brake lines, gas lines, which order - JeepForum.com
post #1 of 7 Old 04-20-2003, 06:34 AM Thread Starter
certifiablejeep
Bicentennial Nickel
certifiablejeep's Avatar
1976 CJ5
I just finished sand blasting and painting up the frame, now I need to put on the new lines and was wondernig from top to botom on a 1976 Jeep CJ-5 304, what order do the lines go in or does it matter.
When I bought the Jeep there were some remnants of the lines on the driver side inside frame rail, but I can't seem to find the pics.
Also, where do I get the little holders/separators that were on there. the ones that are left are rotted.
Thanks,
cb
CertifiableJeep
'76 ORANGE
'76 MAROON
'78 SILVER
'82 WHITE
Build
'83 GREEN
Build
ORANGE JEEP CLUB #41
SILVER JEEP CLUB #41
SIENNA JEEP CLUB #62
RHD JEEP CLUB #41
NEWJO Member
certifiablejeep is offline
post #2 of 7 Old 04-20-2003, 07:35 AM
79Renegade
Here is a picture of mine that I just completed, installed stainless fuel and brake lines. I put the brakes lines on first then the fuel lines over the top. I fabricated a couple clamps and found the rest(electrical clamps) at my local hardware store.
All the lines run down the left (drivers) side of the frame.
The rear line goes to the crossmember above the axle and then a hose goes from there to the junction block on the rear axle.
I spent the extra and went with the pre-bent lines which made the installation process a lot easier and quicker. I was going to bend my own but my old lines were pretty much history and didn't have much left to follow. Plus I'm planning on keeping the jeep and went with stainless for the long term life.
I can take more pics if you need.
Greg
79Renegade is offline
post #3 of 7 Old 04-20-2003, 05:59 PM Thread Starter
certifiablejeep
Bicentennial Nickel
1976 CJ5
that is exactly what I was looking for. I am/was in the same boat as you. I didn't have much to go by and now I can use this as a guide. Thanks!
cb
CertifiableJeep
'76 ORANGE
'76 MAROON
'78 SILVER
'82 WHITE
Build
'83 GREEN
Build
RHD JEEP CLUB #41
NEWJO Member
post #4 of 7 Old 06-29-2003, 12:51 PM Thread Starter
certifiablejeep
Bicentennial Nickel
1976 CJ5
OK, I went with the stainless kit as well for the brakes and the gas lines.
2 things I noticed when laying them out today, first, the gas lines look to be a lot shorter then what I need. Iknow I can compensate with longer rubber from the ends to the pump and gas filter outlet, but I was shocked to see this.
Secondly, I am converting from manula to power brakes and the kit came with 2 different size master cylinder lines and I am not sure if with power brakes do you need a different proportinoning valve.
Any ideas?
CertifiableJeep
'76 ORANGE
'76 MAROON
'78 SILVER
'82 WHITE
Build
'83 GREEN
Build
RHD JEEP CLUB #41
NEWJO Member
post #5 of 7 Old 06-29-2003, 12:53 PM Thread Starter
certifiablejeep
Bicentennial Nickel
1976 CJ5
Any way to get a close up of your valve so I can compare?
Thanks,
cb
CertifiableJeep
'76 ORANGE
'76 MAROON
'78 SILVER
'82 WHITE
Build
'83 GREEN
Build
RHD JEEP CLUB #41
NEWJO Member
post #6 of 7 Old 06-29-2003, 07:58 PM
79Renegade
Any ideas?
[IMG]
http://www.imagestation.com/picture/...7/fbce3cf4.jpg[/IMG]
Here is a few pics.Did the best I could with the engine & tranny in place.I have a stock 79 CJ5 and the fuel lines stop at the front of the tub and rubber lines go to the engine. Other than a 2 piece steel line from carb to fuel pump. I assume that is original.
My parts jeep had manual front discs and I used that proportioning valve. The lines I ordered are for power front disc and the lines fit.( I am installing the power brake unit off another Jeep.The bigger line goes towards the front of the jeep.)
I'm not to the stage of brakes yet, so I don't know if I have to change the proportioning valve.
Greg
post #7 of 7 Old 06-30-2003, 04:03 AM Thread Starter
certifiablejeep
Bicentennial Nickel
1976 CJ5
Thanks for the pics. The valves are different apparently. I am seeing one on Ebay for 20 bucks right now so I will pick that up.
As for mine, I don't have the front guy on the angle like yours, mine are all non-angled and the "front one" is not larger, it is the same size, so that is where I am at.
As for the brakes, I don't think it needs to be changed if you were going with manual brakes, only power.
Thanks for the info, it is much appreciated.
cb
CertifiableJeep
'76 ORANGE
'76 MAROON
'78 SILVER
'82 WHITE
Build
'83 GREEN
Build
RHD JEEP CLUB #41
NEWJO Member
brake lines asherdav Jeep CJ Forum 3 07-17-2009 02:46 PM
Weber 34 conv, nutter, Vacuum lines / Fuel lines valkadesh Jeep CJ Forum 29 06-11-2007 09:21 AM
Brake lines EDs Jeep Jeep CJ Forum 3 03-25-2007 01:58 PM
Running auto trans lines...use braided or hard lines? Pacfanweb Jeep CJ Forum 7 08-15-2006 10:07 PM
SS brake lines CJ Fanatic Jeep CJ Forum 2 06-17-2005 07:01 PM
