Brake light problem of my own - JeepForum.com
post #1 of 2 Old 02-17-2012, 05:01 AM Thread Starter
imafishingfred
imafishingfred's Avatar
1981 CJ7
So not to hijack any other threads I decided to start from scratch. I'm working on my sons 79 CJ7. His brake lights stopped working. His turn signals do work. After reading some of the other threads in the last couple days I tried a few things.
I checked the fuse - OK
Removed the brake switch and checked it - OK
Placed a jumper wire in the brake switch connector - Still no brake lights. I do however have power to the connector and from there to the turn signal switch connector on the side of the column.
Here's where I gave up for the night.
Without the jumper the turn signals work. With the jumper the turn signals work, BUT, if you turn on the signal with the jumper wire in place the brake light on the opposite side comes on also (It's not flashing on that side, just a brake light). Same thing for the other side when you turn that signal on. Swapped out the 2 flashers and both work (click) when the signal is on. The emergency flashers will not come on.
So I'm thinking I may have a bad turn signal cam or a short in the column harness.
Any ideas or suggestions?
imafishingfred is offline
post #2 of 2 Old 02-17-2012, 10:15 AM Thread Starter
imafishingfred
1981 CJ7
Problem solved thanks to the forum search and John Strenk's writeup on replacing the turn signal cam on this thread
http://www.jeepforum.com/forum/f8/tu...witch-1225607/
Thanks John
FNG brake problem. Dash E-Brake light on - pedal is softer then a teddy bear Dudman5703 Jeep CJ Forum 6 06-23-2011 07:53 PM
brake light problem op-and-sons Jeep CJ Forum 0 02-03-2011 04:51 PM
Single Rear Brake Light Problem HakkTW Jeep CJ Forum 5 05-19-2009 10:27 PM
Another brake light problem fastas69 Jeep CJ Forum 13 12-29-2008 06:26 PM
Another CJ5 Brake Light problem thread Scuter83 Jeep CJ Forum 2 05-05-2007 02:43 PM
