Brake line removal help! - JeepForum.com
post #1 of 1 Old 02-12-2013, 11:04 AM Thread Starter
Alex77cj7
1977 CJ7
Hey I'm in the process of removing my brake lines right now and I'm in desperate need of some help. On the front axle the nut part of the brake lines is between the drum and the knuckle of the axle. It's too tight of an area to fit a wrench. What do I do? Here's a pic.
Also when I removed my drivers side brake line no brake fluid poured out if it.. I pressed the brakes to see if the hard line is clear and the fluid squirted out. I've noticed recently that my jeep has been pulling hard to the right when I brake. Could this be why? What would cause the dry brake line?
Build: http://www.jeepforum.com/forum/f22/my-77-cj7-project-sleeping-beauty-1442479/#post14508634
Alex77cj7 is offline
