Brake lights driving me crazy - JeepForum.com
 3Likes
  • 1 Post By Fourtrail
  • 1 Post By ECJ-7
  • 1 Post By eyedoc
post #1 of 9 Old 08-17-2017, 11:42 PM Thread Starter
eyedoc
OK, I had to replace my turn signal because only one signal was working and I was completely lacking brake lights. So, I've rewired everything and I have all signals working, but I ONLY have brake lights when the headlights are on. No headlights, no brake lights.
I've checked the wiring and I have one wire from my turn signal going to the brake switch and the other pole of the brake switch goes to the light switch. The diagram shows the brake lights splicing in the back and then going to one of the terminals on the light switch. I've screwed with this so much I have the entire schematic memorized, but I'm wondering if I possibly have a bad brake switch? I mean, they come on when the lights are on, so that's probably not it...but everything else is new including all of the wiring and the entire tail light housing.
HELP ME!!! I'm going friggin' batcrap over this thing!
1959 Willy's CJ5
eyedoc is offline
post #2 of 9 Old 08-18-2017, 12:09 AM
Fourtrail
1974 CJ6
Which teminal on the light switch are you hooked to? I believe you should be hooked to constant power/incoming power to the light switch. Like the headlights, tge brake lights should function with the key off. Sounds like you are hooked up to the wrong terminal giving you only brake lights when the lights are on.
John Strenk likes this.
80 CJ-5, 74 CJ-6, 56 CJ-5
Fourtrail is online now
post #3 of 9 Old 08-18-2017, 04:14 AM
ECJ-7
1976 CJ7
find a hot terminal on the fuse panel and plug the brake light wire into it. I'm guessing there is a brakelight fuse, but even if there isn't just find one that is hot all the time.
ECJ-7 is offline
post #4 of 9 Old 08-18-2017, 06:40 AM
pedal2themetai
1956 CJ5
HI. there should be power to one side of the brake light switch all the time the key is on.. Sounds like you only have power with the lights are on then you have it wired wrong.. Also there are two filaments in the bulbs.. one bright one dim.. The bright one is Brake/signal filament and the dim one is tail lights.. if you get them mixed up you well NOT be able to see the brake lights with the lights on..
Did you figure out that switch in your grill??
good luck
tim
pedal2themetai is offline
post #5 of 9 Old 08-18-2017, 07:51 AM Thread Starter
eyedoc
good luck
tim
I'm going to play with it today and see if I can figure it out. The brakes work great with the lights on, it's when they're off that everything falls apart.
I'm pretty sure that thing on the grill is some kind of relay for towing. The wires are clipped down low, but I think that's what it is.
1959 Willy's CJ5
eyedoc is offline
post #6 of 9 Old 08-18-2017, 07:52 AM Thread Starter
eyedoc
Maybe? I went by the schematic, but I'll hook it to another one and see what that does
1959 Willy's CJ5
eyedoc is offline
post #7 of 9 Old 08-18-2017, 11:46 AM
bob4703
1974 CJ5
This good advice except you do not have fuse box or panel--just individually fused circuits. If you wire it up from a hot source fuse it and don't piggy back off another fused circuit. It is a simple circuit--fused power to brake light switch to brake lights.
Good luck and bright lights!
Paved roads are prime examples of government over spending!
bob4703 is offline
post #8 of 9 Old 08-18-2017, 12:07 PM
pedal2themetai
1956 CJ5
What year are you working on??
good luck
tim
post #9 of 9 Old 08-18-2017, 05:07 PM Thread Starter
eyedoc
1959, but with a little trial, a little error and a little profanity, I figured it out. I assume because it's a newer light switch, the poles don't match the schematic in the manual and Fourtrail got my brain going with his post above.
I just touched every connection on the light switch until I found one that was a continuous power pole and it worked like a champ. I'm happy to say we're now properly inspected and licensed! I've been driving it around all day and it's awesome. A little loud, a little rough and every once in a while smells like gas...perfect.
Thanks for all of the replies.
1959 Willy's CJ5
eyedoc is offline
