Brake Pad Problem - JeepForum.com
post #1 of 4 Old 04-28-2013, 12:58 PM Thread Starter
RDH
Brake Pad Problem
The pad life on my brakes are completely exhausted so I ordered a new set of pads for it. I get them to the house and the length of the pads is too short to fit the caliper/caliper bracket. Is there an alternate vehicle I can look up for my brake pad needs? The caliper is held on with a slide pin that has an allen head retaining bolt. Damn me for putting all my eggs in one basket. Haste is appreciated, I need to be able to drive this thing to work tomorrow.
1978 CJ7: 304, 3Spd, AMC 20 Rear, Thrush Welded Mufflers W/ Turndowns, Unknown Front, Worn out Dana 20 case
RDH is offline
post #2 of 4 Old 04-28-2013, 02:01 PM
skizriz
1978 CJ7
There is a 2 bolt caliper, and a 6 bolt caliper.
Verify which one you have by the mounting bracket. They take different pads.
You should have the 6 bolt, newer years used the 2 bolt, but somebody could have very well swapped out the axle. '78 was also a year of mix and matching of leftover parts.
skizriz is offline
post #3 of 4 Old 04-28-2013, 02:15 PM
Matt80cj
1980 CJ7
i had a similar problem putting brakes on my 80 this winter. I finally got part # D90 from O Reilly's. I first got #SC52 which was completely wrong. I even told them 2 bolt calipers.
Matt80cj is offline
post #4 of 4 Old 04-28-2013, 03:49 PM Thread Starter
RDH
I figured out I have the late 78 brakes. AutoZone PN D52. I'd still like to know what vehicle these brakes originally were equipped for.
RDH is offline
