brake lights help 1963 cj5 - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > brake lights help 1963 cj5
50" LED CREE Light Bar Pair With Wiring KitFLASH SALE! Open thread to reveil the Newest Sale @ ROCKRIFS: Jeep Fog Light LED Bulbs! Several Brightness Options!
Unread 04-12-2014, 01:01 PM   #1
Dtsouth2
1963 CJ5
I need help I cannot get the brake lights or signals to work. There is a brown on each side that appears to gobtobthe brake switch on the peddle but then im lost there is a single brown wire that I wire hot?
Dtsouth2 is offline   Reply With Quote Quick reply to this message
Unread 04-12-2014, 01:39 PM   #2
Mike Romain
Location: Off the Grid in Chester Grant, Nova Scotia, Canada
There is usually one hot wire for both and it uses the fixture bolts for the ground path. So the fixtures and the tub both have to be good grounds.
Mike
Some Canadian Bush Jeep Runs and Build Photos: http://mikeromainjeeptrips.shutterfly.com (10 new albums added Sept 16/10)
Mike Romain is offline   Reply With Quote Quick reply to this message
Unread 04-13-2014, 08:49 AM   #3
Dtsouth2
1963 CJ5
Thanks! Any idea how the flasher hooks up it has a rd white and black
Unread 04-13-2014, 08:55 AM   #4
Mike Romain
The Haynes CJ manual is a good book to have. It has decent wiring schematics. If I can find mine, I can help more. Don't know your setup off hand, sorry.
Tempted to say red to fuse, white to signal arm and black to ground. Just a guess.
Mike
