would be getting too hot. Do you have a brake warning light in your cluster? Does it come on? If it comes on, it is likely a prop valve problem. IMO
1985 Jeep CJ-7
Automatic-258 I6- Detroit lockers front/rear - Superior 1-piece axles, Ramsey Pro 9000 Winch, Quick Disconnects, 33 BFG AT's, 4.10 gears, Howell TBI, DUI HEI Ignition, Ground Pounder Rear Bumper / Tire Carrier Combo, Handen Fab integrated winch plate front bumper w/hoop, ORF weld-in front sport cage.
USMC 1999-2004 Semper Fi!
Torchmate CNC Plasma Table Build / Projects
Handen Fabrication
jatepper is offline   Reply With Quote
Old 12-08-2008, 02:32 PM   #5
gwalls
1979 CJ7
Brake warning light not hooked up. I put in a new Painless wiring harness and then when I had to replace the proportion valve the old harness was a 2 wire hookup and the new valve is a 1 wire hookup so not really sure how to hook this up.
Old 12-08-2008, 03:11 PM   #6
Mike Romain
Off Road Forever
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
The rubber line from the steel one to the caliper can separate internally acting like a valve which can cause that. How old are they?
Mike
86/00 CJ7 Laredo, 33x9.5 BFG AT's, 'glass nose to tail in '00, 'New' frame,wires and plumbing in '09. Carter BBD Carbed 4.0 HO in '10. Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote
Old 12-08-2008, 03:50 PM   #7
gwalls
1979 CJ7
Not sure about the rubber lines. Will have to look at that tonight. Thanks
Old 12-09-2008, 10:37 AM   #8
gwalls
1979 CJ7
Pulled wheels last night. Seems as both sides are sticking but passenger side is worse. Would the fluid boiling next in lines next to the headers cause the fluid to expand and put pressure on calipers? Also if the fluid got to hot does it need to be changed out? If I pull the caliper off the wheel spins free. If I push the piston back in and remount it still spins free. But after driving for a while it sticks and causes the wheel to be hard to spin.
Old 12-09-2008, 10:48 AM   #9
MikeMCJ
what year CJ? Did it once have drums? There may be a residual backpressure valve that is keeping too much pressure in the lines. I'm no expert at Jeep brakes, but I am pretty sure there are 2 different backpressures based on drum (10 psi) or disc (2 psi). Discs need less pressure as they don't have to deal with return-spring tension.
I'm currently collecting parts for a knuckle swap and power brake booster/mc/p.valve from a wide track (got the axle parts and picked up the booster/mc/p.valve last night), so I would like to hear from the people that have done the research so I don't end up PO'd because I didn't assemble the right parts the first time.
MikeMCJ is offline   Reply With Quote
Old 12-09-2008, 10:52 AM   #10
esearscj7
1983 CJ7
I second what Mike Romain suggested about the rubber brake lines. I had that happen to 2 cars. If they are old that is most likely the problem.
esearscj7 is offline   Reply With Quote
Old 12-09-2008, 10:54 AM   #11
Saltydawg1
1983 CJ7
Mike brought up a good point about the rubber lines. Those are the second thing I'd check after looking for a sticky caliper.
If it's only one wheel sticking the problem is usually a rubber hose or caliper.
If both wheels up front or in the back are acting up then you may have proportioning valve or master cylinder problems.
Brake fluid is designed to handle high temperatures very well. Its still possible to have heat soak problems but I would make sure your rubber hoses and calipers are in good shape first.
I had just assumed that since you replaced pretty much everything else you would have naturally done the rubber hoses. It is a pretty common problem to find among aging vehicles and ones that have sat for a long period of time.
Old 12-09-2008, 11:01 AM   #12
Mike Romain
Off Road Forever
The headers could be an issue, but the pressure would go away when they cooled down.
Did you put a new master cylinder in? They make two flavors, the one for drum brakes will cause the calipers to load up like that and drag. I have seen the wrong one in the box also...
Mike
Old 12-09-2008, 11:08 AM   #13
gwalls
1979 CJ7
The rubber lines were replaced with new braided lines. Rear wheel cyclinder, inline tube stainless prebent lines and proportion valve, booster: all new. Calipers rebuilt from Advance auto parts. Master cyclinder rebuilt from Oreilly's. They seemed to match the old factory one when pulled out but no way to tell now as I've returned them for core. The right front sticks to the point I can almost not turn it by hand. The driver side wil turn but still dragging more than it should.
Old 12-09-2008, 11:18 AM   #14
Mike Romain
Off Road Forever
The only thing in the system that is supposed to 'hold' a back pressure is the master as far as I know. If they have the wrong valve in there it will hold too much.
Mike
Old 12-09-2008, 11:28 AM   #15
MikeMCJ
exactly, a residual pressure valve, most often incorporated into the MC.
I doubt the heat has anything to do with it. ever see how hot cup car's rotor gets at a short track? brake fluid boils, but it would act spongy
my guess would be the MC. I do not suspect the proportioning valve.
Glock Forum
