Brake lights don't work - JeepForum.com
Go Back JeepForum.com > Models > Jeep CJ Forum > Brake lights don't work
Northridge4x4 - Memorial Day SaleSuper Low Prices on TJ Bumpers and $399.95 Tire Carriers!RCI FUEL CELL BRACKET - Perfect for the back of your Jeep
Unread 05-17-2006, 08:16 PM   #1
78GoldenEagle
1978 CJ7
So I'm a new guy to not only the Jeep world, but the auto restoration world. I just recenlty bought a 1978 Jeep CJ7 Golden Eagle. It runs Ok. I can can drive it around at least I could if I had brakelights. I 've changed the fuse, the bulbs and cleaned the grounding wire. I'm wondering if the stoplight switch is bad or if maybe there is a wire not plugged in somewhere (the rear lights work-just not the brake lights)? Any thoughts?
Bruce
78GoldenEagle is offline   Reply With Quote
Unread 05-17-2006, 08:39 PM   #2
tmak504
1976 CJ7
you could check the brake pedal, there is a point in which the brake light engages when you hit the pedal itself, sounds like you covered evertything else...
[url]http://memimage.cardomain.net/member_images/4/web/2236000-2236999/2236506_1_full.jpg[/url]
tmak504 is offline   Reply With Quote
Unread 05-18-2006, 12:15 AM   #3
RARECJ8
my brake lights failed (its an 81, so it was time) all things checked out-- so now WTF? then i remembered all the brake light power goes thru the turn signal switch and then while driving it one day (w/out the rear lights, doh!) the left turn signal stopped working-- so i replaced the switch and presto! all works great!
mb
Who is John Galt?
Life member BRC
Cal4Wheel
www.hillsangels4x4.com
RARECJ8 is offline   Reply With Quote
Unread 05-18-2006, 03:04 AM   #4
John Strenk
John Strenk's Avatar
1976 CJ5
If just the brake lights dont work then check the fuse and switch.
If both Turnsignals and Brake lights dont work, check the TS switch (Hazard Switch partialy in?) and harness.
John Strenk is online now   Reply With Quote
Unread 05-18-2006, 05:59 AM   #5
jason43
Best bet is the switch on the brake pedal if everything else works, IMHO.
jason43 is offline   Reply With Quote
Unread 05-18-2006, 06:06 AM   #6
fuzz401
1978 CJ7
ck the switch it might of pushed back it is way up under the dash
1978 cj-7 had since 1979
401 .030 over- full floating flat top pistons
crower solid cam 292 dur .500/.510 lift
turbo 400 tranny 2500 stall
model 20 transfer case
aj delux glass body
4" lift
dana 30 frount
dana 44 rear
4.56 gears
http://img2.photobucket.com/albums/v...slideshow=true
http://photobucket.com/albums/v31/fu...slideshow=true
13.461 @ 92.45 mph on 37" super swampers on 1/4 mile
fuzz401 is offline   Reply With Quote
