Brake lights/Backup lights issue - JeepForum.com
post #1 of 4 Old 12-02-2009, 03:28 PM Thread Starter
montypyfly
1983 CJ7
Brake lights/Backup lights issue -- SOLVED
I have an issue with my 83 CJ-7
My back up lights haven't worked for a while. I just assumed the switch was unaligned. But the other day I noticed my brake lights were sticking on.... Pulling on the peddle didn't help like in my old CJ-5s, so I just pulled the fuse so they would go off.
Today I notice..... I have Back up lights!!!!!... I put the fuse back in, I have stuck brake lights and NO backup lights. Fuse out, Back up lights again.
So... any guesses? At first I was thinking I would just fight with the brake light switch, but since I know that to be a major PITA, my thought is now that something in the brake wires is shorting out and causing the Brake lights to stay on, and to cause the backup lights to fail. Removing the fuse eliminates the short effecting the backup lights.
Does this sound plausible? if so, any guesses where I should start hunting down the problem? Thanks for any and all ideas.
montypyfly is offline
post #2 of 4 Old 12-02-2009, 04:52 PM
bulletproofcj
1980 CJ7
Are your brake lights by chance dim? You may have ground issues at your taillights.
John
bulletproofcj is offline
post #3 of 4 Old 12-02-2009, 06:12 PM Thread Starter
montypyfly
1983 CJ7
Problem SOLVED
Fought the cold and took a look at the Brake Light Switch. I just stuck a thick magnetic sheet under the Switch, now it pushes up far enough to shut off. And now... the back up lights seem to be working with the fuse in.... Still have no idae about that, but it's working.
So ... "Never Mind"
post #4 of 4 Old 12-03-2009, 06:20 PM
bulletproofcj
1980 CJ7
If only all CJ problems were that easy. Driving a CJ sometimes tells others we love a challenge.
Any way to improve the backup lights? W7NB Jeep CJ Forum 18 12-21-2009 11:04 PM
backup lights won't come on sparctacus Jeep CJ Forum 4 08-13-2007 08:36 PM
Wiring issue is driving me nuts, rear brake lights work when they want gunsmokex Jeep CJ Forum 2 07-16-2007 11:57 AM
brake lights dont work w/ head lights on mike norman Jeep CJ Forum 4 09-27-2005 03:53 PM
Backup lights question Baloo Jeep CJ Forum 12 04-24-2003 10:09 PM
