Brake problem - JeepForum.com
post #1 of 5 Old 05-24-2003, 12:34 PM Thread Starter
rok_toy
rok_toy's Avatar
Brake problem
I finally got that D44 under the front, finished bolting everything up!!
Here's the problem... I went through the brake bleeding process three times.(I've done this a zillion times before)
No air coming out, thought it was done?
I have absolutely no brakes, the pedal goes to the floor. I can't find any leaks, I'm not losing fluid.
I just put a new master on, still nothing!!
Any help................. PLEASE!!
I gotta do some wheeling soon or I'll go insane!!
1986 CJ-7, 258/T5/Dana300, Dana 44's, 4.89's, ARB's, SOA, Warn8K, high-steer, 37" MTR's, onboard air( york style)...more to come!!
rok_toy is offline
post #2 of 5 Old 05-24-2003, 06:06 PM
jadams68
jadams68's Avatar
Sounds to me like the new master cylinder is shot.
If you have no brakes and you're experienced with bleeding them correctly, I'd have to go with the mast. cyl.
I used to own two CJ's...Perhaps a 3rd is in the future?
jadams68 is offline
post #3 of 5 Old 05-24-2003, 06:24 PM Thread Starter
rok_toy
rok_toy's Avatar
master?
It did the same thing before I put the new master on!!
Thanks for the tip, but I can't help but think something is screwy somewhere.
The stock master should provide sufficient volume for the chevy calipers, right?
I'm totally stumped!!! Don't even know what else to check.
All new parts:
master cylinder
calipers
pads
lines
rotors...
rok_toy is offline
post #4 of 5 Old 05-25-2003, 10:34 AM
rustyCJ
the prop valve might being doing this some how, not really sure how it could though. like you i would guess the stock master isnt pusing enough for the chevy calipers.
"character is doing the right thing even if nobody is looking"
rustyCJ is offline
post #5 of 5 Old 05-26-2003, 03:05 PM Thread Starter
rok_toy
rok_toy's Avatar
Porportioning valve??
I think I narrowed it down to the porportioning valve.
A buddy told me There is some type of safety valve that keeps fluid from going to either end of the brake system, if there's a leak or problem.
He told me the safety valve( inside the porp. valve) has to be returned to the centered position. So the brakes will work properly.
Here's my question:
How so I get the valve reset?
Please let me know if you have any ideas.
Thanks fellow wheelers.
rok_toy is offline
Brake Problem - First pump hardly any brake wigsajumper Jeep CJ Forum 15 06-25-2009 12:25 PM
CJ7 brake problem buzzbrick Jeep CJ Forum 4 12-10-2008 12:03 PM
Brake problem! reedler Jeep CJ Forum 17 12-10-2005 03:24 PM
Brake problem jtroutman Jeep CJ Forum 2 05-01-2003 10:03 AM
brake problem onesojourner Jeep CJ Forum 1 08-18-2002 02:56 PM
