Brake light on dash on after new ss brake lines - JeepForum.com
post #1 of 6 Old 09-04-2002, 09:29 AM Thread Starter
Jeep Daddy
Jeep Daddy's Avatar
I installed new SS braided brake lines in front and my dash brake light stays on. I disconnected the wires to the proportioning valve and it's off now. Yes, I bled the front brakes after installing the new lines. I didn't re-blead the rear
Will the smaller diameter brake lines cause the brake light to stay on all the time? or do I need to check for air in the lines or a leaky wheel cylinder in the rear. I guess it could be coincidental that a wheel cylinder started leaking right after installing new front brake lines
2004 Rubicon, 6" lift, 35s, winch, hard top, full doors, bumpers, tire carrier and rock sliders.
Jeep Daddy is offline
post #2 of 6 Old 09-04-2002, 12:43 PM
4wheeler4CJ
4wheeler4CJ's Avatar
The proportioning valve piston inside may be stuck to where it moved when your line leaked originally. It may not have returned to the original position once you replaced the line, so that may be why the light stays on now.
4wheeler4CJ is offline
post #3 of 6 Old 09-04-2002, 02:09 PM Thread Starter
Jeep Daddy
Jeep Daddy's Avatar
I kind of figured it was something like that. So, how do I fix it????
post #4 of 6 Old 09-04-2002, 10:49 PM
jeepdaddy2000
jeepdaddy2000's Avatar
1971 CJ5
It's a two person process. What you need to do is to have one person crack a bleeder on the rear. Then with the key(brake light) on, you SLOWLY depress the brake pedal. Keep applying pressure until you feel a "pop" in the brake pedal. The light should go out. Stop and have your friend close the bleeder. Slowly ease the pedal back up. If after applying heavy pressure to the pedal the light doesn"t pop, close the rear bleeder, release the pedal and repeat the process with the front. NOTE, some times the pedal will "pop" and the shuttle valve will go the other way(the light will flash off, then be on again). If this happens, go to the opposite bleeder(front or rear) and repeat the process. Don't forget to recheck your fluid level.
jeepdaddy2000 is offline
post #5 of 6 Old 09-05-2002, 12:20 AM Thread Starter
Jeep Daddy
Jeep Daddy's Avatar
Ok, thanks. I'll try that and let you know how it works. Thanks again.
post #6 of 6 Old 09-10-2002, 06:39 PM Thread Starter
Jeep Daddy
Jeep Daddy's Avatar
I finally got a helper to assist in bleeding my brakes again and the light is out. I started on the rr wheel and as soon as I bled it one time, the light went out.
Thanks for the suggestions.
Which Brake Lines??? poppatello Jeep CJ Forum 7 02-02-2010 12:05 PM
Brake light on dash is on wm69 Jeep CJ Forum 6 02-02-2009 03:21 PM
brake lines bjf498 Jeep CJ Forum 8 04-17-2008 11:16 PM
CJ7 Brake lines 5artist5 Jeep CJ Forum 6 08-24-2007 08:11 AM
brake lines, gas lines, which order certifiablejeep Jeep CJ Forum 6 06-30-2003 04:03 AM
