Brake light will not come on! - JeepForum.com
post #1 of 16 Old 05-13-2013, 07:24 PM Thread Starter
Jefenhauser
1980 CJ7
My brake light are not coming on when I press the brake pedal. I check the switch with a meter and it seemed to be working and the parking light come on and the blinkers work. My hazards don't work either. Anyone have an idea what to look for?
Jefenhauser is offline
post #2 of 16 Old 05-13-2013, 07:46 PM
SCSEAJAYSEVEN
1978 CJ7
Fuse?
SCSEAJAYSEVEN is offline
post #3 of 16 Old 05-13-2013, 07:48 PM Thread Starter
Jefenhauser
1980 CJ7
The fuse is good.
post #4 of 16 Old 05-13-2013, 07:48 PM Thread Starter
Jefenhauser
1980 CJ7
Oh I forgot its a 1980 CJ7
post #5 of 16 Old 05-13-2013, 08:07 PM
james04si
james04si's Avatar
1977 CJ5
Could be the turn signal switch in the column. I know if the hazard button is stuck halfway in the front lights in the grill light up when you hit the brakes. I found that out when I failed inspection and tore the column apart only to figure out the hazard button was stuck halfway in.
james04si is offline
post #6 of 16 Old 05-14-2013, 05:07 AM Thread Starter
Jefenhauser
1980 CJ7
The hazzards are not working either. When you push the button in you lose the turn signals but they start working again when you pull the hazzard button back out. This is very frustrating!
post #7 of 16 Old 05-14-2013, 05:39 AM
thompsoj22
id have to see the schematic for your year
but i had the identical problem, it is the turn signal switch and it is kind of a bear to change but cured the problem. bought it at the zone for $24. pull the wheel, the snap ring that is behind it is the fun part. it holds the steering lock plate, pull the column mount hrdwr and support bracket, the plastic cover for the signal switch harness, feed the wires out through the top and reverse it to install. that snap ring is a bear!. make sure you get the right switch for tilt or non tilt.
thompsoj22 is offline
post #8 of 16 Old 05-15-2013, 06:35 AM Thread Starter
Jefenhauser
1980 CJ7
I have not been able to work on it yet but now the Blinker fuse keeps blowing so i'm gonna try to replace the switch and start tracing back to see if i can see where the problem lies. This morning I did find that the PO was running the electric fuel pump off the brake light fuse. I moved it from there but still have not found the issue.
post #9 of 16 Old 05-15-2013, 09:03 AM
texasdave
texasdave's Avatar
1980 CJ7
Flasher.
texasdave is offline
post #10 of 16 Old 05-15-2013, 04:12 PM
WindKnot
1977 CJ7
There's a special tool usually available for rent/free at the parts house to push the lock ring down making the ring easy to remove. If your signal doesn't "self cancel", now's the time to change that out too.
I'd rather be lost on the trails than found at home!
Phoenix Rising- A Flame Off Restoration?
WindKnot is offline
post #11 of 16 Old 05-15-2013, 04:35 PM
james04si
james04si's Avatar
1977 CJ5
And if you have doubt you can always unplug the turn signal switch under the dash and plug in the new one before tearing down the column to test.
post #12 of 16 Old 05-15-2013, 04:53 PM
thompsoj22
now that is a good idea
slaving the switch in to see favorable results prior to the teardown is smart
post #13 of 16 Old 05-15-2013, 04:56 PM
thompsoj22
be careful with the hazard wiper!
i assumed the little contactor that clips into the signal switch comes with the new switch, "wrong". you have to reuse it so be gentle with it. two little contact arms, cant miss it.
post #14 of 16 Old 05-15-2013, 06:25 PM Thread Starter
Jefenhauser
1980 CJ7
I ordered the switch today. Thanks for the advice!
post #15 of 16 Old 05-17-2013, 11:07 AM Thread Starter
Jefenhauser
1980 CJ7
Well got it fixed! The PO had wired the radio through the hot wire going to brake light switch a
