brake lights went out - JeepForum.com
post #1 of 11 Old 02-14-2012, 06:06 PM Thread Starter
My83andMe
1983 CJ7
Hey everyone, maybe you can help me figure this one out. My brake lights won't light up when I put pressure on the peddle though when I turn on the running lights the bulbs and wiring are good. This is a new one for me and I can't seem to track it down. Thanks guys... if you can help out on this you'll really be saving my rear end.
I thank you and believe me my Jeep definatly thanks you cus otherwise I'd be turning a wrench with out a clue. :)
My83andMe is offline
post #2 of 11 Old 02-14-2012, 06:17 PM
teh603
1963 CJ5
Switch gone bad on you?
teh603 is offline
post #3 of 11 Old 02-14-2012, 06:29 PM Thread Starter
My83andMe
1983 CJ7
Not exactly sure. I tried to poke my head around the peddle but with the steering, wires, etc. in the way I can't tell. What would it take, once I am able to find it, to get it out and check?
post #4 of 11 Old 02-14-2012, 06:37 PM
only in a jeep cj
Running lights are on a different circuit then the tail and turn lights. They use the second filament in the bulb. Do your turn signals work? If so, I would look into the switch as well. Without disconnecting anything, there is a two wire lead with a plastic plug coming off the switch wire about 4 inches from it. Red wires, one solid one with marker. Jump this plug to bypass the switch and test the rest of the wiring, etc. Let us know from there.
Ed
1975 CJ-6 1983 CJ-8
1986 CJ-7 Laredo 1986 TJ-7 Trail Jeep
2003 Inca Gold TJ Rubicon
only in a jeep cj is online now
post #5 of 11 Old 02-14-2012, 06:55 PM Thread Starter
My83andMe
1983 CJ7
Will do. Unfortunately its looking like I'm going to have to take out my drivers seat. It take some awkward bending and I still can't get a clear look at it. How exactly do I jump the connection once I get to that point?
post #6 of 11 Old 02-14-2012, 07:49 PM
only in a jeep cj
Just slide seat all the way back and with right shoulder on the floorboard, look up and follow the brake pedal all the way up to the pivot, the switch will be off to the side a bit. The test plug will be hanging a few inches over. A small scrap wire will make a jumper just to see if the brake lights come on.
Ed
1975 CJ-6 1983 CJ-8
post #7 of 11 Old 02-14-2012, 10:32 PM
BagusJeep
1981 CJ7
Also check your fuses, you should have a 20 Amp STOP fuse.
It is on the same circuit as the Hazard flasher and clock (if fitted). There are other fuses for the Turn signals and park and tail lamps.
BagusJeep lives in Bali.
1981 CJ7 258ci - Bagusjeep
1984 CJ7 258ci - Puthijeep
1981 J20 258ci - Gladys
1995 Cherokee 4.0 - CHEROKEE
BagusJeep is offline
post #8 of 11 Old 02-14-2012, 10:56 PM
Coiz
1979 CJ7
For visual reference, this is where to find the brake light switch on the pedal assembly.
Mike
Coiz is offline
post #9 of 11 Old 02-16-2012, 12:40 PM Thread Starter
My83andMe
1983 CJ7
Hey all-star I appreciate all the quick replies. I got it apart and tried both jumping it and plugging in a new switch and still no change. Frustration is starting to set in all over again
post #10 of 11 Old 02-16-2012, 12:52 PM
csabens
Did you check the fuses? If so and all is well...
Another option for testing (with a test light) is to remove some of the wire loom running down the driver side and locate the hot wire for the brake lights, i think it's red, i can't remember off the top of my head though. Jump the wires again under the dash, and ground your test light and move up and down the wire to see where you go dark. Start up front and move to the back.
Daily Driven: 1985 CJ7 Renegade, 258ci 4.2L (TeamRushed and Nuttered), T176/Dana 300 (in need of an overhaul), Weber 38 DGES, Ion Alloy 174 15x8, MasterCraft Courser MT 33x12.5x15, Front Axle Dana 30 w/ Superwinch Hubs, Rear Axle AMC 20 w/ one piece Alloy USA.
csabens is offline
post #11 of 11 Old 02-16-2012, 12:54 PM Thread Starter
My83andMe
1983 CJ7
Alright! Got it. Just had to trace it to a worn wire. Thanks again everyone.
Brake lights not coming on, Reverse lights up brake lights Where to start? AJeep Jeep CJ Forum 7 11-24-2010 07:41 PM
parking lights behaving brake lights, wtf? NJCJ7 Jeep CJ Forum 6 06-04-2010 04:40 PM
Brake lights/Backup lights issue montypyfly Jeep CJ Forum 3 12-03-2009 05:20 PM
all exterior lights work except for the brake lights! meater Jeep CJ Forum 4 11-01-2008 07:31 PM
brake lights dont work w/ head lights on mike norman Jeep CJ Forum 4 09-27-2005 02:53 PM
