Brake Line Issues! - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Brake Line Issues!
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line*VOTE NOW Help Metalcloak Giveaway an XJ Suspension*The Original 3/8" Ruffstuff Diff Cover!
Unread 07-05-2014, 07:08 PM   #1
aglinks
1983 CJ7
Brake Line Issues!
So I broke a brake line this weekend (rubber one on the left) and am having a hard time removing it. You can see in the picture how the shoulders of the nut on the right are stripped and even vice grips aren't working. Any tips? Can I just remove the angle piece and use a coupler to attach to the steel line on the right?
aglinks is offline   Reply With Quote
Unread 07-05-2014, 08:30 PM   #2
texasdave
texasdave's Avatar
1980 CJ7
Remove the spring clip holding the line on the mount. That should give you some extra room. I'd cut the rubber line soak the coupling with PB blaster pull it back through the mount where you can get a good grip with a wrench and use large water pump pliers to hold the rubber line coupling.
texasdave is offline   Reply With Quote
Unread 07-05-2014, 09:57 PM   #3
aglinks
1983 CJ7
Ok I'll soak it tonight. Maybe I'll have better luck tomorrow.
Unread 07-06-2014, 10:06 PM   #4
aglinks
1983 CJ7
Got it off with some PB blaster and a small pipe wrench. Took some blood, sweat, and swear words though. New line is on order.
Unread 07-07-2014, 06:56 PM   #5
aglinks
1983 CJ7
I got it replaced, took probably a lot more effort than it should have but everything seems to be working.
Unread 07-08-2014, 05:10 PM   #6
aglinks
1983 CJ7
Just out of curiosity, are anyone elses brakes really damn stiff? It takes a fair amount of force to stop. Maybe my booster is bad?
Unread 07-08-2014, 05:21 PM   #7
Coiz
1979 CJ7
Don't forget it is a lifted Jeep with 33's so they can feel that way.
If you want to test your booster, start the engine and let it idle. Shut it off and pump the brakes, you should get 2-3 good pedals before it gets obviously stiff. Press your foot on the brake and start the engine, the pedal should fall a little once the booster gets vacuum.
Mike
My build thread
Coiz is offline   Reply With Quote
Unread 07-08-2014, 06:15 PM   #8
zillla
1975 CJ5
Happened to me. I had to use heat to get my old one off. Uh nebba mind
Pull my finger
zillla is offline   Reply With Quote
Unread 07-08-2014, 06:34 PM   #9
jay-h
You might want to upgrade your brakes. The stock brakes were barely adequate for stock tires
My toys
'89 Wrangler YJ
'47 CJ2-A
wife's toys
97 Grand Cherokee (ZJ)
87 MB 560SL roadster
jay-h is offline   Reply With Quote
Unread 07-08-2014, 06:56 PM   #10
Professur
A 6" pipe wrench and a cheater pipe and a great goto for rounded nuts. Far better than Vise grips
Professur is online now   Reply With Quote
Unread 07-08-2014, 07:54 PM   #11
aglinks
1983 CJ7
That's what I ended up using, 6" pipe wrench is officially added to the tool bag.
Unread 07-08-2014, 10:25 PM   #12
aglinks
1983 CJ7
I followed this exact procedure and it did exactly as you said, so apparently my booster is good. I have good pads up front so maybe I am just paranoid.
