brake pedal stick when pressed down - JeepForum.com
post #1 of 10 Old 11-03-2013, 10:29 AM Thread Starter
my1986cj7
After replacing my brakes master cylinder the pedal wants to stick. I have to pull it back up with my foot. I have tried wd40 on the linkage and on the shaft of the master cylinder connected to the peddle but no luck. I check the spring and it is connected but seem not stiff enough for the new cylinder. Is it possible the new ones are stiffer. I replaced the old one because the old one was leaking. Any ideas?
my1986cj7 is offline
post #2 of 10 Old 12-01-2014, 11:01 AM Thread Starter
my1986cj7
Ok, I still need help with this. I have the whole dash and steering wheel down with no pressure on the pedal. The master cylinder disconnected to the pivot point on pedal. Shouldn't this pedal move freely like the clutch pedal? The problem is the brakes worked fine till I replaced the master cylinder. I have bench bleed the master cylinder twice now to make sure all the air is out of it. Confused in Missouri.
post #3 of 10 Old 12-01-2014, 12:33 PM
lucdog
lucdog's Avatar
1980 CJ5
Does the brake pedal work good without the actuating rod connected?
Power brakes?
When you bench bled, did the plunger come back on its own?
1957 WILLYS pickup,
1973 J 4000,
1978 CJ7 DD.
1979 J20
1980 CJ5 trail Jeep.
1983 CJ7
1989 YJ the CJ to YJ.
lucdog is offline
post #4 of 10 Old 12-01-2014, 01:37 PM Thread Starter
my1986cj7
Power brakes?
No it is stiff even with out the actuating rod connected. I just got the whole assembly out an hour ago and the clutch moves freely but the brake is stuck solid they should be able to move independently from each other correct?
Also when I bench bleed the cylinder I used the plugs that came with it and bleed the air out of it that way. The fsm says to use hoses connected to the holes routed back to the top of the cylinder?? How far should the plunger move on the cylinder when bleeding on the bench mine only moves about 1/2 inch. I have tried to disassemble the assembly but haven't had any luck, other then mess up the thread a little bit on the bolt that goes though the assembly. I've sprayed half a can of nuts off on this thing maybe it will come apart. I have had the brakes working but you have to use your foot to pull the brake pedal up to release the brake and that was a pain in the aZZ. sorry for the book just trying to remember every thing that I have done.:bric kwall
post #5 of 10 Old 12-01-2014, 08:13 PM
BagusJeep
1981 CJ7
You should have two springs inside the master cylinder so when you take off the snap ring at the front which retains the assembly in there the plungers / pistons should just pop right out.
Also, I am not aware of there being a threaded rod that goes through the master cylinder. There is a push rod that goes through the boot and oushes on the curved surface of the front of the primary piston assembly but that is it.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #6 of 10 Old 12-02-2014, 06:03 AM Thread Starter
my1986cj7
The bushings where froze up on the pedal assembly. Now I need to find a new assembly pin, and buy some new bushings to reassemble the pedal assembly. I have found the bushings but not the pin that goes though the bushings for the clutch and brake pedal assembly. Anyone know where to find one?https://www.google.com/search?q=clut...0CAgQhxw&dpr=1 the pin I need is #5 in this picture in this post.
post #7 of 10 Old 12-02-2014, 10:03 AM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
I found the bushings at Quadratec don't see the pin. You may have to buy the whole assembly, or find one that can be parted out.
Or you could pull out the whole assembly, take it apart, and see if the pin can be salvaged. If it is worn, maybe it could be welded, ground, and polished. Or maybe a machine shop could make a replacement part based on the old one.
Do you have any photos of the current pin?
"I give you a republic, if you can keep it." - Benjamin Franklin
Ken4444 is offline
post #8 of 10 Old 12-02-2014, 10:22 AM
Ken4444
Corripe Cervisiam
Ken4444's Avatar
Does the part look like this?
Ken4444 is offline
post #9 of 10 Old 12-02-2014, 10:26 AM Thread Starter
my1986cj7
Thank Ken I bought an assembly off of Ebay and I had to destroy the old one to get it out it was so rusted. I've already looked at all the parts places and none have the pin just the bushings. I thought about the machine shop to guess I will have them make me a new one to have a spare on hand.
post #10 of 10 Old 12-03-2014, 12:42 PM Thread Starter
my1986cj7
Close but no nut in middle thanks though.
